Question about Coffee Makers & Espresso Machines
The steam wand on my Brevile barista express works, but no water comes out the water spout.
SOURCE: steam wand not working
When I got my X1 (used,) the steamer was clogged. I unscrewed the end of the nozzle, and a big chunk of calcium(?) came out. I had to poke it with some wire with the steamer on. The way I got the end off is: I wrapped it with a leather glove first, then turned it with a pair of pliers. I still managed to scratch it a little bit though. Maybe you can turn it by inserting a needle in the little hole on the side of the nozzle. I've been thinking of using distilled water to avoid the calcium build-up in the future.
Posted on Oct 08, 2008
SOURCE: miele steam wand doesn't work
hi i have the same problem as listed no steam . pump make the noise but no steam some time a drip of water thans 07764308535
Posted on Nov 01, 2008
SOURCE: barista athena
I have just had a similar problem. Water no longer moves through the steam wand when I try to prime it. Instead, water shoots through the shot handle (or screen if handle is not in).
One thing I did notice is that the dial for the steam wand unscrewed too far and basically popped out. I screwed it back in and the water did not ever come out of the wand again. I took the top lid plate off and unscrewed the wand dial and removed it. I put it back and noticed that there is a little metal spring switch underneath that I assume turns the wand pump on.
Attached to the dial is a plastic sleeve with a flat side. When the dial is turned, this sleeve should turn the switch on. I noticed though that the sleeve is creeping up the shaft towards the dial head which makes it miss the spring switch.
I don't know what kept the sleeve in place before. Probably a plastic stop that has been worn away from use. There is an allen screw in the sleeve, but tightening it doesn't seem to keep it in place. Perhaps inserting a spring in between the dial and the sleeve would work, but the sleeve cannot be taken off to do this. No other answers right now. My wife is not happy the lattes have dried up.
Posted on Nov 07, 2008
SOURCE: Starbuck's Barista steam wand leak
remove the cover from the machine, loosen the allen screw that fastens the steam knob to the shaft, move it slightly and retighten to allow the knob to close the valve a bit more. I have had to do this a few times in the 9 years I've had my machine as either the knob loosens or the valve threads wear a bit.
Posted on Mar 03, 2009
  • 14 Answers
SOURCE: Starbucks Barista Espresso Maker
This is a general comment for people having problems with leaks and pressure in their espresso machines. If you do not used filtered water, the minerals and other materials suspended in the water will bond to the moving parts and tubes of your machine (e.g.: scale). The problem will be worse if you live in an area with particularly hard water. In some cases the pressure pipes can get completely blocked and if the pump is powerful enough, the pipes can rupture, otherwise, the pump will simply not put out any water. The solution is to regularly flush out the system with descaler. The frequency of cleaning depends upon how often you use the machine. You can get descaler from any decent coffe place (like Starbucks), an appliance repair place, or the hardware store. I use CLR which is sold at hardware stores. CLR stands for Calcium-Lime-Rust, and it effectively cleans all of these and is cheaper than specialty scale removers. Simply dilute some in water and pour the mixture in the machine, then cycle the pump and run it through. Collect the spent liquid and run it through again 4 or 5 times (or more if you've never cleaned your machine before...) Allow the liquid to sit for 10-15 minutes between flushes so that the solution has a chance to eat away at the scale. Once you have done this a few times, flush out the machine thoroughly with clean water 4 or 5 times, using CLEAN water each time you rinse. If you want to get an idea of the scale that has been removed, keep a small amount of the original clean solution in a glass and then compare the spend cleaning liquid with unused cleaning liquid to see the difference. The spent liquid should be foggy/muddy compared to the clean stuff and if you let it sit, the scale will settle to the bottom of the glass and will be clearly visible. You can prevent some of the buildup in your machine by using filtered water as they do at Starbucks.
Posted on Jun 05, 2009
Water will not come out
Helpful Hints ' Home Espresso Repair
www.espressorepair.com/helpful-hints/
Why isn't water coming through my espresso machine? ... clean, waffle side up, smooth side down, and that the water hose is not crimped. ... After one cup of waterhas flown through the brew head and the steam wand, the vapor lock will be fixed. ...When the ready light comes on again, turn the steam knob open to release ...
No water out of the brew head - Starbucks Barista - iFixit
Dec 28, 2015 | Coffee Makers & Espresso Machines
My brevile cafe roma coffee machine wont operate the steam through the spout to froff up my milk.
hi there, it sounds like the steam wand is blocked up...see page 11 of the following PDF that is for your machine. also see the cleaning section of that same PDF. Notice the "decalcifying" section. http://www.brevilleusa.com/media/mediaappearance/4553/ESP8SXL_IB_C11.pdf
Hope this helps you!
Jun 11, 2012 | Breville CM5 Espresso Machine & Coffee...
I have a starbucks barista athena that has a vapor lock. How do I fix this?
It's easy to break the vaporlock on an Athena.
  1. Power the machine off and let it cool (20-30 minutes is plenty)
  2. Place a mug under the steam wand and open the steam valve all the way. If there's residual pressure, let it release the pressure before proceeding
  3. Power on the machine and wait for a steady stream of water from the steam wand.
  4. Close the steam valve and you should be good to go!
Jan 14, 2011 | Estro Barista Athena
Can't get steam from the a Starbucks Saeco Italila Digital Auto
Hi If you can get water to flow from the wand, you can descale the machine. You might have a bad steam boiler. There is also a fuse on the boiler that might be bad. Set your water hardness to 4 to keep the machine working for a long time. Descale more often than not enough.
Jan 26, 2010 | Starbucks Saeco Italia Digital Barista...
The two coffee lights and the water light are flashing
Had the same problem. I sealed my lips around the steam wand and sucked as hard as I could, first with open steam knob, then with closed. Obviously there was some air left inside from steaming before. Machine worked fine afterwards.
Nov 30, 2009 | Starbucks Saeco Italia Digital Barista...
No water flowing through steam wand
You might want to try draining the machine and filling it back up. There could be a number of different things wrong with your machine.
Mar 21, 2009 | Starbucks Barista Utopia
Barista athena
Aug 13, 2008 | Estro Barista Athena
Miele steam wand doesn't work
May 13, 2008 | Miele Coffee System
Coffee Makers & Espresso Machines Logo
Top Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
