Question about Cameras
Just installed aG2740 3 cameras work great and cant get the other to work power lead ok but camera lights don't come on, all cameras are turned on and have tried pairing but still no go
SOURCE: Camera rapidly beeps 6 times when powered up and immediately turns off!
I HAVE SOLVED THIS!
I Totally fixed my CAMERA!
If you turn on your camera, the lens does not come out, and it just beeps then turns off, then listen to me.
You need to unscrew the outer casing and take off the metal shell.
Hold the camera in one hand, palming it, looking down at the LCD (ie the lens is pointing into your palm). This is to orient you.
If you look at the left SIDE of the camera, near the upper left corner of the LCD, you can peek through some of the windows of the black plastic casing and see 2 PLASTIC GEARS. The top one is white, the other is black. These are the gears that actually move the lens in and out. All I did was give the white gear a good jiggle with the tip of a pen and evidently it made the teeth of the gears mesh together like its supposed to and .... VOILA .... the lens came out when I powered it on and all is well! I know this is gonna help someone!
Posted on May 24, 2008
SOURCE: Camera will not work with sd card
Had the same problem, blew out the card slot with air and fixed it. Apparently poor contact points with the card.
Posted on Jul 27, 2008
SOURCE: Samsung NV10 Charging problem
I had the same problem while charging the camera with the cradle. I tried charging directly with the camera and it looks good. Problem seems to come from the cradle itself. Phil
Posted on Jan 01, 2009
SOURCE: My camera says "Turn the power off and on again"
My sister had the same problem and I was trying to figure out what it was so I googled it and someone suggested to take the camera and hit it (not very hard) with the lens side down on a table.....This may sound completely crazy but I tried it and it made a weird sound so I turned it off then on again and it worked!! Hope it works!
Posted on Mar 13, 2009
  • 124 Answers
SOURCE: Please Turn On The Camera...
switch off your cam !!! connect the cam to the PC via data cable !!!!!then swith on your digi cam & place it in display picture mode !!!!!!then u can use ur digi cam like a pen drive
Posted on Jul 21, 2009
We just received a camera clock and we cant get it connected to WFI. We have been working on thisfor hours, the only time we can work on this is evenings.
WIFI connection method:
1. Switch the power button to turn on, then long press the play key until the blue light on(30 seconds later, blue indicator light start flickering, then the clock camera is turned on , and then red indicator light will flickering, which means the clock camera WIFI signal is opened)
2. turn on the WIFI on your smart phone . Run APP software that you have downloaded and installed
Dec 12, 2017 | Car Audio & Video
E system 1212 Laptop won't switch on. Power
Laptops are so integrated that usually a system failure that involves power issues such as in your case where you cant get it turn on with anything on the screen mean the mainboard (motherboard) is damaged. This usually leads to buying a new laptop or paying for the board to be replaced which usually costs as much as the laptop.
May 12, 2011 | Computers & Internet
Battery power problem
Even though the camera shows that the battery is charged it could still be that the battery is faulty. If you don't want the needless expense of buying a new battery just to find the fault is with the camera after all, try rigging up a test circuit with a piece of wire and a low voltage light bulb from a torch or fairy lights. If the bulb lights up then the battery should be OK. (Make sure the bulb works with another normal 9v battery you know is good.)
I just tried this with my camera battery and an old dud battery I had to scrap and the bulb lights up with the good battery as expected.
Sep 22, 2009 | JVC Everio GZ-HD7 Camcorder
Oct 24, 2008 | Samsung NV10 Digital Camera
Reverse camera installation
use a relay.
run a power lead from the battery to the lead, tap your reverse light positive for signal and output the relay to your camera.
Its simple and efficient and better than running the camera directly from the reverse +
Aug 30, 2008 | Car Audio & Video
Not charging?
Please plug the camera charger in AC Outlet and hook it to camera. Check camera power turn ON, works fine? if OK, switch it to Standby / Off mode. Attach battery and check any charging light lit? If yes, leave the camera on charging position for 4-5 hours until its charge light flashs or turn Off. battery is chaged now. Have fun :)
Aug 13, 2008 | Sony Handycam CCD-TRV37 Camcorder
How do you reset the camera
under the battery there should be a little button here u might have to use a needle or somethign fine and sharp to reach it, press that. that should help. if it is not there, then it might be under or on top of the camera im not to shore, try to find it, if u cant, please et back to me.
Jul 17, 2008 | Sony Cybershot DSC-T200 Digital Camera
Weird shut off problem
If you don’t find a solution you may want to try fixityourself123@gmail.com. He was able to give me some great advice and he has used parts in good condition and at a good price. It worked for me.
Jul 17, 2008 | Casio EXILIM ZOOM EX-Z70 Digital Camera
Lights are on but nobody's home!
I had the same problem two years ago and because the camera was still within warranty coverage, I was able to return it to Olympus for no charge repair and they fixed the zoom lens gear and it works fine.
Oct 14, 2007 | Olympus SP-320 Digital Camera
Cameras Logo
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
