Suggestions on non-working Linear Series RV5090 system in travel trailer
System was working. Went on trip and tried it, did tnot turn on. Pressed reset button, no response. Checked fuse, good fuse. TV works, but system seems to not have power or not working? Any suggestions?
  • 192 Answers
SOURCE: Will not power on. Please Help!!
Error code 12 means normal operation. On these models we have found that a switch is sticking on the control panel not allowing the set to turn on. Disconnect the control panel. You will be able to use the remote on it. To find the plugs for the control panel: Remove the speaker grill and front panel, then follow the wire to the connection. Remember to unplug the set before putting your hands inside of it. Tell me how it went. Lead Tech
Posted on Dec 15, 2006
  • 2651 Answers
SOURCE: Tappan 30 Series Range ignition system
no fuse/ with execption of trying to reset circuit breaker. perhaps the power tripped the breaker om the electrical panel, if the power supply is goos to the unit i would look to the spark module( it contorls all electronic ignition function
Posted on May 08, 2008
  • 3433 Answers
SOURCE: trailer running lamps will not work
Your running lights/marker lights and tail lights are on the same circuit. I all thetruck lights work, the problem is in the plug or plug harness.
Posted on Jul 01, 2009
SOURCE: navigation system, radio, front power outlet failure
The solution is to buy a new mini fuse (Blue #15) at an autonation or similar. Open the passenger side kick plate fuse box and pull out the fuse in position #9 (upper most left fuse). You will need needle nose pliers or tweezers etc... Insert new fuse and you are done. 50 cent repair and 30 seconds spent screwing with it. Enjoy! Oh, and don't worry about blowing it again. Best I can say is when starting the car, unplug the power sucking device like a radar. Once car is on you can re-insert it the radar. The initial jolt of powering everything on all at once is what blew your fuse in the first place. Get a few additional fuses to have on hand just in case.
Posted on Jul 17, 2009
  • 3 Answers
SOURCE: System turns on but is nonresponsive and doesn't work.
Did you get the im600 wet? I have a similar problem, and I've been touching the power and volume buttons with wet fingers. I believe the design allows for liquid to enter the unit, and then it short circuits. Also found gummy residue around the pin, in the power connector on the back. Hope that helps.
Posted on Jul 19, 2009
Utility trailer electric brake are not working when connected to my truck
the wires to the electric brakes at wheels , I had this problem on my travel trailer and it turned out due to corrosion at connectors at wheels the power wasn't getting to wheels one other thing to ck is trailer plug , it turns out not all mfg wire there plugs the same , try to obtain a diagram from mfg for both trailer and truck , compare them for any differences
Sep 29, 2016 | Cars & Trucks
Wiring diagram for salem by forest river travel trailer
Try turning them to the off position then on again that should reset the breaker. When they trip sometimes they move so little you can hardly see it.
May 03, 2014 | Cars & Trucks
Electric heater problems.
Plug in a ceramic 120 volt or oil type space heater to keep trailer warm. Most travel trailers are propane only, they do not have electric heat strips. I would bet that is why it only blows cold air.
Jan 28, 2014 | Open Range 2011 Mesa Ridge MR243F
I have a travel trailer every time it gets 90 or higher outside it will blow the fuse. I have went on top and cleaned it good but no change. any ideas thanks
Where do you have it plugged in to? Is it plugged in with 30amp plug to receptacle. Which breaker is tripping, the one for AC only, or the main breaker for trailer, or breaker at plug in?
