Question about Mercury Marine 15hp & 20hp 4 Stroke Outboards Outboard, 115lb., 15"
20 hp 2 stroke 2015 yahama not responding to acselerate.
New #4 carbarator for Yahama 2004 4 stroke 50 hp will not idle
correctly adjust idle setting screw
as a start position turn it all the way in then back out m1 1/2 turns
adjust the throttle setting by the screw on the butterfly lever
Jul 08, 2017 | HP Boating
I have a 20 hp mercury outboard serial#06082001.I want to know what year it is and if it's 2 or 4 stroke
If you drop the first zero it would put it at 1981.
this site gives a different answer, as 1980- 81, so close. It SUGGESTS it is a 4 stroke engine.
It is likely a 4 stroke, but I won't give you a definitive answer, due to the damage it can cause with a guess!
A four stroke running with two stroke oil will just smoke, but a two stroke with no oil will seize and leave you stranded on the water with a seized engine!
A four stroke engine has valves operated by push rods or a pulley and a chain, a two stroke just has a head. Take a look at the engine and it should be obvious.
For your first service, I would suggest you go to a marine engineer. Ask all the questions, and get the right answers. When I had my 1986 Evinrude serviced, i typed a list of questions and left the list with him. i asked him when I picked up the boat and wrote the answers down. The first one was 'petrol to oil ratio and which is the best oil'. A basic service will cost you a hundred bucks and you will have some comfort that you are unlikely to break down, 6 miles offshore with only a paddle :)*
Mar 07, 2017 | Mercury Boating
How to adjust valves on pro 300 x19.5 hp
Adjustment and Tuning of a Chainsaw Carburetor ' Chainsawr
Carburetor Adjustment for Chainsaws Carburetor adjustment is critical on chain sawsand ... The throttle valve (butterfly) simply cuts off the supply of combustible air/fuel and the engine stops. .... (7) Go back to step (5) and reset the idle speed.Missing: 300 ‎x19 ‎hp
Small Engine Troubleshooting - Jacks Small Engines
Mar 20, 2015 - Fuel valve shut off; Fuel solenoid inoperative. ... Pull starter rope to setengine on compression. ... i cant get motor to idle its a b&s 300 series 4.50 model 9t602 type 5019 serial 11082954 aug ... i have a 17 hp kohler command that backfires when i try to start it, it has a new coil and i ... July 5, 2015 at 1:46 pm.
? 7:08
Feb 27, 2008 - Uploaded by DIOSpeedDemon
The reed valve is very important for a high perfomance DIO engine. ... The valve material is of great concern when building these engines. ... DIOSpeedDemon 5 months ago ..... 300 HP 2 STROKE - Duration: 1:05. jangho9 218,194 views ... Two-Stroke Scooter / ATV Carburetor Settings And Adjustments ...Missing: chainsaws ‎pro ‎x19
Jan 25, 2016 | Garden
What is the yamaha spark gap for jet ski engines 1990 year
Sep 01, 2014 | Clymer Yahama 2-250 HP Two-Stroke Outboard...
Yamaha diagrams
All the 1998 range? Shimming diagrams?
Apr 27, 2014 | Clymer Yahama 2-250 HP Two-Stroke Outboard...
How many miledge will give yamaha r125?
Hi, Depending your driving style, but normally the mileage of this bike will (15-20) KM/L.
Please see below for more detail: TECHNICAL SPECIFICATION :
CC : 124.66
BHP :15 PS @ 9000 rpm
TORQUE :12.24 Nm @ 8000 rpm
BORE X STROKE :52 x 58.6MM
WHEEL BASE:1355 mm
FRONT TYRE :100/80-17
REAR TYRE :130/70 -17
LENGTH :2015 mm
WIDTH:660 mm
HEIGHT :970 mm
MILEAGE : 15-20 kmpl
Dec 08, 2010 | 2008 Yamaha YZF-R125
Fuel ratio 2 stroke yahama YZ125
32:1--40:1 Any less than a 32:1 mix and she will smoke and foul plugs(not to mention wasting money on mix) Any more than a 40:1 mix and your top end ect. is not being lubed enough which will lead to costly top end and engine repair..... 40:1 is good for a synthetic mix...And 32:1 for a non synthetic mix.... hope this helps ya....
May 21, 2010 | 2003 Yamaha YZ 125
2008 Yahama 90 2 stroke outboard lower unit fluid leak
Ok by fluid I assume it is gear oil leaking yes?
There is every chance there is the smallest seal leak there that may only be present once the gear case gets a little pressure in it, either through use, or through expansion as the leg heats sitting in the sun even. Have you got a new washer installed under this screw to properly seal it? Usually a nylon type washer is best.
Also, how do you know the lower unit is not leaking or have water intrusion? Have you drained the gearbox oil recently? If so what color was the oil, milky looking at oil or good semi-transparent oil color?
Mar 16, 2009 | Boating
Yamaha india
hello Sir,
It was the phase between 1990-1995, when Yahama lost to Hero Honda, as v know, Yahama was an expert in 2-stroke engine bikes, as v know 2-stroke engine will yield higher power but NO good mileage, n emit more smoke.
so...GOV OF INDIA phased out all production of 2 stoke engines in the country, so yamaha had to stop the production of Yamaha RX n RD series in INDIA.
N constantly rising fuel prize, utilizing this need form d public Hero Honda's CD 100 hit the market, with 4 stroke engine n heavily improved mileage.
hence Hero honda won the race...
Although Yamaha came up with some 4 stroke models, but those didnt click it for them, but now its again yamaha's time !!
with introuduction of Yamaha R15, FZR , really yamaha is back with a bang !!
thank u so much..!!
plz vote me/ rate me ..thank u!!
May 22, 2008 | Yamaha RX-V520
Mercury Marine 15hp & 20hp 4 Stroke Outboards Outboard, 115lb., 15" Logo
65 people viewed this question
Top Mercury Marine Boating Experts
Fabrice Wolters
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Mercury Marine Boating Expert? Answer questions, earn points and help others
