Question about Sanyo Heating & Cooling
Sanyo Kmart 0912 I have a 30 amp disconnect 2 pole out side my house I'm gonna at a later date install 3 acs split units - do I bring 220 v up from disconnect than run to each location
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 20 Answers
Before connecting you should check the amperage of each ac then make total amps may the disconnect can not support
Have a Sanyo split inverter AC unit. On turning it on, operation lamp blinks and unit does not cool. Please help.
The blinking is an indicator that it needs service. Call a technician! Ask if they are experienced in mini split systems. You can check the air filters. Check the outdoor coil to see if its clean or covered up with dirt. And at the breaker or disconnect, turn off power, wait 5 mins, and turn it back on. Then give it 3-5 mins to see if it will reset itself. If this don't work, call a tech/service provider! These units are troublesome to troubleshoot.
Jun 06, 2015 | Sanyo Heating & Cooling
Why does my split ac unit leak inside the house?
This happens when the drain pipe is too high, or kinked. The pipe must be lower then the drain pan in order for the water to drain. This is a common problem.
Jul 27, 2014 | Sanyo Heating & Cooling
Daikin split system air con dead
Split system Air conditioners are very often on two or more separate breakers, with a control voltage (24vac commonly) connecting their operation. the condensor unit and out-door fan generally on a 220 vc 'paired' breaker, possibly a quick disconnect near the unit with fuses inside, or an independant breaker pair, and the evaporator unit with INDOOR fan on a 110 or 220 vac breaker.
switch the fan to 'ON' at the thermostat... this is the midpoint of the system electrically. If the fan comes on check for voltage at the condensor unit. a check to see if the thermostat is the problem... remove the thermostat and connect the red, green and either the white or yellow wires (not both) if you chose white you should have heat...yellow AC...
most split system AC have a small buss fuse on the control circuit board of the indoor unit. looks like a glass tube with metal caps held by metal clips. In 40+ yrs experience I have found it is more likely one or both of the 30 amp buss fuses near the outdoor unit (replace both even if one is still ok) or a 30 amp breaker in the quick disconnect box.
In many systems the control voltage to the thermostat derives from a transformer in the outdoor unit... it could be as simple as a broken wire. Without a full diagnostic, a complete description of the unit ( AC or heat pump, etc) this is all speculation
Nov 19, 2013 | Heating & Cooling
Cutler hammer 60 amp non-fusible disconnect... looking for instructions or a diagram to install
You connect the two hot wires from your power source to the two lugs in the. On the other side of the disconnect you connect the two hot wires to the A/C unit to the other two lugs. You tie the neutral wires (white) together and insulate them. You ground the ground wire to the box and run a ground wire to the AC unit.
So, you should have a red, black white and ground wire on the supply side to your disconnect. The red and black are your hots from your main box to the disconnect. They go on one side of the disconnect. The units red and black go ont other side. You connect the neutrals and ground it and you are in business.
Don't guess, because you are fooling with 220 Volts AC which will knock you silly.
Aug 02, 2011 | Heating & Cooling
We have just had an electrician do work around our house when we went to use the airconditioner it doesnt work. Tried to call our electrician but of course no answer. Any ideas how to start my...
Check the electrical panal and make sure the breaker is on(220 volt 2-piole breaker). Check at the air conditioning unit and make sure the disconnect is on and there are fuses in the disconnect. Some disconnects are a non-fusible type. Turn the breaker off at the electrical panal and make sure the fuses at the disconnect are good. Also check and see if the switch at the furance is on. Or check the electrical panal and make sure the breaker for the furnace is on(110 volt single pole breaker). This is only if it is a split system type air conditioner. Part insude , part outside. You need control voltaged (24 volts) from the furance to the outside contactor at the air conditioer for the system to operate.
Jan 27, 2011 | Mastercool 67680 Evaporative Cooler Air...
My AC unit has three wires, green, white red. Coming off the house and off the unit. How do I wire them!!
Hi, if you are talking about the wires,high voltage wires coming from the breaker box, and the same coming from the outdoor unit which are also high voltage wires, you have to set a disconnect box and mount it with in 3 to 5 feet from the outdoor unit. I am assuming you had no prior a/c unit there? If not, the 3 at the house must be ran out of your main breaker box through a breaker, double pole. It needs to match the rating of the voltage on the data plate on your unit, lets say, 30 amps. From your breaker box it needs to be ran through water tight conduit over to the box you will be adding there. Even though you have a green for ground, white and red, the white should be 120 volts and the red the same to have 220 volts. They will wire in this box to the line side. The directions in the new box will tell you line/power in and load/power out to new unit. This box you will need to buy is either a 30 amp or 60 amp disconnect. From the new unit, you will need to buy enough wire of the same size, and a piece of 3/4" seal tight flex conduit and 2- 3/4" connectors. Pull the 3 pieces of new wire through the flex conduit and connect to the 3 wires there. The green is ground so just connect it to a ground or the case. The other end will go through a knock out plug into the box and will connect to the load side. There will be a lug for the green ground. Coming from the house at the breaker box is where these 3 wires should be, and coming out of the breaker, you can use the 3/4" seal-tight to pull enough wire from there to the new box. This is what feeds your outdoor unit. This is just for the outdoor unit. The indoor unit runs on its own power source. There has to be a box mounted there also and wires pulled from the main breaker box to the indoor box. Hopefully who ever installed the unit has done all of this. If you have all of the boxes already there, just hook color to color. If you have never had a split system a/c unit at your home before and you are doing this yourself, there is a lot of high voltage wiring that has to be put in to run both the indoor and outdoor. Get back to me a let me know what you have to work with and if you have ever had a system like this before, and if you set the unit and installed the duct work.
Sincerely,
Shastalaker7
PS If the indoor unit is gas fired, the high voltage will be 120 volts. If its a heat pump, it will be 220 volts.
May 25, 2010 | Goodman CLQ36AR49 Air Conditioner
Retrofit newer Sanyo split AC system where old is installed
absolutly if you change refrigerants witch you prob would have to you may have to flush the linesets to cleen all the oil out but you should have no problems
Apr 08, 2010 | Sanyo Split System Air Conditioner
We have a Carrier mini split AC that we are wiring on a portable office that will be going to a foreign country, the Carrier #38QG24-H. This unit's voltage specifications is 200-240volts, single phase, 50...
please 200- 240 volts is a standard for all and for the breaker is depending of the country if 120 v single phase you will install as usa if 220 v single also you can connect you breaker but the problem is some countries are not 50 hz comfirm the unit is 50/60 hz.
Sep 24, 2009 | Heating & Cooling
Heating & Cooling Logo
Top Sanyo Heating & Cooling Experts
Dennis Boxerman
Tim Whalen
Chuck
Are you a Sanyo Heating and Cooling Expert? Answer questions, earn points and help others
