Question about Health & Beauty
Nine blink code on golden companion four wheel scooter
  • Health & Beauty Master
  • 1,049 Answers
Hi FLASH CODE #9 . Controller fault .. Cheers
Posted on Jan 01, 2017
  • 13 Answers
SOURCE: golden companion 2 scooter moves slow in reverse
i would suggest there is either a loose connection or the speed control has failed, the scooter will still run but at a slow speed, the part is fairly standard in all scooters. if i can be any furthur assitance please email me rick @ (remove the spaces)
Posted on Jun 18, 2009
  • 32 Answers
SOURCE: how do I find year model of my Golden Companion scooter?
Posted on Jul 12, 2009
  • 32 Answers
SOURCE: moving problem
More than likely its the speed pod or engager (paddle assy. This would need to be replaced.
  • 177 Answers
SOURCE: Golden Companion Scooter not moving - diagnosed via owner manual
Hi. Many scooters will display this fault code if the potentiometer is not exactlly centred when you turn on the key. The pot is not always faulty. Some scooters also have a smaller additional pot to controll the speed. If this pot is faulty it will cause the same fault code. Any other switches such as indoor/ outdoor switches. I have had a few machines fitted with curtis controllers where the fault is in the controller.
Check the wiring and plugs and connectors.
Good luck. Neil.
Posted on May 30, 2010
  • 692 Answers
SOURCE: i have a golden companion
The L.E.D. located on the tiller
dashboard will indicate with flash codes what problem is occurring.
L.E.D. Flashes 1 time and pauses, 1 time and pauses…. Batteries are low,
scooter will still operate.
L.E.D. Flashes 2 times and pauses, 2 times and pauses…. Batteries are very
low, scooter will not operate.
L.E.D. Flashes 3 times and pauses, 3 times and pauses….Over voltage to
L.E.D. Flashes 5 times and pauses, 5 times and pauses….Brake is in the
freewheel position or connection to brake is open.
L.E.D. Flashes 6 times and pauses, 6 times and pauses….Paddle or speed
potentiometer problem.
L.E.D. Flashes 7 times and pauses, 7 times and pauses….Paddle or speed
L.E.D. Flashes 8 times and pauses, 8 times and pauses….Motor
disconnected or faulty.
L.E.D. Flashes 9 times and pauses, 9 times and pause….Controller fault.
I hope this helps they are pretty standard codes I got this from Golden Tech Web Site
Posted on Aug 18, 2010
I have a Golden Companion 2 three wheeled scooter. The motor will not engage while sitting on the ground. When I put the rear wheels up the motor engages fine and runs fine.
hi check youre batteries when u have it of the ground there is not much current drain on the batteries when its on the ground it takes a lot more current to move it......try and get them load tested.good luck
Sep 05, 2015 | Golden Technologies Golden CompanioN II -...
I have a golden companion II 3 wheel scooter with new batteries, the problem isafter a complete charge the scooter starts off fine but gradually loses power as indicated by meter in 5 to 10 minutes. A
hi ,there are two parts to batteries holding power and preforming well, firstly how good are the batteries, secondly how good is the charger ?, good batteries and a bad charger will make the batteries appear bad...
Feb 22, 2014 | Golden Technologies Golden CompanioN II -...
Trying to find a golden companion repair service
Call Golden Technologies at 800-624-6374 and ask them to give you the phone number of a local dealer in your area that can service your scooter
Aug 04, 2012 | Golden Technologies Companion I 3 Wheel...
Golden companion II full charge turn key on press lever to go forward it dont move hear clicking sound green light on dash blinks
John count the number of flashes by the green light and it will be the fault code indicating the problem Your owners manual should list the fault codes to be able to determine what the problem is. Ie 4 blinks pause 4 blinks pause. The clicking you hear is the electric brakes being engaged. Hope this helps
Mar 01, 2011 | Golden Technologies Companion II Travel...
Where can I get a Battery for My Golden Companion II Scooter and the cost?
Norman you will need 2 U1 batteries and you can purchase them from any battery warehouse type store or you can try to find an Interstate battery dealer in your area or you can get them through your Provider where you got your scooter Costs around $200.00 for both Hope this helps
Feb 17, 2011 | Golden Technologies Golden CompanioN II -...
I haVe two golden companion scooters that worked Perfectly. One day they just quit running. I know that when the light blinks a certain number of times in the manual it tells you what's wrong. Both of mine...
Hi. 5 flashes on some scooters is the fault code for brake coil open circuit. This usually means that the free-wheel lever is in the wrong position.
Someone might have moved the levers so that they could push the scooters, and forgot to put the levers back to the correct position.
This fault code can also mean that the solenoid coil is faulty, but 9 times out of 10, it is the lever in the wrong position.
Good luck. Neil.
Jun 12, 2010 | Golden Technologies Golden CompanioN II -...
Moving problem
Jun 26, 2009 | Golden Technologies Companion II Travel...
Health & Beauty Logo
57 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
Are you a Health and Beauty Expert? Answer questions, earn points and help others
