Question about Drills
Drill Presses - Need manuals for Rockwell 15-350. I found exploded parts diagrams. But not manuals.
  • 3 more comments
  • Jim Crosheck
    Jim Crosheck Jan 02, 2017
    Good answers. I had not connected the Rockwell and Delta models. Now left with one puzzle regarding the spring loaded sheave. I had assumed that this was similar to variable speed drives in snowmobiles ad ATVs. But the spring loaded sheaves halves are locked to the shaft with set screws. Which means no auto speed adjustment. Or am I missing something?
  • Vernon Taylor Jan 02, 2017
    I have not yet met a manual drill press with variable speed. The material being drilled is given a number into which the diameter of the drill bit and the number of cutting faces is divided in order to obtain the correct spindle speed. This is then selected from the table usually engraved somewhere on the machine and the drive belt is moved to the indicated steps on the stepped pulleys to select the nearest speed to that calculated.
    A basic machine typically has 8 speeds and a good jobbing machine has as many as 16 speeds, a 5/8 inch chuck and a number two morse taper. Bigger than that and the machine becomes an industrial rather than a jobbing machine.
  • Jim Crosheck
    The Rockwell 15-350 appears to be the same as the Delta VS6. Just looked at their manual and exploded views. As I said before, the spring loaded sheave should (my view) compensate its width for the changing width of the control end (dialed speed). Both sides of spring loaded sheave are fixed to shaft with set screws. Ideas?
    Firstly I didn't at first understand your reference to "sheaves". It would have been easier if I could picture what you are describing. The variable drive is probably achieved by variable pitch pulleys - one being arranged to have a mechanical (selective) control and the other being spring loaded. The mechanical control would vary the pitch of one pulley and the very tight drive belt would force the other pulley to reduce in size against the spring pressure.
    One half of each pulley must be free to move and change pitch in order to be a variable ratio drive. If this is not so perhaps the drive wasn't working and the extra screws are a modification or perhaps one screw is intended to be located in a keyway and secure the pulley while the other screw is intended to locate in the same keyway but slide along it as the pitch varies.
  • Jim Crosheck
    Your description is exactly what I expect as well. As I mentioned, the Delta VS6 manual is exactly the same as the hardware I have, but labeled as a Rockwell 15-350. The parts view shows set screws in both halves of the sheave on the motor. I suspect the prior owner messed with the drive since both shafts has rust from being in a barn. I am guessing the speed control end froze and then he locked it up by tightening the screw on the other side of the spring loaded sheave. I have the one shaft working so now I need to free up the other. Remove/loosen the unnecessary set screw and clean up the rust and I should be in business. Thanks for the input.
  • 4,483 Answers
Excluding industrial units, drill presses are very similar to each other and most of the low and medium price units are generic tools of far eastern origin so any simple set of instructions for any drill press will apply to most machines.
Mostly the drill press is an intuitive tool to use for anyone who has the slightest engineering experience so most manuals seem to be almost filled with safety information rather than any useful information. The useful stuff should be gleaned from more comprehensive manuals about engineering and workshop practice.
Does any know much about a Rockwell delta drill press model o-2140-a?
Rockwell Manufacturing Co. - Photo Index ...
vintagemachinery.org/mfgindex/detail.aspx?id=698&tab=4
02/24/2015, Jointer, 6" Short Bed Jointer, Model No. on Motor: JB82B710CW · 6" ...12/30/2014, Drill Press, Delta Rockwell Homecraft Drill Press 11-120 · 11" ...
Aug 27, 2015 | Delta Drills
Looking for diagram to put together a Rockwell drill model rc-2222.
I could probably manage it if you haven't lost any of the bits but I couldn't tell you how to do it.
Chances of getting a good diagram are slim but if you search for spare parts suppliers and find your model there is often an exploded drawing showing the rough order of most of the parts.
Feb 03, 2015 | Drills
Rockwell drillpress, model #15-069, S/N 1696907 How to reinstall return coil spring for down ward operating arm.
Hi wildoak1,
Welcome to fixya!
Found a forum where the guys were discussing various ways of installing the pinion return spring. Read down the page and you'll find where they start discussing it.: http://www.owwm.org/viewtopic.php?f=1&t=72586&p=507720&hilit=replace+pinion+return+spring+Rockwell#p507720
Hope this helps. If it does, I'd appreciate your vote. Keeps me working here......
Thanks,
Handie Andie
Jun 20, 2011 | Delta rockwell 15" Vs6 Drill Press...
There isn't a manual for our craftsman 21914 drill press. We need to know how to put it together.
Use this link to get to the Sear page showing exploded parts diagrams for your drill press.
http://www.searspartsdirect.com/partsdirect/part-model/Craftsman-Parts/Drill-Parts/Model-315219140/0247/0713080?searchedModel=21914&blt=
If you click on the tab to "search by part description" you can enter "manual", then you can order it for $2.16, it you still need it.
Good luck, Al K
Feb 02, 2011 | Craftsman 12" Drill Press (21914)
We own an old Rockwell International Model 15 drill and tap machine. The chuck needs to be replaced. Where can I purchase one?
Click here for a site that WILL have everything you need for that old work horse. Hope you have a fat wallet.
Aug 26, 2010 | Delta Rockwelldelta 15" Drill Press...
Where can I buy an, on off switch for a model 15 floor drill press?
That can be obtained direct from rockwell, or SearPartsDirect.com
Aug 08, 2010 | Delta Rockwell 15 Inch Utility Drill...
Removal of chuck
Harold, Have you tried looking from the top? Maybe you can put a rod into the spindle from the top and give it a tap. Al Kupchella
Apr 10, 2010 | Turner Walker-turner Rockwell 20 Inch...
Bent spindle in vintage drill press. Possibly Rockwell Press. 3 phase floor model
Remove spindle and take to a machine shop where they can use a dial indicator along with a press to straighten the shaft.
Nov 11, 2009 | Turner Walker-turner Rockwell 20 Inch...
I need a manual for a Delta drill press, Model 14-040. Could anyone help? Thanks, Gary
Unfortunately, an online manual for that model isn't available online from the delta site, but if you go here you'll at least be able to access an exploded parts diagram and list. Perhaps that will help.
If you really need a manual, take a look at this list and maybe there's something there you can use.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
May 22, 2009 | Delta 15 - 126 Drill Presses
Drills Logo
228 people viewed this question
Top Drills Experts
Are you a Drill Expert? Answer questions, earn points and help others
