We are having problems with water jets on our front loader washing machine which is `10 years old
docjohn174
  • 943 Answers
SOURCE: hi I have a whirlpool
HI thanks for the question When you put the lid domn can you hear the motorstart if no you need a lid switch if yes you need a motor coupling thanks THE APPLIANCE DOC
Posted on Sep 13, 2008
  • 4 Answers
SOURCE: bosch front loader washing machine water pump?
Always check to see if the water waste (located normally at bottom right) has no foreign objects in their such as bobby pins, coins etc It has happened to me 3 times (first time cost me $150)
Posted on Jun 16, 2009
  • 4088 Answers
SOURCE: washes then does nothing else
First, is the machine still under warranty? If so, take advantage. Suspect the timer assembly or possibly a bad relay. Try pulling the power plug for 5 minutes then retry. If it has a mechanically driven dial, try rotating to spin. If that works, there may be a fault in the clock drive to the timer. If electronic, it's all in the timer control board.
Posted on Aug 11, 2009
  • 70 Answers
SOURCE: 10 year old miele 300 washing machine jumps to
Most likely brushes. Fit carbon brushes part no.4297411 as they are less then half the price of the brush module Part no. 4229779.
Posted on Jun 19, 2010
godescobar
  • 110 Answers
SOURCE: My 2 year old Samsung front loader washing machine
if its spinning but no water comes out then most likely the cause of that is that the pump is either on its way out and can no longer pump the water out or its plugged with something most likely a sock or some other debris...
if the washer does not spin at all then something is most likely jammed or another mechanical failure.. front load washers can be problematic especially if you don't go easy on the load size so id suggest having a repair man fix...its not recommended trying to do it yourself
Posted on Feb 08, 2011
Bosch avantixx front loader leaking underneath machine? machine only 2 years old
  • You will find a small door on the front bottom of the washing machine.
  • Open it.
  • Unscrew the filter and rinse it with running water.
  • Put it back in place and repeat the above steps in reverse order.
This should solve your leakage problem.
Aug 03, 2014 | Bosch Washing Machines
My washing machine fills with pieces of black matter. I have done machine clean washes and it still happens every time, covering my clothes in black pieces that look like cardboard. Please help my - the...
Hi mine does exactly the same! I have to call in my washing machine technician more often (he told me this would happen with a top loader as opposed to a front loader, boy was he right!!) and he cleans out the drum. Mostly it is the fabric softener which is too thick. I water mine down to 50/50 and I do another spin after my final wash. I also empty the filter of water at the side/bottom of the machine. This annoying problem is caused by the way the drum turns on a top loader as opposed to the front loader. My top loader cannot heat water automatically either like a front loader, and I think this also adds to the problem as hot/boiling water would dissolve all that soap/fabric softener. Hope this helps.
Jul 12, 2014 | Samsung SW62ASP Top Load Washer
Ytek.netwe just moved into a house with a duet washing machine- a few years old. when we do a normal clean cycle, it doesnt appear there is that much water getting used. How much water should we see thru...
All front loaders use very little water as a opposed to a top loader that uses up to 45 gallons per load a front loader uses about 10,plus a front loader cleans clothes very well with that minimal water usage.
The major question is do the clothes seem to come out clean when you have used that washer?
Aug 20, 2011 | Whirlpool Washing Machines
I have a Kenmore top load washer model 20692. The washer won't drain and whenever the washer is supposed to turn all I hear is a hum. What could be the problem and is it worth fixing in a 10 year old...
Sounds like you have multiple problems...you are right... probably not worth fixing...
Look at the front loaders... they use way less water and are more gentile on your clothing...
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Aug 08, 2010 | Kenmore Washing Machines
Jun 15, 2010 | Miele 300 Front Load Washer
Grey spots on our white clothes after wash
do you use affresh to clean your front loader? deposits of soap and other such things can be stuck around the inside tub of your washer. try this porduct out it works great on all front loaders use hot water with the affresh pellet with no clothes and run the machine through a cycle this also helps with any stagnant water smells also have you cleaned out your pump lately. * note remeber to put the pellet on the inside of the machine not in the soap dispenser
Apr 28, 2010 | Bosch Axxis WFL 2060 Front Load Washer
We have a Maytag Neptune washer Model # MAH4000 AWW it is leaking from the front at the bottom of door. Water pours out like a water fall when it wants to rinse. Any ideas?
TO ELLIESHIRK, I SEE YOU POSTED YOUR PROBLEM ON MAR. 19, 2009. I HAVE A MATAG NEPTUNE FRONT LOADER WASH MACHINE MODEL #MAH55FLBWW. I AM HAVING THE SAME PROBLEM WITH MY MACHINE LEAKING WATER OUT THE FRONT DOOR. MY WASH MACHINE SEAL LOOKS FINE. IF YOU HAVE FOUND A SOLUTION TO YOUR WASH MACHINE LEAK PROBLEM, PLEASE LET ME KNOW, OK. YOU MAY EMAIL ME AT: CJA931@FRONTIERNET.NET , MY WASH MACINE IS NOT VERY OLD EITHER 4-5 YEARS IM GUESSING, IT WAS LEFT WITH THE HOUSE I PURCHASED. THANK-YOU FOR YOUR HELP AND TIME. CONNIE
Mar 18, 2009 | Maytag Neptune MAH7500A Front Load Washer
Aquaris Hotpoint Wma 13
Dear grahamconnor,
ngfam1 here for you!
I am happy to be of assistance!
If the machine is 10 years old or more buy a new one!!
Look at speed Queen washers1 They are commercial and have the best warranty in the industry!
use the least water and wash 8 loads a week for 25 years or more! They start at about $549 for the top loader and 1299 for the front loader, BUT the front loader uses ONLY 13.9 GALLONS OF WATER!
The last washer i will buy! And everyone working in my applaince store has one!
If you decide on service!
Here is a good service that I recommend to my customers,
in our 65 year old appliance business!
A&E Factory Service
1-800-905-9505 -(IN U.S.A.)
They are open to make appointments 7days/24hours
A&E is factory authorized service for most brands!
Including warranty work!!!
They will help you, and all will be well!
You will be fine now!
Thank You
Bless you,ngfam1
PS. PLEASE GIVE ME A GOOD RATING HERE ON FIXYA.COM BEFORE YOU SIGN OFF
Aug 26, 2008 | Hotpoint WMA13 Front Load Washer
Hoover 500 ma top load washing machine manual & specifications
FRIEND,
BUY SPEED QUEEN FRONT LOADER. IT ONLY USES 13.9 GALLONS OF WATER PER WASH!!!!
If the appliance is 10 years old or more,it may make sense not to invest any money to fix it!
BUY SPEED QUEEN NEXT TIME AND HAVE IT FOR 25 YEARS! THAT'S WHAT I HAVE!
Happy to assist you,
PS. PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OFF!
Aug 26, 2008 | Hoover Washing Machines
Washing Machines Logo
27 people viewed this question
Top Washing Machines Experts
