Question about Frigidaire Dryers
Frigidaire model ffle1011mw serial fe44904115 dryer won't turn on
  • Frigidaire Master
  • 5,323 Answers
Electric dryer no start does nothing
Check dryer Terminal block prongs both outside prongs should give combined 220, and 110 each if u check 1 outside & 1 center (ground) prong. Also check house electrical outlet for full voltage.
CHECK THERMAL SHUT OFF THERMOSTAT USUALLY LOCATED ON THE BLOWER. for OHMS or resistance with a meter. Should show a closed circuit. Ohms WHEN THIS FUSE BLOWS IT WILL SHUT DOWN EVERYTHING.
NEXT Test the PUSH start switch with meter for OHMS. Should show OHMS when pushed in or on start, and no ohms or infinity when in off position.
If you hear a humming/clicking sound from motor area you more than likely have a bad motor.
Try this test out to see if u have weak windings or relay/capacitor on motor.
Open the dryer door and turn by hand the drum while machine is on ON position. And you or someone else presses the door engagement switch in. If it starts up then u have bad windings
Another thing to check is the belt safety switch. With a multi meter.
Especially if u just replaced the belt. The belt safety switch is attached to the Tensioner and motor. IT LOOKS LIKE A DOOR SWITCH SOMEWHAT a little black pc of plastic with 2 prongs going into it. Sits at bottom of motor. Under the Tensioner. Attach meter clips to the 2 prongs on switch, Then when the little white push button is pressed in it should show continuity and none when released.
Lastly check ur DOOR SWITCH for continuity with a meter when the button is pushed in the (on/Door closed position,) it may have gone bad.
https://www.youtube.com/watch?v=sTRP6kHqAFs
Hey GOD IS GOOD !!!! WHICH IS WHY MY ADVICE IS FREE
Need to replace belt
Search Results
    How to repair a KENMORE double decker washer&dryer ...
    ? 4:59
    www.youtube.com/watch?v=Rc_ZGugYBTY
    May 31, 2014 - Uploaded by MrProductionist
    How to repair a broken dryer belt from a Double Decker Washer and Dryer. ... I have a Kenmore stackable Washer-Dryer, and the dryer belt is ...
Oct 21, 2015 | Frigidaire FFLE1011MW White Washer/Dryer...
READ FRIGIDAIRE ERROR CODES
Hello Rob Olsen, I appreciate your inquiry!
I understand that you would like to have information upon reading error codes for your Frigidaire laundry center. I was able to locate a manual that has information regarding error codes for your laundry center. I hope this information is helpful to some degree. -Matt
Frigidaire Manual Search Results
Nov 09, 2014 | Frigidaire FFLE1011MW White Washer/Dryer...
FFLE1011MWO will not heat
Good Morning Steven,
I understand that the dryer on is not heating on your Frigidaire laundry center, model# FFLE1011MW0. Before calling a technician, check the following solutions:
    1)Make sure that the two house fuses your dryer is attached to. If one of the two fuses is blown, the drum may turn but you won't receive any heat.
    2)For Gas Models Only: Make sure the gas supply valve is open, make sure there is enough air supply to support the burner flame, and make sure the LP gas supply tank is not empty or there has been a utility interruption of the natural gas.
    3)Check the lint filter, the ducting that leads outside, as well as the outside vent for any lint that might be clogged inside. This can cause a no heat issue, due to your dyer is not getting a good air flow.
    4)For Electric Dryers Only: Make sure your dryer is connected to a 208 volt circuit.
    I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your dryer status has changed successfully. Hope this is helpful.
    -Best Regards-
    WP
May 29, 2014 | Frigidaire FFLE1011MW Electric...
Frigidaire stack dryer turns off after few seconds
CHECK MOISTER SENSOR AND OR THERMISTOR. THERMAL CUT OFF AND CYCLING AND HI LIMIT THERMOSTATS
Feb 15, 2014 | Frigidaire FFLE1011MW Electric...
WASHER WON'T START
Thank you for your inquiry, friend!
I see that you are having trouble with your Frigidaire washer not starting. This sounds like a possible problem with your control panel or keypad. You may need to disassemble the washer in order to pinpoint the possible problem this is not a simple DIY job. I would recommend seeking assistance from a professional technician for proper diagnosis and repair. This will help you avoid future issues as well as possible multiple part purchases. I hope this information is helpful. -Matt
Jan 06, 2014 | Frigidaire FFLE1011MW Electric...
My Frigidaire Affinity dryer won't tumble; it just hums
Thats not even a question Stupit!!!! A good hummer is good for you ********!!!!
Aug 04, 2012 | Frigidaire GLEQ2152ES Electric Dryer
Frigidaire model FDE336RES2 makes a squealing noise and won't turn with a full load in dryer.
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 03, 2011 | Frigidaire Dryers
Dryer will not run
dryer starts sometimes if you hold in button. frigidaire gallery series model # GLEQ942CSO. serial # XD350164472. flat panel control board.
Mar 31, 2008 | Frigidaire GLEQ2152ES Electric Dryer
Dryers Logo
43 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
