My Toyo Stove laser 56 thermostat changes setting. I set the temp at 69, leave the room and when I return it is at 76 or so. This has happened on a number of times.
    New Friend:
    A rookie expert who has answered 20 questions on their first day.
  • 20 Answers
May be the thermostat is defective
I have a Skytech 3301 for a propane stove with some thermostat problems.
Great question! It sounds to me like the Skytech's swing temp setting may be out of whack.
Here is a quick link to the product page with a link to the owner's manual at the bottom if you need: Skytech 3301 Fireplace Remote.
Below is an excerpt on how to check and modify the swing temp settings for the Skytech 3301. (I apologize if the copy/paste formats poorly).
The Thermo Mode on the transmitter operates the appliance whenever the ROOM TEMPERATURE varies a
certain number of degrees from the SET TEMPERATURE. This variation is called the "SWING" or
TEMPERATURE DIFFERENTIAL. The normal operating cycle of an appliance may be 2-4 times per hour depending on how well the room or
home is insulated from the cold or drafts. A smaller "swing number" increases the number of cycles so the room temperature is more
constant. A larger "swing number" decreases the number of cycles, which saves energy, in most cases. The factory setting for the "swing
number" is 2. This represents a temperature variation of +/- 2
F (1
C) between SET temperature and ROOM temperature, which determines
when the fireplace will be activated. The "SWING" number values are:
1=+ 1
F (.5
C), 2= + 2
F (1
C) and 3 = + 3
F (1.6
1. To change the temperature "SWING" setting (1-3), press the TIMER/TIME and DOWN buttons
simultaneously to display the current "SWING" setting in the SET TEMP frame. The letter "S" will
display in the ROOM TEMP frame on the LCD screen.
2. Press the UP or DOWN button to change the temperature differential or "SWING" (1-3). See above
for 1-3 "SWING" temperature valves.
3. To store the "swing number press the SET button or allow 15 seconds to lapse, and the new "swing
number' will be automatically programmed.
The operation of the factory set "THERMO SWING" can be checked by adjusting the SET TEMP 2
F above or below the room temperature.
This will cause the system to turn ON or OFF. Normally the system will only respond to temperature changes every two minutes. Manually
changing the SET temperature will activate the system in less than 10 seconds. IF the "SWING" is changed, then a new room temperature
differential will respond. Factory setting of "SWING" temperature is 2
Jan 17, 2013 | Skytech 3301 Thermostatic Gas Fireplace &...
The thermostat setting temperature of my Laser 56 Toyostove will suddenly jump up to a high setting (86) which in turn causes the stove, when not operating, to start up and/or causes the stove, when...
The reason I asked was to see if it is a power supply problem. If the setback had been set on 86 I would suspect you were having power fluctuations causing the heater to go the setback temperature. I will give this some more thought and post something else soon.
Sep 11, 2010 | Rinnai Toyostove Direct Vent Heater: Laser...
Have a new ac system installed thermostat is set at 76 shows room and setting the same all the time shouldn't the room temp rise before unit comes on.
Yes the temp should rise 2 to 3 degrees before the unit comes on, This is called the temp swing, try lowering the temp setting and wait for the temp to drop, then set it back when you want it.
Aug 21, 2010 | Computers & Internet
GE AGM08LJG1 window unit: digital temp increases on its own. Ex: when set to 65 degrees (and timer set to turn the unit off in 4 hours), return to the room 2 hrs later and the digital temp reads 69. What...
its telling you the room temp that is been sucked into the evaporator.its normal for this to happen.once you set the temp you stays there untile you change it.but its all good.
Jun 09, 2009 | GE Deluxe AGM08LJ Thru-Wall/Window Air...
Exhuast smell(odor)
If your Laser 56 is giving off fumes it is probably coming from the igniter gasket and the igniter guide gasket. The igniter gasket has broken and needs to be replaced with the new style. The new style cost about $12. The guide gasket is the fiber gasket around the hole the igniter goes in. It has seperated and all you have to do is smash it back together. If you have high temp silicone or furnace cement, you can use either to seal the crack. Any toyotomi dealer can get you the new igniter gasket # 17185580.
Good luck,
Tom Hawkins
Feb 28, 2009 | Rinnai Toyostove Direct Vent Heater: Laser...
The thermostat does register the right temperature.
Your heater might be on the Auto settings .. it will turn on and off itself once the pre set temp is reached ...
Jan 05, 2009 | Lasko 5365 Ceramic Compact Heater
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
