Question about Samsung Televison & Video
On the Samsung 55 inch 4K television when the close caption is on the top of the screen that gives channel information blinks on and off. When the close caption is off it does not. Any suggestions.
SOURCE: close caption
You need to turn on closed captions through the menu of your PVR. To have it on all the time, turn the box off, press menu on the front of the box, and scroll down to captions.
This should fix the problem
Posted on Mar 10, 2008
crlee3
SOURCE: Closed Caption
Yeah, I'm now believing it's the tv. The captions on the other tv in the house work great. My samsung is only 2 yrs old. This model was 1080 i...Kinda of costly. Still no solution???? CR. LEE
Posted on Sep 08, 2008
  • 85 Answers
SOURCE: Unable to remove the closed caption through the
I dont know what model you have i see two on there website. i read manual for one of the 42 inch lcd tvs and i do see where you confirmed you said off to closed caption mode am i correct? Ok try this turn the closed caption on and exit menu. now shut off tv and turn it back on. now go into menu and turn closed caption mode to off now and exit menu and see if that helps. ok i hope this helps ....oh i forgot to mention make sure that you didnt enable the closed captioning on your cable box remote. Just might want to check with that. It might not be your tv at all it could be the cable boxes closed captioning service. I hope some of this helps if not see if there is a factory reset in the menu.
Posted on Feb 20, 2009
  • 304 Answers
SOURCE: Samsung LCD tv no sound from one channel only, no
First try viewing regular programming and see if you have audio on both channels. If you do not then go to the user menu and make sure that the chim function is turned "on". Then turn off the tv and listen for the down chime coming from both speakers. If you only hear the chime from one speaker then the Aidio circuits are bad on the Main bd and needs to be replaced.
Posted on Jul 16, 2009
bshldn
  • 736 Answers
SOURCE: 2008 Samsung 32" Flatscreen 720p Channels are
The cc has been enabled on your cable box. Usually there is a hidden menu accessed by turning off the cable box. Yes I did say turning off the cable box first. Then immediately pressing the menu button on the front of the cable box. The hidden menu should pop up and one of the menu options will be closed captioning,. Disable it.
Posted on Nov 09, 2010
How do I turn off the closed captioning?
Press the closed captioning button a second time.
Mar 20, 2016 | LG 47LS4500 47 Inch 1080p LED LCD HDTV -...
How do I get closed captioning on a Samsung TV model TXJ2754?
Hello
Your TV displays the closed captions that are broadcast with some
television shows. These captions are usually subtitles for the hearing
impaired or language translations. All VCRs record the closed caption
signal and most pre-recorded commercial video tapes provide closed
captions. Check for the closed caption symbol in your television
schedule and on the tape's packaging: .
1 Press MENU repeatedly until you see the Setup menu. Press CH
to select "Caption."
2 Press VOL+ to open the Closed Caption menu.
3 Press VOL + to turn closed captioning on.
Misspellings and odd characters can occur in captioning. Also, there may be a
captioning delay after changing channels. Neither situation is a TV malfunction.
4 Press CH to highlight "Mode." Press - VOL or VOL + to choose
"Capt." (captions) or "Text." In caption mode, captions appear and
cover a small portion of the picture. In text mode, information unrelated
to the program, such as news reports, are displayed and
often cover a large portion of the screen.
5 If you wish, use CH , CH , or VOL + to change the captioning
channel or field. Then, press DISPLAY to return to normal viewing.
 Different channels and fields display different information, such as additional
languages or supplemental information
Nov 23, 2010 | Samsung TXJ2754 27" TV
I HAVE JUST BOUGHT A RCA 27 INCH TRUE FLAT TV AFTER HAVING IT FOR ABOUT 1 MONTH IT STARTS HAVING A BIG BLACK BOX ON THE SCREEN SO THAT YOU CAN NOT SEE THE PICTURE BUT YOU CAN CHANGE THE CHANNEL AND GET A...
Somehow you have enabled the Closed Captioning mode. Work your way through the menus to turn it off and the problem will be resolved. The channels that come in normally are not transmitting the closed captioning information, thus no CC black box.
Dan
Mar 28, 2009 | RCA TruFlat 27F520T 27" TV
Turn off channel caption on Sony 48 inch
There should be an option in the menue for closed caption set it to off.
Jul 28, 2008 | Sony KP-51HW40 51" Rear Projection...
Black screen keeps popping up
If a black box appears on the screen, and a small amount of the picture is visible around the border, it means that your closed captions are on and set to TEXT. Go back into the menu, navigate to the closed captions page and set the captions to OFF.
Sep 02, 2007 | Toshiba 50A50 50" Rear Projection...
Closed Caption
closed caption depends on your tv stations. If a tv station does not support providng closed captions, then it will not really show closed captions. Closed captions depends really on the feature of a tv station
Apr 14, 2007 | Samsung LN-R3228W 32 in. HD-Ready LCD...
Having a problem getting a picture
Im sorry to tell you this but it sounds like someone turned on the text feature on the closed caption? Go into the menu function, with the remote, and turn off the closed caption.
Sep 23, 2006 | Toshiba TP-55H64 55 in. Rear Projection...
Televison & Video Logo
29 people viewed this question
Henry  Thomas
Henry Thomas
