Question about Furniture
Wine cooler,Allavino vwr1601, will not turn on, simply stopped working. no power at all to lights, motor.
4 Suggested Answers
  • 159 Answers
SOURCE: 2 mos old. simply stopped working. no power at all to lights, motor ,etc.
check if you get power by the motor if no power change the thermostat
Posted on May 16, 2009
DrakeTech
  • 61 Answers
SOURCE: wine cooler just stopped working. light will come
Try disconnecting all power to the unit for about 10 mins, and turn it back on to see if the compressor will kick in. Also check your temp settings and make sure they are properly set. If that doesnt work, you might have a dead compressor which a tech can look at and verify.
DrakeTech.
Posted on Mar 01, 2010
  • 472 Answers
SOURCE: wine cooler has no light or power working it
you want to check power coming into unit... do you have power at the switch... there was alot of issues a ton etime with there power control switches and thermostats... check incoming power to unit and see if the switch has failed... also these units have small controls on them that will fail from time to time. you are going to have to see where power has failed at.
Posted on Jan 03, 2011
Nothing works except the upper lighted panel in front of Allavino wine cooler. What might be the problem, and Can I fix it?
that one in the picture looks like it has a code. it is usually the cooling sensor.if it run on compressor it need relay overload and sensor check.
Apr 20, 2015 | Furniture
N'finity wine cooler
call the repair man if probably needs recharged with freon
Feb 16, 2015 | allavino MWR-1682-BL-C 170 Bottle...
Vinotemp wine cooler just stop working.
Ok check the power supply input. Assume you have do e that and all ok. More than likely it could be a thermostat or compressor gas leakage. Has the compressor been running more than usual before it gave up working. Check for rust on the internal coils as sometimes they fail. Depending on what you paid for the wine cooler it may be cheaper to simply replace it. Can highly recommend Delongi 145
litre bar fridge, after replacing several cheaper brands and it is very reliable and cools really well though they are not at the cheap end of the market. You get what you pay for with appliances. Best of luck resolving the problem but if the wine cooler no longer is getting cold but the compressor continues to run, you can bet that it's out if gas from a leak in the internal pipe work and generally not worth attempting to either locate and or repair.
Apr 28, 2014 | VinoTemp (VT60GNV) Wine Cooler
Compressor seems bad
HI sally.well wine coolers r not rocket science.your local engineer should be able to at least diagnose the problem...lets c if u can do it ok?(still getting power )u mean light comes on or u mean it runs but dont get cold?well haier is not the best but if it's done 7 years is not bad:).ok...1-check if it makes any noise or is completely quiet.if no sound feel the motor (compressor).hot or cold.if cold it could be the thermostat or motor.if hot running or not it could be refrigerant or motor.needs visual.hope this helps.ALI
Jul 09, 2012 | Haier HVFM20ABB Wine Cooler
Wine cooler has no light or power working it simply shut down
Jan 03, 2011 | Avanti EWC28 Wine Cooler
Haier HVTB18DaBB Wine Cooler has stopped working. It was working yesterday and today it isn't.
check if it still has power, if it does check the back of the cooler to see if the fans have stopped running, you might need new fans.
Oct 03, 2010 | Haier HVTS18DABB Wine Cooler
Wine cooler just stopped working. light will come
DrakeTech.
Mar 01, 2010 | KitchenAid KUWS246E Stainless Steel Wine...
May 13, 2009 | Avanti WCR683DZD Stainless Steel Wine...
Furniture Logo
142 people viewed this question
Top Furniture Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a Furniture Expert? Answer questions, earn points and help others
