When I turn it on, I get to check a word I press down arrow and nothing happens. I have changed the batteries and pressed clear but nothing happens.
SOURCE: Lexmark X3350 Printer
Thanks for everyones help, what worked for me is to reinstall the software that came with the printer. Works just fine now.
Posted on Apr 23, 2008
  • 64 Answers
SOURCE: change the batteries and pressed the on/off-switch arrow dont mov
Make sure you have the latest drivers from the logitech website.
Also, make sure that the receiver is within a reasonable proximity of the mouse. I have also found that I get interference if I have placed the receiver near my speakers.
Please rate me if this works.
Posted on Apr 15, 2009
  • 53 Answers
SOURCE: nothing happens when I press the start button.
here is a list of things it could be. pull spark plugs check compression. all cylinders need to equal each other within five percent, and be over 100 lbs of compression. I don't know the year model but, some gp1200 comes with a security key pad. click here for a link to Yamaha, for the owners manual. it will give detailed instructions on how to reset code. last find the starter solenoid I have attached a the picture it has a number one marking the image. the discription at the bottom says starter relay assy A quick test of the starter is to jump across the leads. You need to be careful it will arc. best thing to use is a short screw driver. use the metal shaft of the screw driver to connect both threaded connectors on top.
Posted on Nov 06, 2009
  • 12 Answers
SOURCE: When I turn on WII it says ''press A to
If you have more than one remote, you may have to "sync" the remotes to your Wii system.
1. Open the battery cover on your remote and press the red "SYNC" button. The lights on the remote should begin flashing.
2. Open the cover on SD Card slot on the console and press the "SYNC" button.
3. The lights on the remote should stop flashing after a few seconds. Your remote is now ready for use.
This process must be repeated for each new remote.
Posted on Feb 09, 2010
  • 47 Answers
SOURCE: when you press down the clutch nothing happens
first check for fluid in clutch reservoir, maybe low. second bleed air from clutch system. if still no pressure then check master cylinder or slave cylinder. sometimes it is a simple fix.
Posted on Jun 13, 2010
Dell3100. Getting PCL error - press reset .tried to reinstall .nothing works
  1. Press Select ( > ) to clear the error on the printer.
  2. Reset the printer NVRAM:
    1. Press Menu.
    2. Press the down arrow until Configure appears, and then press Select ( > ).
    3. Press the down arrow until Maintenance appears, and then press Select ( > ).
    4. Press the down arrow until Init NVRAM appears, and then press Select ( > ).
    5. When Restart Printer appears, turn the printer off and then back on.
  3. Change the PCL driver to binary mode and attempt to print the document again.
    1. Right-click the printer's icon in Printers and Faxes, and then click Printing Preferences.
    2. Click the Advanced tab.
    3. Click Bitmap Smoothing and change the setting to On, and then click OK.
  4. If the error still occurs, Contact Technical Support.
Feb 12, 2015 | Dell Laser Printer 3100cn PCL6
Up and down arrows on my ti-84 work as left and right arrows on the main screen! how do i fix this?
Remove one of the AAA batteries.
Press and hold CLEAR while reinstalling the AAA battery.
Continue holding CLEAR button and press ON.
Release buttons and press CLEAR again.
Feb 03, 2013 | Texas Instruments TI-84 Plus Silver...
Mem cleared Changed out the batteries and received a messege mem cleared and nothing will work.
Follow this steps to resolve this problem:
1. Press ON to turn calcilator on
2. Press 2nd and then press + key button. TI- 81 displays RESET menu
3. Press 2 to select the RESET, the second item in the RESET menu. The display shows the message Mem cleared. Press CLEAR to clear the screen
If you cannot see anything on the screen, you may need to adjust the graphing TI- 81 calculator contrast:
-To darken the screen, press and release 2nd key, and then press and hold up-arrow key until the display is sufficiently dark
- To lighten the screen, press and release 2nd key, and then press and hold down-arrow key until the display is sufficiently light
Aug 22, 2012 | Texas Instruments TI-81 Calculator
I just changed the batteries on my TI86 and now the screen is dark I can't see hardly. How can I clear the screen to look normal?
Turn the calculator on. Press and release the 2nd key, then press and hold the down-arrow key to lighten the screen. If you go too far, press and release the 2nd key then press and hold the up-arrow key.
