Replace a thermo coupler for a emberglow fireplace model bvfm18nl
    Habit-Forming:
  • 90 Answers
Hi Josh. If you are going to do this yourself its not that hard, Whats going on, pilot wont stay lit. Allot of thermocouples are replaced when really all that is needed is to clean the pilot burner and orfice.If your pilot keeps going out, verify there is not some kind of a cut out switch that will drop the pilot out if it over heats or if its not venting properly.
Posted on Jan 03, 2017
Re the thermostat, we set it to the maximum temp possible, heater still not turning on
Possible thermo coupler is not working. Need to replace most likely
Thermo coupler is where the pilot light heats up to make the unit light up.
Nov 03, 2014 | Heating & Cooling
Lights but turns off in about a minute
It might have a built in thermostat that will light the heater when room temp falls below a certain temp. It should then relight and warm things back up. As long as the pilot stays lit it should work just fine.
Feb 08, 2014 | Emberglow Melbourne Oak 24 in. Vent-Free...
I changed the thermo coupler and the pilot light does stay lit but the burners won't light
If you are referring to a gas fireplace:
  • Make sure the pilot knob is turned from "pilot" to "ON" or it will never run.
  • If the pilot knob is "ON", and the pilot is lit, but the burner won't light, it could be a bad Thermopile. The thermopile is the other safety mechanism in the pilot assembly that controls the burner.
Dec 19, 2012 | Heating & Cooling
I NEED A SERVICE MANUAL FOR MY VERMONT CASTING RADIANT GAS STOVE MODEL RMV40
This should get you to the right manual for the rnv40 Vermont Casting located in conneticut 1-855-415-0071 8am to8pm EST
Nov 17, 2012 | Grilling
Kozy heat 932 fireplace, pilot goes out when i release the knob, I get 17.5 millivolts on the thermo coupler
the thermopile needs 600 millivolts from that for it to work, clean pilot recheak thermocouple if still low change it .
Oct 06, 2012 | Heating & Cooling
Skytech-3001 Thermo won't work
I am having some trouble! Mine became unconnected and I don't know how to reconnect. There is two wire, red and white, a box that sits inside the fireplace that has an on/off sitch and a box that sits outside the fireplace with a off/remore/on switch. How do I connect it back? Please help!
Jan 28, 2012 | Skytech 3301 Thermostatic Gas Fireplace &...
Have a GTI Insert Replaced the thermo coupler . Now the pilot light stays lit but when the fireplace starts it will only go for about 30 seconds then you hear a click and shuts down pilot and all.
It sounds to me like you have a bad flame sensor.Luckily most of the time they are pretty easy to change. If you have your manual it will show you the physical location of flame sensor. Usually 1 or 2 screws holding it in place. Remove screws and unplug wires to remove sensor.Install new sensor and hopefully you're in business. Thank you.
Nov 22, 2010 | Leisure HOMEPRIDE Electric Fireplace...
Thermo coupler on all the time, push in button, shuts off gas
Bad Safety valve. (valve w/red button). Thermocouple keeps the magnet open to keep pilot and so gas can flow to burner. Make sure pilot is clean and strong and hitting thermocouple. If it doesnt stay lit replace Safety Valve.
Dec 17, 2008 | Bakers Pride FC-616 Gas Single Oven
Heating & Cooling Logo
57 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
