Question about Panasonic Televison & Video
I have the panasonic 42 inch viera tv.attempting to connect a sound bar and the tv has to be about 9 years old. we cant figure out which port is the audio out or in.
SOURCE: cant get my viera linked panasonic to play through surround sound
I had the same problem, so i contacted panasonic, I am including the email they sent me.
For connections of audio, so that you can hear all tv audio through the
surround system, connect either an optical audio cable or red & white
analog audio cables from the tv to the home theater. If you are using
optical audio, there is a plug on back of tv labeled for digital audio
output and an input on the surround sound system. If you plan on using
analog red and white, use the PROG OUT red and white output jacks on the
back of the tv to the AUX input on the home theater.
For video connections, to get HD you will need to be using either HDMI or
Component cables. HDMI is the cable that will provided 1080p signal (the
best HD signal), but if the source does not output 1080p, then your tv
will not display 1080p. Most cable boxes output at 1080i or 720p when on
HD stations. This signal still provides great picture quality, but HDMI is
not needed to get these HD signals. You can use component cables for your
cable box and the DVD player output to the tv for video. HDMI might give
you a slightly better picture quality but the signal will be the same.
To make the connection, you will want to connect from the cable box to the
tv (component or hdmi). Also from the home theater system to the tv using
hdmi or the video cables from component (red, blue, & green cables).
We hope this information is helpful to you.
Thank You,
Panasonic Consumer
Posted on Dec 17, 2008
djchillsnyc
  • 152 Answers
SOURCE: panasonic viera tv won't turn on. Power light
hello, you have a either your su, sd or sc boards fualty and it is a driver sos1 thats what the manual reads the best thing to do if your not electronically inclined or able to fix it is to get a service manual and make sure it is for your specific model and size you will find what the 7 blink codes mean, on my side i have a 42 in pana the service manual for this set and your is similar so since it is not the same model i cant tell you exactly what the truoble is but your best bet is to find a service manual find the 7 blink fualt then without getting ripped off you will know what the service man needs to do if you dont know or cant replace the parts yourself that is besides having to download firmware from your computer to a sd card and update your set but you need to solve the blinking code first it may solve the entire issue. the tv should come on when you resolve the blink codes or replace the fualty board or boards
Posted on Oct 14, 2009
james tv man
  • 91 Answers
SOURCE: im trying to connect my boss sound system to my
You can purchase a brand "Gefen" optical digital audio to analog(rca output ) converter........they cost $70 to $90 just google that and you will find. If you are usind a cable or Satellite box,you could easily get the analog audio from those audio outputs to circuimvent the problem
Posted on Jun 15, 2010
walesarumi
  • 6993 Answers
SOURCE: Im trying to connect my
You will be needing a RCA Digital TV box converter or Digital RCA TV box converter. This converter will be the link between the Sound bar system and TV.
You should find this converter in any electronics accessories store within you vicinity or check walmart store close to you or order it online from walmart (But I don't recommend ordering online because of it's problem sometimes).
Check the back of the converter, it should have an input for Digital and RCA output and vise-a-vise.
Take a look at this Walmart link; http://www.walmart.com/ip/RCA-Digital-TV-Converter-Box-DTA800/8343230
I hope you understand the above.
Good luck.
Posted on Feb 26, 2011
SD Tech
  • 14553 Answers
SOURCE: Panasonic Viera 65 inch tv shut off, will not turn back on. Red light blinks 7 times.
Power supply or related to it.
Posted on May 26, 2012
4 inch horizontal gray bars left and right in hd mode, normal channel pic is fine
Please enter the TV's Setup menu and choose the "Other adjust" option. Then choose the "Side bar" option and use the right arrow to change the color of the side bars.
May 05, 2014 | Panasonic VIERA TH-42PX60U 42 in. Plasma...
5 year old plasma panasonic tv 42 " hdmi port not longer working, How to fix
hi you could try firmware update try the panasonic website hope it helps
regards
shaun
Nov 23, 2013 | Panasonic VIERA TH-42PX80B 42 in. Plasma...
I cant connect to the internet I have the cable going directly into the TV and I still cant connect to the TV can someone tell my why?
It is sad to say that Panasonic - 50" Model: TC-P50U50
lacks the ability to connect to internet.
It should have an Ethernet port.
Sep 29, 2012 | Panasonic Viera TCP50U50 50-inch Plasma TV
How to hook sound bar to panasonic viera 42 inch model TC-P42X5
The aftermarket audio/video cannot allow you hook your Tv and Dolbys stereos becauses of incompatibility issues.
Jul 24, 2012 | Panasonic Viera Tc-p42x5 42" Inch Flat...
The hdmi ports (2) do not work on this tv....how do i correct. I have connected 2 different blu ray players and a sony ps3.....the players would play audio but no sound. the ps3 - nada...
Tries tv unplug replug it back like an hour later for a tv resetting itself.The HDMI (2) port might be working again.Just used the PS3 game system only conennected it in the different tv ports of for the HDMIS ports provided by the tv.U know this wright?The PS3 game system play all this funsctions.CD-Audio only,DVD movies and old PS1 games,some PS3 system may,may not support and play old PS2 games,All Blu Ray movies and All PS3 Blu Ray games.
May 13, 2011 | Panasonic VIERA TH-42PX60U 42 in. Plasma...
I have a 42 inch panasonic viera th-p42g10a. i have dvd connected to av1, foxtel to av2, av3 is vacant. I have lost volume to both dvd and foxtel connections, yet i still have volume when watching normal...
This is a problem with your components. You can have the components replaced with a new set which may be expensive, or live to learn using av3 only with a switch system.
Mar 03, 2011 | Panasonic VIERA TH-42PX80E 42 in. Plasma...
Panasonic viera 42 inch plasma, comcast digital cable. screen goes totally green. switch to comcast guide, green disappeared and switched channels, then back to original channel and all was normal. it...
It sound like you are using a component video connection to the TV, which is of variable specification. Try a different type of video feed from your Comcast box
Jan 27, 2018 | Panasonic Viera TH-42PX80U Plasma TV
I cannot find the port to connect my wii sensor bar to a panasonic viera 50 inch
the senor connects to the game console and not to the T.V. itself... its colour coded, too... hope that helps... :)
Jan 02, 2010 | Panasonic Televison & Video
Panasonic viera doesn't display computer correctly
Right click onyour desktop and click properties (Windows XP) or personalize (Windows Vista).
Click the tab that says Settings(XP) or the link that says Display Settings (Vista)
Adjust your resolution by sliding the bar up or down until your dispaly matched the optimum resolution of your TV.
Dec 29, 2008 | Panasonic Viera TH-50PZ80U Plasma TV
Televison & Video Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
