Kelvinator window mount air con model: KWH20HRC is not draining from the plug underneath. Having to release the water regularly.
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 20 Answers
May be is not mounted correctly
Kelvinator wiring diagram for wall mount air conditioner model ewh09hra
Good Morning Friend,
I understand that you are looking for the wiring diagram for your Kelvinator air conditioner, model# EWH09HRA. Typically, the wiring diagrams are not readily available. I suggest contacting the manufacturer, and have your model number available for them. They might be able to locate a copy of the wiring diagram of your air conditioner for you. Hope this is helpful.
-Best Regards-
WP
May 30, 2014 | Electrolux Heating & Cooling
Water leak from Electrolux Kelvinator EPK09CRN2A portable air conditioner
You'll have to open it up and check for a displaced condensate collector. This may look like a funnel with a drain tube that is supposed to go to the tray
Nov 28, 2012 | Electrolux E23CS75SS Air Conditioner
We have a Kelvinator No-Frost Refrigerator-Freezer Model N609PE and for the last week or so have noticed that it forms ice at the bottom of the freezer under the vegetable basked. It still works perfectly...
The drain in the freezer behind back lower panel
needs opening. You can see it at the bottom of the back panel
underneath the evaporator coils. (The cold coils)
Run Hot water in the drain until it clears or use a hairdryer.
When the defrost melts the water it goes down the drain
If the drain is clogged with Ice or ? The defrost water
overflows into the ref. or freezer or on floor
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
If you need more help GO HERE:
http://www.applianceaid.com/procedures.html
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME IF THIS WAS HELPFUL
Aug 21, 2011 | Kelvinator Refrigerators
I have an older model kelvinator dishwasher and there is water in the bottom of the dishwashwer and the diswasher will start and then stop but will go through all of the cycles. It just doesn't do the...
Pull the dishwasher out of the slot. There is a motor underneath that runs the pump to drain it. The usual cause is the it has a bad connection.
May 28, 2011 | Microwave Ovens
Does Whirlpool air conditioner # ACS088GPW has a drain hole ?? Its a window mounted vertical unit. i have more than 2 " of water in the unit. I dont see any drain holes and i am thingink if i should drill...
theres one near the back side on the outside part,they get plugged with bugs,leaves,debris,etc.,when its shut off look underneath and there is a drain hole on the bottom or on the rear ledge on either corner or both rear outside corners,make sure the unit has a slope toward the outside so most of the water drains there too,you can use a short piece of wire to clear these drain holes,if they are dirty enough you may need to unplug the unit and use a garden hose to dilute the debris so it flows out the drain holes
Aug 04, 2010 | Whirlpool ACQ062XJ Air Conditioner
Ok so I need to know how to stop the water coming out of the back of the AC I want to see how I can drain the water PLEASE HELP MEEEEEEEEEEE
ok the air con must release water as its condensation there should have been a small rectangular tray that came with the air con it attaches to the underneath left hand corner with a small bit of pipe that can connect to a peace of hose and run down the wall to a good drainage area
good luck
Jun 25, 2010 | Goldstar KG6000R Window Air Conditioner
I've got an error 1 message on my Kelvinator air
Here is a Toll free number to Kelvinator. Good Luck!
Technical Support Center - U.S.A. 1 (866) 738-1641
Monday - Friday
8:00 am - 6:00 pm EST
Nov 13, 2009 | Heating & Cooling
What is wrong when my airconditioner, starts up, after a little while water starts fo come out the louvers, then after a whileI noticed that it was leaking underneath air conditioner, and water had...
there are drain holes in the tray at the bottom of the unit that should allow the water to drain outside, see if these holes are plugged or if the unit is not mounted level.
Aug 12, 2009 | Heating & Cooling
Mitsubishi Air Conditioner FDKN Series leaks water after 30 mins
It could be one of two things -
1) The unit is not hanging level (assuming this is a wall mount, through the wall, or window unit), or
2) The condensate drain or trough to the drain is plugged/clogged/filled with trash.
Jan 22, 2009 | Heating & Cooling
Heating & Cooling Logo
41 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
