Does Rabbit TV work on televisions - Televison & Video
    Top Expert:
  • Televison & ... Master
  • 75,178 Answers
Why not?
How to hook up T V ears on 32 " element tv ( elucfw329 )
every since television went digital, rabbit ears are hard to get to work. you will probablty have to get a digital converter box for it first, attach rabbit ears to converter box and box to television the same way you would attach cable
Jan 16, 2014 | Element Electronics FLX3210 32 in. LCD TV
No reception with rabbit ears
Check to see if you have the "Rabbit ears" plugged into the correct spot and you are on "Analog tv" if you are trying to use digital tv on "Rabbit ears" it can't send out a strong signal like the areal ontop of a house. You may need to get an adapter to broadcast a stronger signal but even better if you can connect to roof antena.
Oct 24, 2012 | Panasonic TH-42PX6U Plasma TV
Want to set this up without cable. Someone told me to go to "air" mode and add rabbit ears and this will work. I cannot find an air mode on this tv. How do you set this one up with rabbit...
You will once again, purchase a converter box to receive an over the air channel. I don't think you will have to really worry about using an over the air mode on the TV. It may be in the menu, but will work otherwise after being placed on channel 3 to receive through the converter box. The rabbit ears will be connected to the converter box itself.
Feb 13, 2011 | Televison & Video
Can't get any channels on Coby tv
Yes, you need an antenna -- rabbit ears or some other type of digital antenna.
Jan 28, 2009 | Coby TVDVD1350 13 in. TV/DVD Combo
We have a new HDLCDVD220 Sansui television. The rabbit ears antennae we were using on our old tv worked ok, but on this one. its awful. There is almost no color and terrible reception. We were told to get...
You mentioned rabbit ears for old tv, how old are the rabbit ears? Time and humidity will make rabbit ears lose connections internally. Also, if your old rabbit ears have the flat cable going to the tv you probably had to add a converter to go to the new tv. The flat cable will lose signal strength were ever the cable touches metal. Also the adapter will cause signal lose. The best bet is to buy an amplified indoor antenna. You also may try a paper clip and about 3to4' of small gauge wire put the paper clip (bend out to fit) into the center of the antenna in on the tv have the wire connected and let it hang or lift it to see how the picture improves. The problem with rabbit ears is that you have to use war time tactics. Crawl on your stomach and adjust to best picture, if you stand and adjust the signal is usually reflected off your body and will be nice until you walk away.
Jan 28, 2009 | Sansui HDLCDVD220 22 in. LCD TV TV/DVD...
SONY Trinatron 27" Gets No Reception
hello
What are you using to connect the rabbit ears to the tv, a 300 to 75 ohm plug assembly? it may have sprung the contacts in the rf socket of the tuner.
or The tuner has malfunctioned,
It may be switched to the wrong source as some tvs have more than one tuner input.
Thanks Guy9
Jul 08, 2008 | Sony FD Trinitron WEGA KV-27FS100 27" TV
TV won't work with rabbit ears
You must change the input on the system to be AIR/Antenna , the way it was before was set to cable/dish/DTV.
The tv sees the input different.
Jun 05, 2008 | Philips Magnavox 51MP392H Rear Projection...
Televison & Video Logo
26 people viewed this question
Top Televison & Video Experts
