Nine blink code where is sensor - Televison & Video
Nine blink code on golden companion four wheel scooter
Hi FLASH CODE #9 . Controller fault .. Cheers
Jan 01, 2017 | Health & Beauty
Why won't my tv turn on. The red light blinks nine times one at a time after nine times it stops & tv still won't turn on.
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. Viewing it in "Mosaic" or "Magazine" will make surf easy.
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
Jul 26, 2014 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Flashing light #1 on the display of a 2004 recon es Honda atv
How many blinks on the 1st gear light? Here's the code definitions that should be for your quad.
Code 0 (no flashes) - The system is functioning normally
Code 1 (one flash) - Electronic control unit
Code 2 (two flashes) - Shift Switch or it's circuit
Code 3 (three flashes) - Angle sensor or it's circuit
Code 4 (four flashes) - Gear position switch or it's circuit
Code 5 (five flashes) - ECU motor circuit (defective ECU)
Code 6 (six flashes) - ECU failsafe relay circuit (defective ECU)
Code 7 (seven flashes) - ECU voltage converter circuit (defective ECU)
Code 8 (eight flashes) - Angle sensor, control motor, ECU or circuit
Code 9 (nine flashes) - Angle sensor, it's circuit or ECU
Code 10 (ten flashes) - Pulse generator or it's circuit
Code 11 (eleven flashes) - Speed Sensor , it's circuit or ECU
Code 12 (twelve flashes) - Gear position switch, it's circuit or ECU
I hope this helps you out.
Oct 08, 2013 | ATVs
Hitachi indoor unit showing red light blinking in nine times
relay must be change,
or the indoor unit board to be change
Jul 05, 2012 | Heating & Cooling
Sony Trinitron won't turn on - standby light blinks nine times
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://homenol.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts...
Apr 08, 2017 | Sony FD Trinitron WEGA KV-32FS120 32" TV
My 200 honda recon first gear light is blinking and engine wont stay running
How many blinks on the 1st gear light? Here's the code definitions that should be for your quad. Count the flashes and look it up here. Call your dealership or local repair shop for more info and parts if you're planning on tackling it yourself.
Jun 04, 2009 | RTO 200cc Full Size Four Wheeler ATV
SONY KV35S40 Light blinks continuously when power is pressed
hello there,
Many of the later model Sony TV’s have a built in self-diagnosis function. If the timer/standby indicator is blinking, this could be an indication of a problem with the unit. The diagnostic blinking will occur automatically with no action required by you to engage it.
The timing of the blinking you see would be as follows: two to nine blinks, (depending on the fault), about a third of a second apart, then a pause for 3 seconds, then the two to nine blinks about a third of a second apart again.
May 29, 2009 | Sony FD Trinitron WEGA KV-36FS120 36" TV
TV will not come on. TV standby light blinks nine
You need to call a Sony service center for this problem. It will cost you less in the long run.
Apr 16, 2009 | Sony KP-51WS500 51" Rear Projection...
KV-32FS120 Standby Timer blinks nine times
what exact model number of your Sony tv is? I need it to arrange the service manual or schematics.
Aug 12, 2008 | Sony KP-57WS520 57" Rear Projection...
Televison & Video Logo
21 people viewed this question
Top Televison & Video Experts
Electro Med Services...
