Question about Candy Washing Machines
I need baby shower candy bags with a nautical theme in front of the bag
Im having a candy bar and I need bags ti fill with a natuical theme in front
  • 77932 Answers
SOURCE: airbags
If your Focus is a new model the passenger side airbag has a sensor that in effect weighs what is in the passenger seat, and will turn itself off if the weight is below a min, you will see an indicator lite up on the dash indicating this. If your Focus does not have this smart system then I recomment that you not tamper in any way with the passive restraint air bag system, to do so could cause grave personnel injury. Consault your local Ford dealer over the phone they will help.
Posted on Jul 23, 2008
  • 184 Answers
SOURCE: ford mondeo air bag
no you can't there is not a switch to turn of airbag like some manufacturers.
Posted on Feb 14, 2009
  • 3 Answers
SOURCE: Can i turn off my passenger airbag on my R reg Peugeot 406 LX DT
no you carn't im affraid.
Posted on May 18, 2009
  • 96 Answers
SOURCE: how to turn off passenger air bag
A handful of newer vehicles have sensors in the seat where you have to weigh so much in order for the airbag to work (light on the dash will tell you if it's off) or they have a spot for the ignition key in the dash so you can manually turn it off.. my next guess would be to either have them sit in the back or pull the fuse
Posted on Nov 26, 2009
SOURCE: How do you replace the bag on a Hoover Elite 200?
I had the same problem and just figured it out myself. Detach the clamp (attamched to the bag) from the handle. Then slide the bag out from the clamp either left or right. The cloth bag then opnes and you can replace the actual bag inside. Hope this helps.
Posted on Dec 06, 2009
How to get details about Nautical Themed Clothing?
There are many websites on internet which are offering information relating to Nautical Themed Clothing . This internet sites are specifically designed for those men and women who are on the lookout for Nautical Themed Clothing. To Learn More please see this website:
Sep 09, 2017 | GPS
How to Choose a Sleeping Bag
You would think that it's a simple task buying a sleeping bag, but there are many factors to consider before making a decision.
Firstly you have to figure out why you are buying your sleeping bag: Is it to have for sleepovers in your house, is it for the kids, is it for camping trips or serious hiking outings? All these questions will affect how much you should spend and the weight and quality of sleeping bag that you buy.
Different Shapes
There are 3 basic sleeping bag shapes:
Traditional mummy style which has tapered ends and traps the heat well.
Rectangular style which are bulkier and less heat efficient but they can be unzipped, so not only can they be used as a blanket but also give more space to move around in.
Semi-rectangular style which is quite a good compromise between the 2 options above.
Choosing a Fill Material
There are 2 main types of fill material for sleeping bags; Synthetic or Down. Here are the pros and cons of both types.
Synthetic: These sleeping bags weigh a lot more than down filled bags and are bulkier but they cope much better with being wet as they retain their insulation well. They also dry quickly once wet and have better anti-allergic qualities. Finally, they usually cost a lot less, so if you are camping on a budget - this might be the filling for you.
Down: These bags are made from the fluffy undercoating of geese and ducks. It's a natural material as opposed to a synthetic one and it's really good at keeping you insulated and warm, so it's a good option if you are camping in cold weather locations. The quality varies depending on the bird the down comes from and there are measurements that tell you the quantity of down used in each sleeping bag. These bags are really compact and light but if they get wet they take forever to dry.
What else? Other things to consider when buying a sleeping bag are; Whether to get a lining with it which helps avoid the need to wash your sleeping bag too often. Also a sleeping bag mat which goes under the sleeping bag and rolls up very compactly can make all the difference to your sleep. Read the washing instructions to make sure you can put it in the machine or dryer. Enjoy your sleeping bag.
on Aug 20, 2012 | Camping, Backpacking & Hiking
How do I take apart a moen shower head?
You can remove the head from the shower arm by taking a crescent wrench. Put it on the flat sides of the nut on the showerhead and unscrew it counterclockwise. There is no way to take apart the Moen showerhead. If the reason you want to disassemble the showerhead is to clean it because it is clogged, disassembly is not needed. Just fill a Ziploc bag with a 50-50 solution of vinegar and warm water. Place the bag onto your shower head so it is fully immersed in the solution. Use a rubber band to hold it in place. Let it soak overnight and then take a toothbrush to any of the white scaly matter that might remain.
Aug 10, 2015 | Moen Home
I have xmark walk behind s series the lawn clipping bag falls of constantly
Have you tried to help with the load on the bar the bag hangs on? If there is a way to attach a bungee from the lower part of the bag to the bar, it ought to help with the weight as it fills.
Oct 18, 2014 | Garden
Where can I get an eco-friendly bean bag chair?
The ecosak website has some really nice organic cotton bean bags or you could try the Kilpatrick design website that fills their bean bags with more eco-friendly reclaimed shredded foam.
Sep 13, 2012 | Furniture
The handheld sprayer on my Eurostream NSF 61/9 kitchen faucet will only spray. It will not go to a full stream of water when the faucet is turned on. I have taken it apart and tried to get the spring in...
if the sprayer is old it may need to have some lime or calcium build up -Just fill a small plastic bag half full with white vinegar and attach the bag over your showerhead with a rubber band up side down of course -Leave the bag in place for an hour or two. Then remove the bag and scrub the shower head with an old toothbrush or rag. Your shower head will look and should function like new if that is the problem
Nov 08, 2017 | Home
We bought a Quinny Buzz travel system back in 2006, it is still in good condition two babies later as both our kids are not pushchair babies however I'm having a third baby and did notice that while using...
Hi this usually only happens if you have bags on the handle bar, they can not take the weight mine did the same I bought those clips thinking oh!!!! very handy, but as soon as I add bags that happened.
May 06, 2010 | Quinny Buzz Jogger
No suction with my Hoover Breathe Easy Upright
If the bag fills up with air it should be sucking since the air that fills the bag is blowing air into the bag thus the dust gets carried along with it. However it should be easy to inspect the hose by taking it off by either removing screws *dont lose them, by the way! And looking at the dust channel after the beater bar. Either way something is clogged if the dust bag is filling up with air. Also check that the filter underneath the bag or beside the motor is completely clean.
Feb 20, 2009 | Hoover Breathe Easy U5250-930 Bagged...
How to fold bugaboo camaleon to fit the bugaboo travel bag
Put the seat in first (upside down, with the back of the seat facing up). Then put the collapsed chassis (with the large rear wheel taken off) on top of the seat. Make sure the front wheels are facing up. The handle bar goes towards the skinnier part of the travel bag.
Jun 21, 2008 | Bugaboo Cameleon Jogger
Washing Machines Logo
78 people viewed this question
Top Candy Washing Machines Experts
Gerry Harvey
Gerry Harvey
Are you a Candy Washing Machine Expert? Answer questions, earn points and help others
