How to test PioneerAVIC 8100NEX to see if it works?
I rececntly found this dumpster diving and it doesn't have the powercord. I cant seem to find the power cord pinout anywhere.is there a way to test to see If this works or not?
4 Suggested Answers
  • 105 Answers
SOURCE: Powercord replacement
Usually, you must get a replacement through the manufacturer. However, many products share common cord designs, & you may be able to find a compatible cord at your local thrift stores. They often have odd cord sections.
Posted on Aug 12, 2007
bobjrdns
  • 84 Answers
SOURCE: Where can i find a new power cord?
REPAIR OLD WITH ECETRICAL TAPE IF THE WIRES TOUCHED TOGETHER THEN IT PROBERLY BLEW A FUSE
Posted on Oct 18, 2008
phil_hick883
  • 917 Answers
SOURCE: Is dumpster diving prohibited by city ordinance in Mesquite,Tx?
Call local Police , they will advise
Posted on May 09, 2015
Washburn mercury series electric serial #6050208 trying to find out what I can about it. Found it in a dumpster dive.
Cameron, nice find. Check the attached links,instruction and guides, you can also Google or Bing search the guitar for more info. Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://www.washburn.com/media/catalogs/pdf/Washburn1993ElectricsCatalog.pdf
Blue Book of Electric Guitar Values ELECTRIC MERCURY SERIES ELECTRIC...
washburn mercury series electric guitar Google Search
WASHBURN MERCURY SERIES guitar list
Jul 08, 2016 | Washburn Music
Tip
Eagle Dumpster Rental
At Eagle Dumpster Rental professionals in waste management are ready to help with any and all trash hauling, garbage collection and trash container needs. Eagle Dumpster Rental services the entire greater Philadelphia area with prompt and courteous service, including same day deliveries, to meet the demands of all customers. Waste containers for home clean-up projects, construction dumpsters, roll-off containers and junk removal services are all areas of expertise found from Philadelphia's top waste management and garbage collection provider, Eagle Dumpster Rental. Eagle Dumpster Rental In Philadelphia PA Wilmington DE Nearby Areas
on Oct 05, 2016 | Home
Diagram need sawzall sears
Searsparts.com has an exploded view. You can (in firefox at least) right click and save the JPEG file so you have a copy. Also do a search for repair parts+make+model# and most of the sites will have an exploded view and the parts list but I haven't found a parts list that I could download. I have a dumpster-dive 172.171800 that $30 of parts fixed.
Oct 07, 2013 | Craftsman 8.0 amp Reciprocating Saw
PPID: CN-0JMN8H-12960-11Q- A0DDJAL0R0
A) If the motherboard has been Static shocked, from not following Anti-Static Procedures; it's a Frisbee. (Or dumpster item)
B) Right off hand I'd say it's a Dell Inspiron Mini 10 motherboard.
Not the following model number of Mini 10 (1012), but guessing one of the Mini 10's,
http://www.ebay.com/itm/DELL-INSPIRON-MINI-10-1012-MOTHERBOARD-JMN8H-0JMN8H-CN-0JMN8H-LA-5732P-/330580340503
Regards,
joecoolvette
Mar 15, 2013 | Computers & Internet
On screen saying re attach power source, no function.
Does it have the battery in it? If so, plug the powercord in to charge. If not, put the battery in it. If it still doesn't work with battery and power cord: I would think either the battery or the powercord is not working properly. Most likely the powercord.
May 02, 2011 | Sony Handycam DCR-TRV280 Digital Camcorder
IC Power 19'' LCD Product PA192D Model # 900G quit working
I C Power PA192D Model 900G, Mfg Sep '05 19inch LCD
I purchased this monitor at Goodwill not working for $20. The 900G power light failed to come on and there was no video when turned on. To fix, first pull the 2 screws at the bottom of the back side of the monitor_ note this face is NOT removed by prying with a screwdriver like other monitors, it IS removed by sliding the face plate Upwards. Remove the LCD screws and remove the wires to the backlights carefully noting what goes where. Remove the metal cover and remove the 110volt power board. I found smoke trails under the cover and a swollen 470uf25v capacitor number C206, and replaced C110, C211 all were 470uf. Reassembled and found no change. Tore down again, used the ESR meter CapAnalyzer 88a and found C114 47uf25v to be 30% working, the volt ohm showed the cap to be good, that's why the ESR meter was needed. Replaced the 47uf25v C114, tested the large 100uf 450v capacitor, it tested only slightly under spec , could not find a 100uf at Radio Shack so did not replace it. So in this attempt the only thing changed was the 47uf C114. Reassembled and now works perfectly.
i'm not an expert at anything...x'cept maybe dumpster diving. God Bless
Nov 20, 2008 | LG Flatron L1951S-SN 19" LCD Flat Panel...
Tyris Tyris 17" LCD F179 T701DB monitor image appears for 2 secs
Sounds like a bad inverter or CCFT(s). Adjust the brightness to the darkest setting. If the display stays on longer, the you have a bad CCFT(s). If it still goes out the suspect a bad inverter.
Aug 30, 2008 | Dell E172FP 17" LCD Flat Panel Monitor
Hv transformer
Check this site under troubleshooting to find more info on how to test those parts.
Apr 23, 2008 | Kenmore 62702 Microwave Oven
Dell E173FPf lcd- no picture,steady green light
E173FPf Mfg December 2004
This E173FPF has changed much inside from the November 2003 E172fpb which had the famous 4 identical transistors 5707 that would tend to fail in pairs. If your newer E173FPF displays a green power light and fails to display a picture try replacing the 220uf25v capacitors at C6 and C26. Test them with a volt ohm meter and they will test Ok, replace them anyway. Radio Shack did not have the 25v so I used the 35v, display works fine now. There is an E173FPF repair kit with directions available on Ebay if you don't have a parts store in your area and would prefer delivery.
Jan 14, 2008 | Dell E173FPf 17" TFT LCD Flat Panel...
Computers & Internet Logo
David Payne
David Payne
