Question about Schumacher Electrical Supplies
I have a old schumacher battery charger SE-250-30 and need a switch #644-101000, 25A. 277 VAC, 1hp 125 vac 2hp 277 VAC, 35A mas com term. Can I get an equal?
  • 152 Answers
SOURCE: Schumacher 2/10/50 amp charger,125/225 amp starter
It could be an internal fuse, or that the transformer is malfunctioning.
Before any dis-assembly/internal inspection, be sure that the unit in unplugged.
Good luck...
Posted on Feb 25, 2009
  • 323 Answers
SOURCE: need manual
So to this site and download it.
http://manuals.batterychargers.com/manuals/00-00-000496.pdf
Posted on May 28, 2009
SOURCE: battery charger- schumacher se 4020
Century Tool and Equipment. $3.99
http://www.centurytool.net/SE_2158_Schumacher_Battery_Charger_Parts_List_s/30946.htm
Posted on Sep 03, 2009
SOURCE: Low voltage only or can timer be used for 110 v
The specs you wrote above are for high voltage.
125 vac = 125 volts alternating current = high voltage
250 vac = 250 volts alternating current = high voltage
110 v = 110 volts alternating current = high voltage
110 v is just another name for 125 vac -- it's called the "nominal" voltage.
So, the answer is yes, this timer can be used for "110 volt lights".
A 60 watt incandescent bulb pulls 1/2 amp when connected to 120 volts -- the spec for your timer looks like is 20 amps @ 125 volts tungsten (tungsten is the filament in incandescent light bulbs) --
I say looks like 20 amps because it's not clear which amperage goes with which voltage. Here are both calculations:
- 10 amps divided by 1/2 = 20 bulbs
- if it's 20 amps: 20 amps divided by 1/2 = 40 bulbs.
Charlie
Posted on Sep 30, 2009
  • 30 Answers
SOURCE: The door switch has failed and must be replaced.
In Canada B & E industrial electronics (Calgary) carries the switches typically used for microwave doors (~$5). Reliable parts carries the whole assembly of 3 switches and the plastic interlock housing for about $25. Probably worth calling your local industrial electronics supplier. Never purchased online but should be available from any online electronics reseller. Honeywell is another manufacturer (see Microswitches)... HONEYWELL HIGH FORCE PIN PLUNGER 15A Part # V71C17D8
Allied Electronics Online (US) carries the same switch which is interchangable with yours. Honeywell / MicroswitchSwitch, Miniature, Basic, SPDT, PIN PLUNGER Actuator, QUICK CONNECT TERMINATION
(Are you getting all these numbers off the switch itself as the OMRON RE2 sounds a bit like a relay number...?)
Posted on Oct 21, 2010
Do you have a wiring diagram for a Schumacher se-1010-2 battery charger?
What did you find on Google and forum sites are also a great sourse of information.
Sep 16, 2014 | Schumacher SE-1010-2 12-Volt 10-Amp Dual...
Schumacher charger parts
Probably not worth repairing. Meaning, the cost to repair will most likely exceed the value of the charger.
Sep 04, 2014 | Schumacher SCUSE826 SE-82-6 6 Amp 12V...
Manaul for schumacher battery charger model se4020
Your battery charger supplier or manufacturer should be able to supply you with an operating manual.
Aug 14, 2014 | 10/40/200 Amp 6/12-Volt Manual Battery...
Wiring diagram se-4020 battery charger
try this web site
http://www.manualslib.com/manual/523935/Schumacher-Se-2254.html Schumacher SE 2254 Owner Manual
Feb 08, 2014 | 10/40/200 Amp 6/12-Volt Manual Battery...
I need to see how the wires go inside a Schumacher SE-1052 battery charger.
Most likely that is not the case. Battery chargers that are not really old have current sensing and dont switch on unless there is a load attached to it. A totally dead battery wont be seen by the device and it wont charge it.
Jun 12, 2013 | Schumacher SE-1052 2/10/50 Battery Charger...
I would like to know what wattage can the SS8 series handle??
Intermatic SS8 Instruction Manual says:
The timer can control incandescent lights, fluorescent lights, flood lights (PAR lamps), stereos, or appliances such as an air conditioner. The timer can also control many loads 12 to 277 VAC and 12 to 28 Volts DC.
Intermatic Load rating pdf shows SS5 at 500Watts and no HP rating.
Load rating pdf shows SS7 and SS20 rated for 15Amp, 120V-1HP, 240V-2HP.
Load rating does not show SS8, but since SS8 manual shows 'appliances and air conditioner,' and same load parameters shown for SS7, then Amp and HP rating would have to be same-similar to SS7.
http://waterheatertimer.org/Intermatic-timers-and-manuals.html#ST01C
http://waterheatertimer.org/pdf/Load-ratings-for-Intermatic.pdf
Aug 05, 2011 | Hardware & Accessories
Need manual for schumacher se-60 battery charger
May 25, 2009 | Schumacher & Fast Charge Starter Charger
1 hp= 750 watts
125 vac = 125 volts alternating current, wall outlets
5 amp= 5amps
125vac x 5amps= 625 watts
a timer is a switch with a clock on it. just like a switch in a lamp cord.
Dec 12, 2008 | Hardware & Accessories
Electrical Supplies Logo
276 people viewed this question
Top Schumacher Electrical Supplies Experts
D. E. Hev
Are you a Schumacher Electrical Supply Expert? Answer questions, earn points and help others
