Washing machine turn on but wont pump water to fill only sometimes
SOURCE: washing machine wont fill
It could be a bad water valve or it could be the board that controles the valve, I would check first and make sure that the two water hoses where they connect to the washer are not limed up or have some build up of some kind, you can turn the water off and disconect at the washer and visualy ck to see.
Posted on May 10, 2007
  • 1294 Answers
SOURCE: Rinse water fills the washing machine when the spin cycle starts
Check your outlet filter, most likely it is blocked, preventing the water from draining out. Chk your pump too. Before this disconnect from the wall socket; and also check the pipe coming from the tub to the filter. Siphon out the excess water from inside the machine before you open the pipes.
Posted on May 18, 2007
Jimster
  • 240 Answers
SOURCE: hotpoint wma10 washing machine wont stop filling up
You may have a problem with the pressure dome hose (has a cut or kink in it) or it may be a problem with the main control board. Sometimes that small hose inside the machine can get a cut or come loose. That sends pressure to the board and its valve to let the machine know that it has the right amount of water in it. If it has a hole or is blocked, that signal wont ever come on, and you have overfilling.
Posted on Sep 07, 2007
yalmer
  • 552 Answers
SOURCE: Filling With Water
This is probably a control board failure, which should be replaced by someone familiar with them.
If you are handy, you can do it yourself.
If you need assistance, let me know.
Posted on Mar 04, 2008
  • 11 Answers
SOURCE: washing machine wont stop filling up with water
Water valve is bypassing and need to be replaced or the water level switch control is out of order.
A remote possibily is a leaking pressure swith airhose is leaking . Good luck
Posted on Dec 28, 2008
Washer machine front loader wont fill up and wont drain
it maybe that the pump winding is open circuit some machines use the pump winding as the neutral line for the water valves so if the pump fails they wont fill no point in it filling if it wont empty
Mar 09, 2014 | Indesit W 123 Front Load Washer
My Kenmore 500 top loading washing machine wont work right. sometimes it will work and other times it wont. I will put a load in it and sometimes when it hits the rinse cycle it seems like it gets stuck...
for the top loading washing machine mostly have drain pump, please check the filter of your drain pump, if clog your drain pump of some hair pins,cotton buds or coins or any small item,that the cause of water stuck,and it will long time draining or totally not running the drain pump.and its cause of stop of cycle of washing machine in rinse time or spin time,because after washing the pump must be on to remove water before start the next cycle.and the unit top load have drain pump you must be up the drain hose up to 90cm from floor lever to make the water lever is make in normal,the water automatically goes out by drain pump.
and for unbalance most of all top loader have problem in unbalance, the main reason is overload or the type of cloth you wash.
Nov 02, 2013 | Kenmore 24032\24036 Top Load Washer
Wasing machine fills with water during washing and wont pump out filling the drum...
1. Empty the drum via the filter / trap at the front (there is sometimes a drain pipe near the filter - otherwise be prepared to use lots of towels to soak up the water).
2. Check / clean the filter.
3. Ensure that the drainage pipe is not blocked.
4. Check that the pipe from the pump to the waste water pipe is not kinked / blocked.
5. Check that the pipe from the drum to the pump is not blocked.
6. Does the pump sound like it's trying to work? If not, it could be that the pump is dead. Pumps can often become blocked with fluff / slime from the machine.
Jan 13, 2011 | Bosch Washing Machines
It wont spin
Your washer has a lid switch.97a908d.jpg If the switch is broken the washer will not spin. The pump is mounted on the motor.c5ccc2f.jpg
In the wash cycle the pumps turns counterclockwise. In the spin cycle the pump turns clockwise, forcing the water out of the machine. So if that lidswitch is dead then she won't pump OR spin. This video shows how to get into your machine and the next one shows how to replace the lid switch
Use this GUIDE to help you
Did I help?
May 28, 2010 | Roper RAS8445KQ Top Load Washer
My daughter has a samsung sw56app washing machine and it fills with water and washes but wont pump out to rinse and spin
That means the drain pump is broken and needs to be replaced.
Perhaps you need to check if the drain hose is correctly installed, sometimes a bend is not letting water get out.
Nov 05, 2009 | Samsung Washing Machines
Washer won't drain.
My washer fills up with water and goes thru the wash cycle but when it's time to drain, it just sits there and clicks.
Oct 17, 2009 | Tecnik TKL9260 Front Load Washer
Rinse cycle wont fill
check your drain hose. needs to be at hieght of tub before entering the drain....should only be 3-4 inches in the drain and secured with a ziptie.
Jun 08, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Old model rca washer machine...will not agitate/wash the clothes,does spin.
If the washer fills up with water and you hear the motor running but the agitator doesn’t move, the agitator coupling is the most likely problem. First pump the water out by turning the timer to spin. Once the water is out, turn the washer off. Now pull up on the agitator until it comes off (it may be hard to pull off). Now that the agitator is off, you can see the agitator coupling, reach down and try to turn the coupling. If the coupling turns freely, it is striped out and needs to be replaced.
Sep 29, 2008 | Washing Machines
Washing Machines Logo
32 people viewed this question
Top Washing Machines Experts
