Question about Philips Audio Players & Recorders
Philips makes crackling notice when plugged in wall and Idk why
Broken headphone jack on dell d630
Yes! if the plugin is not secure the connection will be poor causing unstable reception in the audio department.
May 10, 2012 | Dell Latitude D630 Laptop Computer PC...
30 year old Philips A12000 amplifier. Making fairly loud crackling sound from right channel.
Likely anelectrolytic coupling capacitor is going bad. Could cause further damage... repair before further use. A competent tech using an oscilloscope should be able to repair the unit, even without a schematic.
Jul 24, 2011 | Philips Audio Players & Recorders
My HP w22 Monitor started to make a crackling sound and than all the sudden turned off, or something. It wont come back on. The computer works just not the monitor. Any ideas on how to fix the problem?
Try checking your Cable connections to the Monitor to the Computer and from the Monitor to the wall outlet.The crackling sound maybe normal.Most Monitors make that sound.
Jul 31, 2010 | HP W22 LCD Monitor
I've got a Philips Faxjet 375 which displays NO LOOP CURRENT when I try to fax anything Any advice?
No dial-tone detected. Plug a regular phone into the wall jack and verify dial-tone.
Make sure you are plugged into the LINE port of the fax machine.
Nov 07, 2008 | Philips Office Equipment & Supplies
Certain songs not working
Make sure all songs are in the right format. If the headphones move even slightly , you will get crackles - this is a common problem with mp3 players - the headphone jacks are sensitive.
Jun 05, 2008 | Philips GoGear SA178 MP3 Player
Philips 170B lcd monitor
Crackling sounds are probably due to a couple of capacitors failing due to age, on the control board. (They can also "whine"). Should be easily replaceable by any experienced technician. Not a difficult job.
Nov 21, 2007 | Philips 170B4MG 17" LCD Monitor
Microphone
my mic was never working i bought it today and pluged it in to my computer an it's not works when i talk in to it and yes it is on
Aug 25, 2007 | Philips PH62080 Uni-Directional Microphone...
26 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
