Question about Vacuums
I need a replacement water plug for model s3501. Where can I get one?
Shark S3501 model mop heats up but no steam or steaming sound
you might try a teaspoon of vinegar in the water. It may have a small plug from hard water.
Mar 01, 2014 | Shark S3501 Steam Mop, Deluxe
S3501 manual
Tap water will work fine, however, if your water is known to have a high calcium or lime content, that will, over time, build up in the tank and nozzle areas of the unit. Distilled water will eliminate that problem if you use it exclusively.
Nov 02, 2013 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Took apart head of sharp steamer S3501; cannoat reassemble. Where can Iget a diagram of how to reassemble?
I just posted a video showing how I took apart and reassembled the S3501 to clear the heating core.
http://youtu.be/S4NglGXVv50
Nov 12, 2012 | Vacuums
Shark s3501 plugged
I had same problem with no steam... ready to throw in the dumpster!
I tried to it take apart. (kind of hard) still ready to throw it!
Then I thought about CLR!
I put about 1/2 cup in, turned on and let set for about 20 to 30 minutes.
I really did not think this would work but... Amazing! I actually got STEAM!!!!!!
Next I dumped out what was left, put in distilled water and ran for another 30 minutes on high.
Will use CLR again before final clean out and 2 full tanks of distilled water before I use again.
May 27, 2012 | Vacuums
Shark steam mop s3501 no steam
On these steam mops you have to use distilled water, if you use tap water and do not have
a water softner, the feeder tubes that pull the water to create steam will be reduced in size
and clog up. the only other option is to take it apart, and replace the hoses, i used some
small fuel line with spring clamps that i bought at an auto supply, it works! good luck!
Jun 26, 2011 | Euro-Pro Shark Steam Mop - Gray/ Purple...
No steam comes out . I have Model S3501 shark steam mop
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it maynot be getting steam to the head...
Euro-Pro Shark Steam Mop Problem
Here also is a link to get any of the Shark Manuals that you need.
heatman101
May 23, 2011 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Shark steam mop - Model S3501 does not produce steam. I checked the water after 10 minutes. It was completely cold. I primed the pump several times as suggested in the user instructions
heatman101
May 17, 2011 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Looking for plug for water go in s3501
Here is a tip that I wrote about how to find the parts you need for your Shark
How to Find Shark Parts and Accessories
heatman101
Dec 19, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Vacuums Logo
21 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
