Question about Element Televison & Video
How do I go into my element tv and shut the speakers off so that I can see is the sound bar will work that way
    Top Expert:
  • Element Master
  • 45,120 Answers
You may be able to turn off internal speakers by returning to the initial set up procedure.
I have a LG TV 47LD650 that has picture but no sound out of tv speakers. If I connect an optical cable into the output and use a sound bar, will it still produce sound?
You have to go to setting and change the audio output to TV speakers for the TV speakers to work,, but, if you use a sound bar with optical connection...you have to set it also .. mine works the same way,,
Jun 19, 2017 | LG Televison & Video
How do I check if my element 40" internal speakers are on/off and if it may be set to sound bar only? I didn't see that in the manual anywhere then again the manual doesn't explain much of anything.
The initial set up procedure may have an option for turning internal speakers off and on. If set to off, audio output is directed from the rear of the TV to the inputs of the sound bar.
Dec 09, 2016 | Element Televison & Video
Need to hook up sayo sound bar to my elment tv and my dvd player together
Help me connect my soundbar to TV, DVD, and Cable ...
www.tomsguide.com/answers/id.../connecting-soundbar-dvd-cable.html
Jan 2, 2015 - I want to connect my soundbar to give sound from my dvd player and cable box. ... More about : connecting soundbar dvd cable ... SolvedHow do I connectmy Element ELEFW392 TV to my Insignia NS-SB314 soundbar.
How do I connect my sound bar to the TV, BluRay, DVD, and ...
www.tomsguide.com/answers/.../connect-sound-bar-bluray-dvd-dish.htm...
Dec 30, 2014 - Then connected Panasonic Blu Ray DVD player: Panasonic HDMI to TV... pretty hook them up and it works' followed by 'why did you buy a sound bar?' Do Ihave to connect sound bar to TV AND Dish receiver? and not to DVD? ... tv bluraysound bar and a DVR cable box together Forum; Solvedconnecting ...
Soundbar to tv [Solved] - TV - Streaming Video & TVs
www.tomsguide.com/answers/id-2198401/soundbar.html
Jan 11, 2016 | Televison & Video
No to hook sound bar to element TV and my DVD player at the same time
Jan 2, 2015 - I want to connect my soundbar to give sound from my dvd player and... The soundbar has an optical cable option, but my tv does not support that cable. ...SolvedHow do I connect my Element ELEFW392 TV to my Insignia ...
Dec 30, 2014 - Then connected Panasonic Blu Ray DVD player: Panasonic HDMI to TV... first time, that paired the sound bar to the subwoofer but still no sound. ... Do I have to connect sound bar to TV AND Dish receiver? and not to DVD?
Jan 11, 2016 | Sanyo Televison & Video
Sound Appeal sound bar set up. Not getting sound from tv except tv's speakers. Help!
You have to check the sound setting of your tv. In most of the lcd tv there are two option that you can select. Internal speaker of the tv and external speakers while using sound bars or other amplification devices. Fist of all Check that setting. Check the link bellow to understand How to setup a sound bar to your tv.
http://electro-medical.blogspot.com/
https://www.youtube.com/watch?v=QQ3zFnnsiMs
Dec 27, 2015 | LG Televison & Video
Sound bar does not work with tv
You are not the only one with this problem!
Try plugging some other speakers into the soundbar and seeing if that works.
If it does, then the problem could be in the TV - its internal speakers may need to be turned off first; and/or check you are connecting with the right socket eg: 'Output'. on the TV. Read the manual!
Mar 05, 2014 | Element Skateboards Element 46" Class...
How to hook up the sound bar and subwoofer to tv
everything is hooked up correctly tp element tv
but no sound
Apr 25, 2011 | Vizio VSB210WS Soundbar
INSIGNIA TV WITH ILIVE BAR. 1 SIDE WORKS
Try swapping your cables from the sound-bar to the TV. If the sound still only plays through one channel but the channel has changed from right to left or vice-versa, then you have a bad cable.
If the performance is the same, connect a different device using the same cables to see if it's the sound bar input or the TV output.
Once you know where the problem is (the sound bar, the TV, or the cables) you'll know what unit needs repair or replacement.
It is entirely possible that a solder joint for the sound-bar has come loose. A soldering pen would easilly fix this if it's a bad joint/connection.
Hope this helps!
Dec 25, 2009 | Insignia 200W Stereo Receiver
I just bought a Element 32LEOQ and the sounds goes off after 15 minutes
Try hooking up the powered PC speakers to the Audio line output RCA jacks, if the sound does not cut out, then the problem is in the power amp sections that drive the speakers, it may be over heating and shut itself off, most Class D amplifier are used in the flat screen TV will shutdown if it is over heating or short circuits.
Nov 01, 2009 | Element Electronics FLX3220F 32 in. LCD TV
Televison & Video Logo
161 people viewed this question
Top Element Televison & Video Experts
Are you an Element Televison and Video Expert? Answer questions, earn points and help others
