How to set up printer to print from my iPad ?
I need help in setting my iPad to print from wireless printer epson xp440
In the print option on the iPad, you will need to see if it recognizes an AirPrint printer (which your xp440 should be). If the printer is recognized it should print.
Sep 17, 2017 | Epson Office Equipment & Supplies
I want to print pictures from my ipad,but printer says to remove memory device. is the printer capable of printing directly from ipad?
Some newer printers will allow you to print to it via wifi. If your printer has this capability check your users manual or the manufactures website to get instructions to do set up.
May 24, 2016 | Office Equipment & Supplies
How do I connect a Epson l355 printer to wifi with a iPad?
Oct 29, 2015 | Epson L355
How do I print from my i-pad?
has the ipad got a driver for the printer
Oct 17, 2015 | Apple iPad 2
How do I add my iPad to my printer?
other way around - you need add printer to your ipad, you did not write what printer model and name, you did not supply information if it is this on wireless network or it is wireless printer, without that information help is not possible...
telepathy is overrated... work only in the movies...
Dec 28, 2014 | HP OFFICEJET PRO 6830 E-ALL-IN-ONE PRINTER
Connect tablet to HP printer
which HP printer? If your printer support eprint you must turn on webservices to get this to work. Make sure that the printer has internet access before starting this.
Dec 05, 2014 | HP Office Equipment & Supplies
How do I print from my ipad to konicaminolta MC 1690 printer
You will have to set up wireless printing from your iPad, but also your printer has to be able to print wireless aswell
Sep 03, 2014 | Apple iPad (16 GB) WiFi Tablet PC
Why won't Print centre ?
HI,
Go to printer page margin setting option and set it. Because if print related any issue first go to printer setting option and set every thing link page layout setting, page choose setting, small fount setting every thing you can do it.
Thanks,.
HP Printer Support
May 17, 2014 | HP Photosmart 5520 e-All-in-One Printer
Printer won't print
If your iPad can see other computers on the network but not the printer, try setting one of the other computers to share the printer and have the iPad access the printer as a shared device off of that other computer. We used to have to do this with for laptop on our home wireless network; we set one of our desktops up to share the printer so the laptop could find it.
Apr 05, 2014 | HP LaserJet Pro P1102W Printer
How to connect iPad to wireless printer
what type printer do you have? you need a wireless router.
connect the printer to your wireless router via ethernet cable or wireless. after setup is done.connect the ipad to the same wireless router...navigate to printable material from the iPad, safari is easy just launch it.click the arrow in the top left corner of the iPad, print should be an option, click print.if you do not see you printers name thenyou should then see add printer, click itif the printer is setup correctly and is "air print" capable (wireless printing) you should see it as an available printer. its simple---- I wish this site did not suck so bad with uploading videos I would show you step for step.... more questions just ask
Mar 29, 2013 | Kodak Office Equipment & Supplies
23 people viewed this question
k24674
jasbo
jasbo
