Question about Crafts & Hobbies
Cricut will not power on. - Crafts & Hobbies
Cricut machines power supplies
18 volts is the voltage and the thing that is most critical to stop the machine burning out.
The 'A' - amperage is the force behind the electricity, 2.0 is a sort of fairly strong person 2.5 amps is a muscle man.
If the piece of equipment needs a muscle man to move it and you use a weaker person, it may not move quite so fast. Good analogy?
Anyway, .5 amps is not going to make that much difference.
Jun 26, 2016 | Cricut Expression Cutting Machine
My cricut wont turn on
Hi, My cricut expression is more then 5 years old. I used it one day and the next day I would not come on (it dose Nothing at all). I brought a new power cord from cricut and still nothing. I'm unable to buy a new one Please help if you can. Thanks!!
Jan 26, 2014 | Cricut Expression Cutting Machine
Cricut mini flashing red light
1-Open Cricut Craft Room with circuit on and flashing green/red
2-Hold power & feed button together until both are solid green
3-You'll be prompted to update firmware
4-Press & hold two buttons again (keep holding)
5-initiate firmware update
6-Let sequence go until 99% ...you may hear a sequence of beeping, don't be alarmed
7-Release buttons
8-You'll be prompted to restart your machine
9-Unplug all plugs from Cricut
10-Wait 30 seconds
11-Plug in both cords
12-Power on Cricut
13-Light should be solid green
14-Press OK on Craftroom prompt on computer
15-Done
Jan 03, 2014 | Provo Craft Cricut Disney Font Cartridge
Cricut expression 2 has no power, will not turn on
Any resolution to this issue? I like stone234 have narrowed it down to the cricut not getting power past the power board. I tested the two prongs that feed the red and black power for the main board and no voltage. Cricut Exp 2. Powered on as soon as I plugged it in. Plugged in usb to computer, I didnt have the software so i searched for it then started downloading it and noticed the screen on the unit was frozen. unplugged it and after plugging it back in it wouldn't power back on.
Nov 05, 2011 | Cricut Expression Cutting Machine
I have the cricut jukebox but no instruction manual. Where can I find one?
http://content.cricut.com/c/downloads/JukeboxManual.pdf
There you go :D
Mar 01, 2011 | Computers & Internet
My cricut expression keeps turning on and off. Resetting does nothing since it won't stay off or on long enough to actually reset. Any ideas?
I would contact cricut because you may have a defective machine. I had an expression and cut one thing then it froze. We did the reset and that did not resolve the issue. Cricut had me send my machine back and they shipped a new one. Mind you they will put a charge on your credit card only to protect themselves. You just ship yours to them the way they tell you in the one you receive. Let me know if you do not have their contact number.
Feb 16, 2010 | Provo Craft Cricut Disney Font Cartridge
Cricut makes loud grinding noise and will not turn roller bar
My wifes' cricut seems to have had the same problem. Try turning off the power, then manually slide the cutting carriage to the left look inside to the right. you should see a red button pull on it until it clicks. power up the cricut and see it it works. it solved the problem for my wife.
Jan 02, 2010 | Provo Craft Toys
I just opened the box from a TV ad purchase of the cricut. When I turn it on the carrier moves to the right and makes a horrible noise. Nothing will work.
Yes, the carriage does move to the right and it makes a funny noise as it moves. The cricut then should light up with display and power light. If yours is not then I would contact Cricut as you may have a defective machine. Just know they will put a charge on your card to ship another machine to you and will remove the charge when you ship your machine with issues back to them.
Dec 27, 2009 | Provo Craft Cricut Disney Font Cartridge
Jpeg file onto a cricut
Cricut does not accept jpegs. They use their cartridges that come with the machine and others that you can purchase. However if you have Cricut Design Studio you can design your image with the cricut. Any further questions feel free to ask.
Dec 02, 2009 | Provo Craft Cricut Disney Font Cartridge
Cricut Expressions Machine error
  1. Make sure your cricut is off when you plug it into your computer via usb.
  2. Make sure your usb cable is plugged directly into the machine, and not to a usb hub.
  3. Start up the DS Once the DS is fully loaded, choose HELP > UPDATE FIRMWARE.
  4. On the cricut machine, hold down the STOP button. Keep holding it down and briefly hold down the power button. Keep holding down the stop button and in about 3-5 seconds, you will hear a beep. That means you are good to go.
  5. On the "update firmware" screen on your computer, select the model you have and then click "begin updating now"
  6. Go and read a magazine or make a cup of tea because it takes a while to update. If it goes really fast (no matter how cool your computer is) it means it did not install properly and you will probably have to do it over again.
Hope this helps you.
Jun 10, 2009 | Provo Craft Cricut Disney Font Cartridge
Crafts & Hobbies Logo
405 people viewed this question
Top Crafts & Hobbies Experts
R.A. Ellis
R.A. Ellis
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Craft and Hobby Expert? Answer questions, earn points and help others
