Question about Sewing Machines
Bobbin thread will not catch. Was sewing fine. What do I do now?
  • Sewing Machines Master
  • 11,774 Answers
Try a brand new needle--old damaged/bent needle will frequently fail to connect with bobbin thread.
If that does not resolve the issue, most likely the machine has been knocked out of time--most often occurs when the needle hits a pin or is deflected by thick fabric so it hits the needleplate or something in the bobbin area. You can search the internet for sewing machine timing or take it for service.
My bottom thread wont pull out once the cover is closed and the thread is pulled through and ready to sew.
If the top thread is not pulling up the bobbin thread, is it actually catching the bobbin thread? If not, then the machine may be out of time. Search for sewing machine timing or take it for service.
If it catches the bobbin thread but then the bobbin thread is difficult to pull, then possibly there is a snag somewhere that is catching the bobbin thread, the bobbin tension needs adjustment, or the bobbin case is incorrectly threaded.
Nov 01, 2017 | Sewing Machines
Why does bobbin thread keep snagging?
increase the needle thread tension up a bit as it is too loose to pull the bobbin thread up properly
keep adjusting until both threads are at the middle of the materials being sewn
Mar 25, 2016 | White Sewing 1418 Mechanical Sewing...
Won't catch bobbin thread
hi Shauna.
this is all i could find out from the internet.
Make sure the presser foot is up when seating the thread through the upper tension. Now, it's time to draw up your bobbin thread. Turn the hand wheel (TOWARDS YOU ONLY, never turn the hand wheel away from you) and hold the needle thread lightly. Tug on it as the needle goes down and then comes up again.
if this is off no help to you go to this link and see if its any good to you.
Frequently Asked Questions Singer Sewing
or this one.
Sewing Machines Won catch bobbin thread Google Search
Dec 13, 2017 | Sewing Machines
Pfaff 1221: was sewing fine; now top thread doesn't catch bobbin thread
try rethreading the machine top and bobbin
make sure the bobbin is inserted correctly into the bobbin case
and if that doesn't help, the problem could be a timing issue and would require a sewing machine shop
Apr 15, 2015 | PfaFF Sewing Machines
I have an 8700 juki industrial machine and as I'm sewing the thread will not catch on the bottom bobbin. I'm frustrated.. It was fine the last time I've used it.
machines do not just go out of time. Is the top threaded correctly. did u miss threading thru the take up arm or take up spring change needle too.
Nov 26, 2012 | Juki Sewing Machines
I have a brother pe 770 and the bobbin will not catch the thread. The thread will wrapped and tangled up around the bobbin case and bobbin, but will not catch the bobbin at all. I chcked the needle, it is...
You need to sew the first stitch slowly. Lower the needle by hand and take up carefully. Pull the needle thread up and the bobbin thread should be caught in the formed loop and come with it. Pull them both to the back of the machine and sew.
Dec 14, 2010 | Brother PE770 Computerized Sewing Machine
How do you load the bobbin properly?
Well you may please follow the steps below -
1. Remove the bobbin from the sewing machine. Note: whether you have a drop-in, front or side-loading bobbin on your sewing machine. A drop in bobbin will load from the top, may be via a removable bobbin case cover near the machine-fed dogs. A side or front loading bobbin needs to be loaded into a removable bobbin case under the machine.
2. Choose the right size bobbin for the sewing machine.
3. Wind thread onto your bobbin. Your sewing machine should have a standard thread spool to hold the thread and a short, squat post wide enough for a bobbin.
4. Put the thread and empty bobbin into position on your sewing machine. Wrap the thread around the bobbin to start it. On most machines, disengage the needle by turning the smaller hand-wheel on the machine toward you. Push the bobbin post into position, securing the bobbin into place. Press gently down. Thread should begin to wind neatly onto your bobbin.
5. Break the thread, push the bobbin post back into an inactive position and remove the bobbin. Tighten the hand-wheel. Thread your sewing machine again if necessary before loading the bobbin.
6. Remove the bobbin case cover and put the bobbin into position. The thread should slide through a catch on the bobbin case and up through the cover.
7. Access the bobbin case for a front or side mount bobbin. Lift the catch and remove the removable bobbin holder. Put the bobbin into the holder and run the thread through the holder, bringing it to the front. Lift the catch and slide the bobbin holder back into the case. Hold your needle thread gently forward with your left hand and turn the hand-wheel. The needle thread will pass down into the machine and catch a loop of the bobbin thread. Pull this loop up and slide both threads to the back before beginning to sew.
Good Luck!!
Thanks for using FixYa!!
Sep 22, 2010 | Euro-Pro Shark 60 - 384
THE SEWING THREAD WILL NOT CATCH THE BOBBIN THREAD
the needle is not catching the thread on the down stroke have you got enough thread out on the bobing for the needle to catch
Jul 22, 2010 | Elna Heirloom Edition 6005
In order to see whether or not my euro-pro 9110 had a timing issue, the service rep had me change out the needle (making sure I was using anything but a Singer brand needle--they do not work in these machines). I re-threaded the needle, took out the bobbin casing and the plastic ring encasing the bobbin, then lowered the needle to see if the hook on the metal ring holding the bobbin actually catches the thread on its own. If it doesn't catch, it's a timing issue and needs repair. They can walk you through this process of troubleshooting and set up repair if need. Call Eruo-Pro's customer service center for sewing machine service and repair at 800-798-7395
Apr 17, 2008 | Euro-Pro 8260 Mechanical Sewing Machine
Sewing Machines Logo
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
