Howden washing machine doestnot heat the water
  • Washing Mach... Master
  • 5,323 Answers
THE MACHINE DOES NOT HEAT THE WATER IT USES HOT WATER FROM THE HOUSE OUTLET. I SUSPECT YOU NEED TO CHECK UR WATER TEMP SWITCH AND UR WATER INLET VALVE.
Howden washing machine doestnot heat the water - 26422920-mnt2j1hw3gokxjshdcwwfxa2-1-0.jpg
Howden HJA8552 does not heat water
This is posted in the wrong category as a Howden HJA8552 is a washing machine.
Jan 01, 2017 | Water Water Heaters
Washes indefinitely - water does not heat.
perhaps a call to a service man locally will be your best choice . none I have ever worked on had heating as an option .
Jun 02, 2015 | Bosch Washing Machines
User manual for Howdens HUA8513
Most manuals can be found on line.
Oct 03, 2014 | Washing Machines
Washing machine not heating
PLEASE CHECK THE WATER COMING TO THE FRONT WASH FRONT LOAD WASHER DONT HEAT THE WATER IT AS A HOT AND COLD WATER VALVE CHECK WATER VALVE
May 02, 2014 | Hotpoint WMA50 Front Load Washer
Changing washing machine heating elemant
washers dont have heating elements, they use hot water from the hot water tank, most likely clogged screen at either end of the hot water hose, replace or clean screen(s) check for screen at water valve, bad,weak or burned solenoid on water valve, replace valve, reason wash cycle is long----- water restriction during fill and rinse cycles they are controlled by the water level switch
Jul 09, 2012 | Washing Machines
I am looking for a copy of the user manual for the Lamona Integrated Washer Dryer model number HJA8704 but am struggling to find it online. Would you be able to help please?
Sorry, this forum is not able to supply any type of manual, installation instructions, electrical or schematic diagrams direct; it's just made up of ordinary guys and gals, probably at home and from all over the world, with experience of addressing problems and giving guidance for free on the web ;-0)
You will need to type into your search engine/web browser '(make model number) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount.
You could also try the manufacturer's web site direct ;-0)
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C.
(this is my standard reply but I've just followed my own advice and found this!
http://www.inter-spares.co.uk/howden/howden-washing-machine/hja8703/instruction-manual-1-2-3-4-5-6-7-8-9-10-11-12&usg=AFQjCNHicY59t2EHXq15qkInEBscfeGeZw)
Jun 19, 2011 | Washing Machines
We have no hot water boiler kaput - will washing machine heat water (hot wash) if only cold water is going into inlets.
Yes. The washing machine contains heating element and a thermostat. It will try to get water from both hot and cold sources and will heat the water to the required temp.
Mar 07, 2011 | Hotpoint Washing Machines
We have a howden hja8513.the problem is the machine will not drain or spin.where is the drain on this model?
the washing machine is not heating the water in any wash programme.
what is the cause and how do i fix it.
Dec 02, 2010 | Washing Machines
Cold water fill does it heat to temputure requied?
If your washing machine has inlets for both hot and cold water, you should connect both if possible. If you can only connect cold water, the washing machine will still work and heat to the required temperature, but it will need to heat the water in the machine, so the wash cycles will take longer and it will use more energy.
If connecting a hot and cold fill washing machine with cold water only, you will need to connect a Y-Piece for it to work:
The tail of the "Y" attaches to the cold water valve on your pipework. You then attach both hot and cold water hoses to the branches of the "Y" and connect both hot and cold water hoses to your washing machine.
Please post back if you need further assistance.
Regards,
BElectric
Nov 25, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
Does the machine heat up the water
If you have only a cold water feed then all of the washing will be in cold water. Dishwashers heat up the water, but clothes washers do not.
Feb 10, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Washing Machines Logo
22 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
