Question about Coffee Makers & Espresso Machines
Coffee set tomax strength but when machine makes coffee its weak
  • 79 Answers
SOURCE: Weak Coffee
I don't have any first-hand experience with this brand. However, it sounds like the coffee grounds are being partially bypassed by the hot water.
One clue that will help diagnose this is: does the carafe fill up to the amount of water that was in the reservoir? If not, that suggests not all the water is being cycled through.
See if the reservoir is completely empty at the end of the brew cycle. Look for any coffee-colored water in the reservoir at the end of the cycle. That would indicate, to me, a defective feed valve in the water path.
Posted on Apr 01, 2008
mirran
  • 515 Answers
SOURCE: Coffee too weak
What kind of saeco incanto do you have?
Posted on Jul 10, 2008
  • 60 Answers
SOURCE: weak coffee
It sounds like you may have lost the sprayhead. It is under the brew basket (above the place where you put the basket with the filter and the coffee). Sometimes they get loose and you don't realize it and it can fall in the grounds and get tossed out after brewing.
Posted on Jul 18, 2008
ginko
  • 19396 Answers
SOURCE: weak coffee
Basing on personal experience (you can find more on Google probably), solutions are:
On percolated (filter) coffee machines:
Check water temp, if water temp is insufficient , most common is scale heating element , faulty element, faulty thermostat.
Check if water is dripping right at the center of the filter, if it is dripping on one side because the orifice is clogged, that can result in weak coffee.
Coffee blend not well distributed on filter basket.
On Espresso machines:
Check water temp, same as filter coffee machines (thermostat element, scale on heating chamber).
Ensure that coffee is filled correctly in the filter cup (fill at level), and well pressed.
Ensure that the coffee mixture that you are using is not too coarse, buy the apposite one for espresso.
Ensure that you are not leaving the machine brewing for a time that is too long, and Italian coffee cup is very small, approximately one regular shot.
On the hob moka pots (espresso, Moka and Bialetti type):
This are the trickiest ones, you need art and practice to get a good espresso with a Moka, but when you learn, the result is better than what you may get with an home electrical espresso maker.
The frame on the hob must be not too strong, and the mixture coarse but well pressed, with water at level tag, or you will get a weak coffee.
On Mokas a good strategy is keeping hob at minimum, and turning up the flame at top when coffee starts coming out.
French and turkish cafetieres:
Ensure that you put enough coffee, water hot enough, and that you left the infusion enough time to get a strong coffee.
Note: insufficient pressure and clogged lines on electric machines never give you a weak coffee, exactly the opposite.
Not pressed mixture always gives weak coffee, but too much pressed mixture may give you coffee with bad taste.
Posted on Apr 01, 2009
SOURCE: My Keurig B60 is Suddenly Brewing WEAK Coffee
I don't have a solution but have just experienced the same problem and am baffled. I am using the same beans same grind. In fact using the exact same grind it went from great one day to weak the next day.  I always run it for 15 - 16 secs to get the shot and that hasn't changed. Pressure and temperature appear fine. I cleaned the top of the top filter which was a little dirty but not seriously bad - no change. The coffee flow which is normally chocolate coloured to start with is just mid brown.
Posted on Feb 28, 2010
Why wont my keurig maker make a strong, dark cup of coffee like my regular coffee maker
Make sure both nozzles are clean. One is in the top and one in the removable bottom. Ream them with a paper clip to make sure they are clear.
Sep 07, 2014 | Keurig B60 Coffee Maker
Weak coffee
better make descaling proces on your machine!
Oct 15, 2013 | Saeco Magic Comfort 103467 Espresso...
Coffee to water ratio
Weak coffee is 2 tsp per cup strong coffee is 3 tsp or 1 Tbls per cup. (3 tsp per Tblsp) 32 Tablespoons = 2 Cups, there are 4 Tblsp per 1/4 cup. If you're confused ( I am from reading my answer) Use 1 cup for weak coffee, two cups for strong or 1 & 1/2 for regular strength coffee. Hope that helps!
Apr 11, 2010 | West Bend (58036) 36-Cup Coffee Maker
Coffee is too weak
I just spoke to someone at customer service. My coffee has been weak and kind of thin. We had the Superautomatica by Saceo for years and I remembered the coffee being richer.
Anyway! The person suggested that I adjust the grind but slowly. So set it to the coarsest setting, brew 2-3 cups. Then put it to the 2nd-coarsest setting, brew 2-3 cups. To the third, brew 2-3 cups. To the forth, brew 2-3 cups. Etc. Until you're at the finest grind setting. Again, brew 2-3 cups. An awfully sensitive machine. It seems to have worked although the last few seconds of brewing continue to be a kind of milky colour (as opposed to a deep black coffee colour). You can, though, press the "cup" button to stop the brew. So once, it starts running milky, you can stop the cycle.
I hope this helps. I know I've been struggling and cursing the machine for a while :)
Dec 30, 2009 | Saeco Odea Giro Plus Coffee Maker
Grinds too long coffee still weak
You can adjust the grind, finer will give you stronger coffee. Think water through sand vs. pebbles. There are also settings you can find in your owners manual for adjusting the length and strength of your "pull".
Try Julius Meinl espresso roast, it's dark, rich and sweet. Definitely my favortie.
Dec 24, 2009 | DeLonghi EAM3400 Espresso Machine
Bad tasting coffee
tell what does it taste like is it to hot burn let me now but i would descale it first not with venagar but with coffee maker descaler start with that and let me now what the taste
Jan 10, 2009 | Sunbeam COFFEEMAKER 10C BLACK DR13
Coffee is weak
Check where the water comes out under the brew filter. It sounds like you may be missing the sprayhead. It is a round metal or plastic piece that is screwed on to the water dispense area and acts like a little showerhead forcing water evenly over the coffee grounds. If it is missing, the coffee will be weak. Check the water temperature. If it isn't hot enough, the coffee will be weak.
Jul 11, 2008 | Bloomfield 8571 Coffee Maker
Weak Coffee
Mar 02, 2008 | Jura Capresso Impressa S8 Coffee Maker,...
Coffee Makers & Espresso Machines Logo
27 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