Jul 27, 2011 | Heating & Cooling
Specs for orion 12" hcca
* Sensitivity: 84 dB
* RMS Power Range : 2000 Watts
* Peak Power Handling: 4000 Watts
* Impedance: 2 Ohm
* Diameter: 12 Inch
* 4" Copper Wound Voice Coil on an Aluminum Former, High temperature PAARC (Polyester Amide, Amide Resin Coated)
* Continuous power handling will be 1500W (under rated)
* Burp power in excess of 5000W
* X-Max estimated at 30mm (total travel 4" peak to peak)
* Field Replaceable Cone / Voice coil / Spider Assembly
* Dual Flat Conex Spiders with Loop/Stitched Tinsel Leads
* Tall, wide, balanced, Foam (high density expanded polyester foam) surround for linear controlled long excursion using a Tri-Radius symmetrical edge design optimized on non-linear FEA
* Enhanced voice coil cooling system (forced convection ? aluminum heat sinking ? shorting rings to reduce inductive heating)
* Dimensions (in) 11.9 x 10.7
Jan 04, 2011 | Orion HCCA 12D Car Speaker
Instructions for wiring a moving trailer connector
Trailer Wiring Diagrams 4 Way Systems
4 way flat molded connectors allow basic hookup for three lighting functions; right turn signal / stop light (green), left turn signal / stop light (yellow), taillight / license / side marker (brown) and a ground (white).
4%20way%20wiring.jpg 4way_vehicle.jpg 4 way tow vehicle side.
4way_trailer.jpg 4 way trailer side.
5 Way Systems
Same as 4 way system listed above but adds a extra blue wire for brake signal or auxiliary power. Used on pop up camper trailers or utility / boat trailers.
5way_vehicle.jpg 5 way tow vehicle side.
5way_trailer.jpg 5 way trailer side.
6 Way System, Rectangle Plug 3/4 inch by 1 inch 6 way rectangle connectors right turn signal (green), left turn signal (yellow), taillight (brown), ground (white). The red and blue wire can be used for brake control or auxiliary. Use on a small motorcycle trailer, snowmobile trailer or utility trailer. Can also be used as custom wiring on trailers with 3 light/wire systems. See "Tow Vehicle Taillight Wiring" below.
6way_rectangle_1.jpg 6 way tow vehicle side.
6way_rectangle_2.jpg 6 way trailer side.
6 Way Systems, Round Plug
Round 1 1/4" diameter metal connector allows 1 or 2 additional wiring and lighting functions such as back up lights, auxiliary 12v power or electric brakes. Note: The black (sometimes red) 12v and blue electric brakes wire may need to be reversed to suit the trailer. Check with a test light or VOM. Uses: horse trailer, travel trailers, landscaping trailer, car trailer, etc.
6way_vehicle.jpg 6 way tow vehicle side.
6way_trailer.jpg 6 way trailer side.
7 Way Systems
Round 2" diameter connector allows additional pin for auxiliary 12 volt power or backup lights. Uses: heavy duty landscaping trailer, car trailer, boat trailers, horse trailer, travel trailer, construction trailer, etc. Check with a test light or VOM.
7way_vehicle.jpg 7 way RV flat blade tow vehicle side.
7way_trailer.jpg 7 way RV flat blade trailer side.
Jan 01, 2011 | 2001 Pontiac Montana
Dometic Duo-Therm air conditioner: keeps tripping the breaker. Unit is 4 years old. 57915-331 Everytime we use it; it cools the camper just fine but out of the blue it trips the breaker and won't work....
First clean the condensor with air blower or water pump and clean the filters.If the same problem persists there is a choke up in the refrigeration piping, cut from the discharge side and suction side flush the system with nitrogen, replace the filter drier and choked capillary if it is a capillary system, brace back the discharge and suction piping to the compressor again, leak test with nitrogen, evacuate the system charge refrigerant and start the system.
Aug 15, 2009 | Dometic Rooftop RV Air Conditioner
Travel Trailer wiring, lights and electronic brake control
i have a 1996 chevy 1500 bought a brake controler but what wire do i put the blue wire to ther are 4 white wires from brake peddle that go on when peddle is pressed on.
May 27, 2008 | 1996 Chevrolet K1500
Televison & Video Logo
23 people viewed this question
Top Televison & Video Experts
