I have tried these steps does not work - Computers & Internet
I connect in lan but lan showing limited connectivity or no connectivity
hi ...
Try with the following steps...
Step 1: Connect modem>>router>>computer
Step 2: Check with the light status
Step 3: Made a hard reset for 10 sec
Step 4: If still working made a network power cycle ie)unplug the power cable both from the modem and also from the router hold it for a min and then replug it
Step 5: Try with different slots
Step : Try with different cable
Thanks ....
With regards....
Priya
Oct 22, 2010 | Computers & Internet
Tip
8 Steps to Fixing Any PS3 Issue
Note: If your PS3 is on, but you are looking at a blank screen, you PS3 may be in HD mode.
  • Turn off your PS3.
  • Hold down the power button for 2 beeps. This will reset your PS3 video to standard output.
  • If you are unable to reset your video, skip to Step 8.
  1. Back Up your PS3. You will need a compatible external hard disk drive for this step.
  2. Enter Recovery Mode.
  3. Choose "System Update".
    Try to load a game or movie. If it works, skip the rest of the steps listed below; otherwise, continue.
  4. Re-enter Recovery mode, and choose "Restore Default Settings".
  5. Re-enter Recovery mode, and choose "Restore File System".
  6. Re-enter Recovery mode, and choose "Rebuild Database".
  7. Re-enter Recovery mode, and choose "Restore PS3 System". WARNING!: This option will delete everything on your PS3 hard disk drive!
  8. Return the unit to Sony. If your PS3 is still under warranty the fix will be free; otherwise it will cost $150.
on Mar 26, 2010 | Sony Playstation 3 (PS3) Console
Everything has been checked out. and is working. now is time to see if it is the router. I can get on line only if I conect with cable. no wireless. It was working.
Hi fine so i do understand u are able to go online wired but not wireless....just try these steps
Step 2: Open the browser page and type http://192.168.2.1
Step 3: Towards the left coloumn click on channel and ssid below wireless
Step 4: Change the channel to 11
Step 5: Assign ur own ssid name-any name as u prefer
Step 6: Checked broadcast ssid is enabled or checked
Step 7: Then apply changes
Step 8: Then click on the security below channel and ssid
Step 9: Select the security type as 64 bit wep
Step 10: Type any 10 numbers make note of those nos thats ur password
Step 11: THen disconnect the connection between router and laptop
Step 12: Tried scan and connect
Step 13: U wiil see the network created by u select that and connect
It will surely work out
Aug 21, 2010 | Belkin Wireless G Plus MIMO (F5D9230-4)...
I have tryed forwarding the key ports I've tryed the dmz none of this works my nat settings are strict and i can barely conect to anyone on xbox live!?
PS3 And XBOX :: BELKIN
Step 1:Connect Modem - Router - Computer (Wired)
Step 2:Open Router Setup by typing http://192.168.2.1 on the address bar of internet explorer
Step 3:On the Left click firewall
Step 4:Leave the Password blank and click submit
Step 5:Disable it and click apply changes
Step 6:Scan and connect in the Xbox/PS3/Wii
Step 7: Get the IP Address of the Xbox/PS3/Wii
Step 8:Open Router Setup in the Computer
Step 9:On the left under Firewall Click DMZ
Step 10:Enable the IP Address of the Xbox/PS3/Wii in it
Step 11:Click Apply Changes
Step 13:On the left Under Utilities click System settings
Step 14:Scroll down to the bottom
Step 15:Enable UPnP
Step 16:Click apply changes
Step 17:Test the connection ,Check the NAT
If working then let me know
If it is still not working
Open Router setup
At the middle Under internet settings check the WAN IP
IF it starts with 192.168. or 172.16 Then you will have to contact your internet service and ask them to bridge the modem
Jun 18, 2010 | Belkin (F5D8231-4) Wireless Router...
Security lock on, need to remove.
Try This
Step 1 :Connect Router - Computer ( Wired )
Step 2 :Open RSP by typing 192.168.2.1 on the address bar of the internet explorer
Step 3 :On the left , Under wireless Click wifi protected setup
Step 4 :Leave the password blank and click SUBMIT
Step 5 : Disable it and click apply changes
Step 6 : On the left under wireless click security
Step 7 : Disable it and click apply
Step 8 :on the left under wireless click channel and ssid
Step 9:Change the ssid into a different name And click apply
Step 10 : Connect to this new name
Mar 29, 2010 | Belkin N Wireless Modem-Router F5D8633au4A
My ps3 does not load games or movies, screen stays still with the circular load symbol at the the top right corner, anything i can do at home to fix this?
Try this:
Mar 25, 2010 | Video Game Consoles & Games
Printer spooler wont work
You need to go to "services" and enable and set to automatic Click "Start"
Step 2 Click "Run"
Step 3 Type in "services.msc"
Step 4 Click OK
Step 5 Find Print Spooler in the list of services
Step6 Click "Start"
Step 7 Check "Automatic Start"
Feb 04, 2010 | HP 510 Notebook
Drops connections often, can't connect new pc running windows 7 (worked to access internet once for 2 minutes, now no connectivity), says DNS server not responding, but all other pc's are connected
Try Assigning A Static DNS Address on the Computer
Step 1 : Open Control Panel
Step 2 : In it Open Network and Internet
Step 3 : Open Network and Sharing Center
Step 4 : On the Left Click Change adapter Settings
Step 5 : Right Click on the Local Area Connection and Select Properties
Step 6 : Highlight Internet Protocol Version 4 TCP /IP V4
Step 7 : Select Properties
Step 8 : On the Bottom half Select Use the Following DNS Address
Step 9 : Assign the Following Addresses
Preferred : 4.2.2.1
Alternate : 4.2.2.2
Click OK And click Close
Now Try It
And Let Me Know If it Works
Jan 14, 2010 | Belkin Wireless G Plus MIMO (F5D9230-4)...
No connection to Insigna Blue Ray
Step 2 : Open RSP By Typing 192.168.2.1 on the address bar of internet explorer
Step 3 : On the left side click firewall
Step 4 : Leave the pass word blank and click submit
Step 5 : Disable it And click Apply changes
Step 6 : Restart the router
Step 7 : try connecting to the wireless
Step 8 :If not working try disabling the security
Dec 27, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
V tech new item..motion console..worked..turned it off turned it on..wont work
make surt you did the steps in the right order. Start with the TV and Vsmile OFF.
step 1) put the cartridge in and make sure it's all the way in
step 2) turn the TV on
step 3) turn the Vsmile on
if it still doesn't work, try taking the batteries out or unplug the adapter to let it clear and then try the steps again.
Nov 23, 2009 | Vtech V.Smile TV Learning System
Computers & Internet Logo
19 people viewed this question
David Payne
David Payne
