Question about RCA Audio Players & Recorders
My RCA audio system shelf does not power on. I changed outlet and check for a defective fuse but to no avail. Any suggestion? It's a RCA 300WATTS 5 DISC AUDIO SYSTEM RS2767I
  • RCA Master
  • 5,348 Answers
Could be an internal fuse in the power supply area. Follow the mains cable. However the fuse blowing could be the sign of a fault. If it blows straight away again there is a fault.
Testimonial: "Thanks."
Willnot turn on, power is on
If it has a fuse check it, if bad replace it.
Oct 11, 2014 | RCA 100-Watt Stereo System With 5-CD...
No power
there should be a power down DC board that will supply dc voltage to the electronic components i think your problem can be found there
Apr 16, 2014 | RCA RS2622 CD Shelf System
Disc compartment will not open
Stretched rubber powered opening mechanism.Change the rubber.
Dec 08, 2013 | RCA RS2041 Neo-5 CD Changer Audio System...
I came home one evening and my system was off. I tried plugging it into different outlets and still received no power to my system. What could be the problem and how can I fix it?
hello, see if theres a power save buttton on the unit if not check the fuse in the plug if ok then the fuse inside the unit may blown. it may be glass type fuse it will be in the power supply if you can't see 1 then there may be a soldered in fuse called a wickman fuse fingers crossed
regards
shaun
Nov 27, 2010 | RCA RS2656 Shelf System
RCA,model number RS2652B NO power
check the cord or try a new one.if not you need to open the unit and look for blown up fuse.
May 08, 2009 | RCA RS2652 Shelf System
DEAD??!!
check the elec outlet & the unit plug and wire connections.
Aug 16, 2008 | Aiwa XR-MS3 Shelf System
5 CD Changer won't work
my rca 5 cd changer skips on all cd's?
Jun 26, 2008 | RCA 100-Watt Stereo System With 5-CD...
Power will not turn on
Power supply is the most likely culprit....check the internal fuses.
Feb 26, 2008 | Nakamichi SoundSpace 5 Shelf System
RS 2654 RCA
I would say it's the main power supply. Try looking for a short in there using a multimeter
Nov 13, 2007 | RCA RS2652 Shelf System
No Sound
First of all the obvious - Do not open up the system unless: 1. you have some experience with electronic repair. 2. you're out of warranty. If under warranty or over your head you can still try connecting the system to a known working speaker, just to rule that out. Other wise take it back to the shope you bought it from, or consult a repair person. If both 1&2 apply to you check the following suggestions: 1. Feed in a signal, as such from an audio generator, and follow the signal path with a scope. Where the signal stops, is your dead area. 2. Take care that you properly check the power supply. Use a scope to see where the audio signal stops along its path to verify. 3. The output IC is most likely defective, and some of its support components along with it. You have to try the IC to test. If the cause of it blowing is not fixed, the new one will blow right away. 4. there is a transistor on the main board which goes bad on these. Near the center of the board, you'd see the overheated area. 5. RCA has a nack of using low value resistors as fuse devices in these sets, when an output device fails or overloads it normally will open the associated resistor (fuse). Fix it and crank it up ;]
Jan 25, 2006 | RCA RS2635 CD Shelf System
57 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
