Question about Refrigerators
My fridge seems to accumulate water under the vege drawer.
  • 1073 Answers
SOURCE: Refrigerator - water liking under the meat drawer
defrost drain stopped up cleanout the drain from the freezer to the drain pan
Posted on May 07, 2008
  • 112 Answers
SOURCE: fridge problem
There is a drain, usually at the bottom of the refrigerator compartment. Pull out the bottom two drawers and see if there is a drain. It is usually in the very back of the inside compartment. Make sure it is not clogged. Usually, this is the problem.
Posted on Oct 18, 2008
peyton32034
  • 410 Answers
SOURCE: Superba fridge 1992 occasonal water under bottom freezer drawer
you have a frozen defrost drain. in order to fix this you will need to remove all shelves and basket out of the freezer. then remove rear evap cover. one youve gained access to this area you will see at the bottom of the coil an aluminum pan that most likely wil be iced over. clear away this ice then try to flush out the drain line with warm water. sometimes its neccessary to force water into drain line with a large syringe or turkey baster. this should fix ya up.
good luck and thx for using fixya Peyton
Posted on Jan 28, 2009
  • 400 Answers
SOURCE: What causes water to accumalate under the drawers of the fridge?
Assume you mean in the freezer compartment? If so this would indicate that the condensate drain is blocked up. You can defrost in two ways. Safest is to switch off the fridge, put a normal pedistal fan in front of the fridge so that the air blows into the compartment until it has defrosted. Or use a hairdryer. Either way, once defrosted, locate the drain hole and force water through it with a turkey baster. This can be done from inside the cabinet or from the back on the outside. Hope this sorts you. ratemeplease
Posted on Mar 12, 2009
SOURCE: Water from freezer dripping into fridge freezing and accumulating
Maytag , MZD2752GRW; Water accumulating and is freezing in bottom of the freezer, then runs out the door on to floor.
Posted on Jul 01, 2009
Why do I get blobs of water on the inside of my salad drawer in my Fridgemaster. Fridge/Freezer
Leaking Refrigerators
I hear a lot of complaints from people that see water leaking into their refrigerator from seemingly nowhere. Water appears in different places and even inside or under a refrigerators that does not have a water or a ice dispenser! Frost free refrigerators defrost the ice that collects on the evaporator coil on the average of about every 8 hours so the water that accumulates during defrost has to go somewhere right?
APPLIANCE 911
Dec 15, 2015 | Refrigerators
After thanksgiving, and loading the fridge with cooked food, after a couple of days water started accumulating under & in the vege drawers. How to correct?looks like the hing in top center of...
Normal 0 MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Dec 10, 2009 | Roper RT18DKXKQ / RT18DKXKT Top Freezer...
Unexplained water accumulation under the crisper/produce
OK, I am going to give you a lot of information on one page, so please read carefully and choose the parts that apply to you. PS, Please rate my solution and my thanks to all the Guru's that helped put the following page together. please click on link below, Thanks Sea Breeze
HOW TO FIX A DRAIN LEAK INSIDE REFRIGERATOR AND FREEZER PART 2
Aug 10, 2009 | Whirlpool Refrigerators
Fridge Leak
We fixed the leak by putting a pipe cleaner down the hole inside the fridge, at the back. This cleared the tube as it had gunk and grime blocking it. Now the water can run freely down the tube and into the drip tray which is at the back of the fridge above the motor.
Jun 12, 2009 | Fisher Refrigerators
Water is accumulating in bottom of fridge under produce drawers
Possibly your defrost drain found inside the freezer back wall is blocked. If you could send me the model number I could help you better. Thanks, Sea Breeze
Look at following areas for the model number
  • Beneath Or Inside Food Compartment On Cabinet Frame
  • On Plate Lower Front Or Rear Of Cabinet
  • Beside Compressor Door On Right End
  • Near Rear Of Cabinet
  • Inside Liner At Top
Mar 28, 2009 | Refrigerators
Whirlpool gold, freezer on top, single door
hi thanks for the question the drain system is clogged the drain hose from the freezer to the drain tray undre neath the fridge by the compressor is clogged you may have to shut down the unit to let the ice melt that has caused this problem get a small plastic hose from a hardware store and shove it up the drain dose and blow air up the hose till its clear that's why you have to shut the fridge off for 24 hrs to allow the ice to melt then blow the air thanks the appliance doc
Sep 02, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Water accumulation under vegetable drawer model KTRS22M
its the problem of the compressor present in your fridge... if its malfunctioning, then water wil accumulate under the vegetable tray
Jun 17, 2008 | Refrigerators
May 07, 2008 | Jenn-Air JCD2295HES Side by Side...
Refrigerators Logo
26 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