Aug 06, 2011 | Texas Instruments TI-86 Calculator
My TI 83 plus is not working. when i press"on" nothing happens. I changed my AAA batteries, i even change the back maxwell battery, but nothing happened
TI calculators have an annoying habit of dimming the screen when the batteries are changed so that it appears as if the calculator isn't turning on. Turn the calculator on (or at least press the ON key). Press and release the 2ND key. Press and hold the Up-arrow key for a few seconds and see whether the screen becomes legible.
If this doesn't do it, please reply to this post and we'll go on from there.
Sep 27, 2010 | Texas Instruments TI-83 Plus Calculator
When I try to graph I get an err: invalid dim Note: This started happening after I changed the AAA batteries
If you got the message while trying to draw a graph
  1. Press [2nd][Y=] (STAT PLOT)
  2. Choose option [4:PlotsOff][ENTER]. Screen displays Done
If message popped up while doing something else that involves lists or matrices, the length of lists may be different, or the dimensions of matrices may not be compatible.
To Clear the lists:
  1. Press [2nd][0] (CATALOG)
  2. Press [PGRM] (C) to jump to first command that starts with c.
  3. Use arrow to scroll down to ClrAllLists, select it [ENTER]
  4. Calculator displays Done
  5. Start the new problem.
To reset the Ram press [2nd][+] (MEM) [7:Reset][1:All Ram][2:Reset]. Press [CLEAR] to erase the Ram Cleared message.
When the RAM is cleared, the calculator is reset. The calculator resets itself after a battery change.
Aug 14, 2010 | Texas Instruments TI-84 Plus Silver...
I've replace battiers in my TI-85 and now when I turn it on there is a black screen. I can turn off. What do I do to clear screen?
After battery replacement, the screen contrast is liable to change: It may be too dark (your current case) or too light. You must adjust the contrast.
  1. Press [2nd] key and release it.
  2. Press an d HOLD one one of the navigation arrows
  • Down arrow to lighten screen (your current case)
  • Up Arrow to darken.
Keep pressing the relevant arrow key until the contrast is adequate.
Jan 25, 2010 | Texas Instruments Office Equipment &...
I accidentally pressed down for too long on my ti-84 plus calculator and i think it locked itself. how can i turn it back on? I NEED it for school!
From TI FAQs:
What troubleshooting can I try if the TI graphing calculator will not turn on?
For the TI-83 Plus Family, TI-84 Plus Family:
Caution: The resets described in these troubleshooting steps will cause a loss of applications, programs and data. If at all possible please create a backup using TI Connect™ first.
  1. Try a new set of AAA batteries.
  2. Adjust the contrast by pressing and releasing the [2nd] key followed by pressing and releasing the up arrow; repeat as necessary. To adjust or lighten the display, use the down arrow.
  3. Remove one of the AAA batteries. Press and hold the [CLEAR] key. While holding [CLEAR], reinsert the AAA battery and then turn the calculator on. The calculator should display the message "RAM Cleared". Release the [CLEAR] key and then press it one more time to remove the message.
  4. Remove one of the AAA batteries. Press and hold the [DEL] key. While holding [DEL], reinsert the AAA battery and then turn the calculator on. The calculator should display "Waiting...Please install calculator software now". Follow the instructions for the TI-83 family or TI-84 Plus family to reinstall the calculator operating system.
  5. Remove all of the batteries including the round lithium battery for 5 minutes. After the 5 minute period, reinsert all of the batteries and turn the calculator on. Adjust the contrast if necessary.
Aug 24, 2009 | Texas Instruments TI-84 Plus Calculator
TI-83 Plus calculators won't turn on despite the many attemps...
It is possible that the contrast is too light as to make the cursor invisible.
In that case you can increase the contrast as follows:
1. Press [2nd] key , then release it.
2 Press [up arrow] key ,then release it.
Repeat the two steps until you get the right contrast.
To decrease the contrast, you press the [down arrow] key instead of the [up arrow] key.
Hope it clears the obscurity.
Hope that
Feb 18, 2009 | HP 12c Calculator
Help!!a Black screen appears when I turn on my calculator
ok guys, after about 10 years of not using my ti-83, i put the new batteries in and got the black screen you are all talking about.. came to this site.. saw no solutions.. kept looking.
I've fixed my calculator, but my brain won't tell me exactly how.. but i followed those instructions..
you CAN see what is on your screen if you tilt it under the light ... just fiddle around until you can see faint writing on your screen under the black.
Press window
i have these entries in my calculator
then go and press second and the down arrow to lighten your screen. it should work.
Nov 01, 2007 | Texas Instruments TI-83 Plus Calculator
