I need the wifi code
I am trying to get on my laptop and need to connect to the wifi the pass word on the bottom of the router does not work
  • Computers & ... Master
  • 18,239 Answers
They are cAsE SeSITive.
If you are sure it is correct, you will have to Reset it, usually a small hole on the back. Then you set it up on the computer with a new password.
Posted on Jan 01, 2017
How do i change my password on my wireless wifi without having the plug in on my pc
Any device connected to your WiFi with the user account name and pass code can do so from the host address as it takes you to the login from your WiFi provider. In the browser of any device connected Emmett the following address:
If need be add the http:// in front. This is the common wireless router address of many routers. Linksys and Verizon and several it other use this.
Aug 18, 2014 | Dell Inspiron Computers & Internet
Need wpa2 pass phrase from belkin router for wifi x-box360 wireless connection.
We are not able to supply this pass code as it is shipped with the router. Take a look on the router itself and try and find a label on it that says something like "Encryption Key" or "Wireless Password". This will be the WPA2 key you need.
Jul 25, 2011 | Video Game Consoles & Games
I put in the wireless router and I'm able to access from my computer but I my laptop can't locate. What do I need to do?
Theencryption key secures your data from unauthorized access. The router's password is a Passphrase or the WEP or WPA orWPA2 encryption key. The Passphrase generates the WEP or WPA or WPA2 encryptionkey and this is in the router's wireless settings. To connect to your wireless router, configure the router'swireless settings ie SSID, plus the WPAor WPA2 encryption key and then configure wireless cards in the laptops and orcomputers with these router's wireless settings. Then the laptops and desktopcomputers can communicate with your wireless router.
Jun 29, 2011 | Linksys Wireless-G WRT54GS Router...
My laptop usually has no trouble connecting to a wireless router. I have just tried to connect to a friend's Belkin *which is not locked" and it asks me for a pin code - got the pin code of the bottom...
To connect to the network in your laptop without entering a PIN code, please follow these steps.
1. Connect the computer to the router with an ethernet cable in one of the grey slot in the router.
2. Open up internet explorer and clear the address bar and type in and hit enter.
3. You will find a belkin router setup page, In the left hand side under the heading Wireless click on Wifi Protected Setup
4. When it asks you for a password leave it blank and click on submit.
5. There change Wifi Protected setup to disabled and click on apply changes.
6. Then in your laptop connect to the wireless network without any PIN number.
Thanks in Advance!
With Regards,
Jan 10, 2011 | Belkin Computers & Internet
Not able to connect wifi in my lapopo
In connecting through a wifi, there are two factors to consider. (1) Wireless Router broadcast and (2) Wireless Receiver.
Make sure that your network router is broadcasting wireless internet or wifi. Also, you have to know if you need a pass key or password in order to connect to the wireless network.
Now, given that there is a wifi spot, your laptop should automatically recognize the wifi broadcast and negotiate connection without your intervention. This will only happen IF AND ONLY IF your laptop has a wifi radio receiver and that it is TURNED ON. When it is turned ON, it will connect you immediately if the network has no pass key set. If there is, then you have to enter that key when you try to manually connect it. (Right click on wireless network icon on system tray. Then it should say: Wireless Network Available. Then Click CONNECT)
To turn your wifi radio receiver ON, slide a switch button to ON position depending on your laptop model. If you dont have that kind of switch, look for the wifi icon printed in the keyboard keys. In some laptop, it is in F2. Now Press FN+F2 to turn wifi radio receiever ON and OFF.
Feb 04, 2010 | Toshiba Satellite A100-S8111TD Notebook
Ibook wont log onto my network
I ran into this with my home network and my old g3 ibook needed the older speed wifi to connect. I found my old wifi router, hooked an ethernet cable to the newer router (in a regular ethernet port) and connected the other end to the internet port on the old one... they linked and worked fine to provide wifi for the old G3's ..
Dec 19, 2009 | Apple iBook G3 Mac Notebook
Cannot connect to internet with konaki netbook
How to Connect a Laptop to a Wireless Router Using a Windows Operating System
Follow the router's manual to set up the router and its Internet connection , which will probably require connecting a wired client to the router. Once the wireless router is set up, the wired connection is no longer necessary. However, it's best to leave the wired client connected if it's a separate computer from that on which you're going to set up WiFi. If something goes wrong, you can access the administration interface again.
Gather information from the setup process. In order to set up the wireless client, you will need to know the service set identifier (SSID), the Wireless Encryption Protocol (WEP) key and the channel and mode.
Boot up the laptop and plug in the WiFi card. This will not be necessary if your laptop has an integrated WiFi card.
Install any drivers needed to use the WiFi card. Insert the disc that came with the WiFi card and follow the on-screen installation process. Most discs will trigger a new hardware wizard that makes installation extremely simple.
Double-click on the "WiFi Connection" icon. It can be found in the system tray at the bottom of the laptop screen.
Click on "Properties."
Select the "Wireless Networks" tab.
Use the "Add" button at the bottom of the dialog if your WiFi network isn't in the "Available Networks" section.
Click on "Configure" when you see your network's SSID in the "Available Networks."
Enter your network's SSID and WEP key.
Click on "Start," then choose "Connect To" and "Wireless Network Connection." Your computer should now be able to access the WiFi network. If the WiFi network is connected to the Internet, it should also be able to connect to the Internet.
Dec 12, 2009 | Computers & Internet
I'm trying to connect to internet via wifi and it's asking for a device password. what is that? this is a d430 dell.
I suspect the device that is asking for a password will be your wireless router. Normally, the password, or key, is printed on a label on the side or bottom of the router.
Nov 21, 2009 | Dell Latitude D430 Notebook
Connecting PSP to wifi
Change the primary DNS of your PSP to and secondary dns to
Apr 25, 2009 | Linksys WRH54G Wireless Router
Hi, I am trying to connect another laptop to our wifi but when i enter the netgear pass code it does not regonise it. Any ideas?
The router's passcode is a different thing to the WEP/WPA encryption code.
Type into the internet browser of a computer that has access to the router and disable the WEP/WPA encryption, and press Apply or Submit.
Now Enable it again and it'll ask you to choose a password. Put something in and Submit that. That password is what you would put into the other laptop to connect.
Hope this helps
Chris (ziraffa)
Dec 31, 2008 | D-Link DI 514 Wireless Router (DI-514)
Computers & Internet Logo
26 people viewed this question
David Payne
David Payne
