Question about Hisense Televison & Video
Hisense TV is stuck on screen with loading after pressing Media on the remote I have unplugged and switched off several times No buttons on the remote changes this! Need help to get it back to normal?
    Top Expert:
  • Hisense Master
  • 75,178 Answers
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
bluenadas
  • 203 Answers
SOURCE: Problem, please help
The unit should be under warranty. What you're describing is not normal and I would attempt to get a replacement from the place of purchase or take the unit to an authorized repair center. Below is the Philips support page for your unit. You can check warranty status as well as request repair.
Philips 42PFL5332D/37
Posted on Dec 07, 2007
SOURCE: Vizio L32 tv
Had same prob;em. Replace main board and now works just fine. You need to take the back off and under the metal cover is the main board. The part number should start with 3320-xxxx-xxxx. You can purchase the board from Vance Baldwin. vancebaldwin.com sign in as a guest. I will warn you the cost of the board is high.
Steve
Posted on Aug 13, 2008
  • 223 Answers
SOURCE: INPUT GOING CRAZY
It could well be the accumulation of dirt/dust behind the buttons causing them to stick. If you are able to carefully remove the board that the buttons are located on and use a cleaner that will de-grease at the same time. Be sure that everything is dry as can be before re-assembling and then check if the problem persists. If you are not capable of doing this trust a competant technician. Hope this helps.
Posted on Oct 01, 2008
ginko
  • 19396 Answers
SOURCE: TV stuck on one channel
Remove batteries from remote, and test again the touch buttons on TV with remote batteries out. This to exclude the possibility that remote has a stuck button.
If the problem persists , then it is probably a faulty IR board on TV (the one that gets IR signal from remote), or a faulty touch button switch.
Posted on May 16, 2009
JayAbed
  • 14 Answers
SOURCE: I have a HAIER 42' LCD tv. Last week we started
Main systme control PCB. its the board where all of your inputs are in.
Posted on Jan 11, 2010
Hi I am having issues with the YouTube app on my tv. When I press the YouTube button on the remote the the app it opens up to the YouTube welcome screen but gets stuck but does not load.
Delete the App, unplug the television, count to 10. Reload the app and try again. It sounds like it has become corrupted. Also check for updates to the television.
Mar 31, 2018 | Hisense Televison & Video
How can I fix the power button on my Hisense model LTDN55XT770XWAU3D TV. All other buttons work perfectly.
The problem probably is that the power button on your remote is jammed or stuck, try pressing it a couple of times to check if its the button or the remote itself is the problem.
May 06, 2017 | Hisense Televison & Video
My Hisense flat screen tv is stuck on small screen. My screen is basically a small box in the corner and the rest is black. Please how can i fix this?
Sounds like its stuck on picture in picture or pip. Is there a button on remote that says pip? Or try unplugging for a few seconds...maybe go to menu and reset settings to default.
Dec 07, 2016 | Hisense Televison & Video
Tv not full screen
Press the 'Zoom' button on the remote control once. The picture will come normal.
Sep 11, 2013 | Hisense Televison & Video
TCL Blue Screen "No Media"
I HAVE FOUND THE ANSWER!!!! I just bought an TCL TV last night and was given the wrong remote. Screen was stuck on "no media" screen BUT I noticed that when I turn the tv on and keep pressing the menu button, the menu screen would pop up for a half second before the no media screen popped up again. So I knew it was able to access it. SO, it took a few try's and with no exact method I turned the tv on, waited til I saw the TCL logo and then simultaneously pressed the menu and channel up button repeatedly. It will open the menu for you and allow you to move between the input channels!!!! It WILL take a few tries to catch it but it worked!!! Your welcome!!!!
Dec 29, 2012 | Televison & Video
Hisense LCD remote code
Turn on the TV and point the remote at the TV,press and hold TV and OK at the same time for 2 seconds,all the buttons on the remote will light up,for 2 seconds,after that only the numbers 1-12 will remain lit. Press the CH/PG button to send a series of off commands to your TV,repeat until your TV turns off,press the TV button to save the code and exit,all the buttons will blink 3 times to confirm code. hope this helps..
Mar 27, 2010 | Televison & Video
Tv stuck in service mode
Unplug for several hours, press and hold power button for 5 seconds, wait half hour more, plug back in and try. Or press and hold either channel buttons at same time or volume buttons at the same time to see if that exits the mode.
Nov 18, 2009 | Sylvania SRT2232S 32" TV
My Hisense lcd is lock.
This is how I got mine to work after weeks of struggling just trying to find a new remote (hisense is really hard to contact....).
1) Turn the TV ON. unplug the tv while still ON 2) hold down the "menu" button on the side of the TV and plug it back in. keep holding it down. the TV should turn on with the menu popping up. use the Vol <> keys and Channel <> keys to navigate the menu. go to the Vchip menu, and play around. I'm not sure what ultimately worked, but i changed the Vchip password to 1111, turned the reset menu to "on" and played around with the ratings settings (turning most of them to "u"s etc).
I went through this process several times and finally, the black background behind the menu turned to static. I played around with the channels, and the TV was unlocked. I turned the TV off, and then on again, and the channels showed up normally (no static). and it was no longer locked. I had to do the unplug thing several times, and was getting really frustrated looking for an "unlock code" in the manual (it just says press the button on the remote. so it was not really helpful).
But really, once you can just get to that menu you've made some progress, and just keep playing around with it until something works.
Best of luck!!
Jun 03, 2008 | Hisense TL1700 17 in. LCD Television
Locked out of TV
Use two buttons on the tv at the same time, hold four seconds.
Try menu & power or vol up & chan up.........
Nov 04, 2007 | Televison & Video
Televison & Video Logo
56 people viewed this question
Top Hisense Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Hisense Televison and Video Expert? Answer questions, earn points and help others
