Question about Ovens
Why is oven not getting hot enough/not cooking from the bottom?
tborn6
  • 700 Answers
SOURCE: Oven not hot enough
the thermometer is most likely the problem, the calibratation is probably off. If you have access to a accurate digital thermometer it is relatively simple to do. If you do have one just take and set the knob to 250 degrees and when the oven gets to 255 it should go off and come back on at 245 degrees. If it's a digital there shopuld be a potentiometer that you have to adjust. good luck
Posted on Dec 26, 2008
  • 57 Answers
SOURCE: neff u1421 bottom oven fan is working t/stat
Can only be either element or thermostat. I suggest you check element and connections
Posted on Aug 26, 2009
heatman101
  • 43501 Answers
SOURCE: Frigidaire gas oven - model FGF366AWA - doesn't get hot inside
Yes it could be the thermostat, but what you need to find out and it is difficult to do, is determine what is cutting your gas back off.
The thermostat could be doing that but the most likely cause is the ignitor.
http://www.appliancepartspros.com/part_details.aspx?part_id=2150412&rdr=%2fpartsearch%2fmodel.aspx%3fmodel_id%3d111760%26diagram_id%3d335207
The amount of electric going through hte ignitor is what tells the gas valve to stay on. When the ignitor gets old it does not pull enough power anymore. The the burner lights for a bit and then cuts out before it should giving you some heat but not enough. It just sits there and cycles...
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
You can find parts for your unit by doing a search for “appliance parts”.
Once you get the results of the search, pick a site and when it comes up it will usually ask for the model number of your unit.
Enter your model number and you will then get a page with exploded views and a parts menu.
Find the part you need and then order it.
Check a few different sites to be sure that you are getting the best pricing.
Most sites can have the part to you in a couple of days.
I hope that this will help you to solve your problem!
Thanks for using Fixya!!
Heatman101
Posted on Jan 01, 2010
Testimonial: "Tips were helpful and response was very quick."
TheMobilian
  • 8220 Answers
SOURCE: Won't get hot, smells like gas
Most of these new fangled gas stove feature a silicone carbide ignitor to light the oven. Older stoves used a standing pilot light. As silicone carbide ignitor age a little they tend to get weak and fail to open the gas safety vave sufficiently enough for ignition. Take a look
Posted on Jul 06, 2010
SOURCE: Simpson Evolution 904 wall oven cooks very unevenly
I agree, the heating is very uneven in our oven, however, when I calibrated the temperature with a thermocouple, I discovered that the temperature gauge was 25C too hot! That is, if I set the oven temperature gauge to 155C, it was actually 180C inside the oven! Taking this in to account, it is now much easier to cook things without them burning.
Posted on Dec 27, 2010
Oven getting hot enough/not cooking from the bottom
On modern electronic control ranges, the oven temperature sensor
is the part that regulates the oven temperature. If it is not working properly it could be the reason why the range or oven won't start. This part can be found inside the oven on the rear wall near the top. Most modern ovens will display a fault code if the oven sensor is at fault. If you think the sensor may be the issue you can check the resistance with a multi-meter but will need to know the correct resistance of the sensor at room temperature. Remove power from the appliance before performing this test.
Jan 01, 2017 | Ovens
We cooked pizza at 500 something popped and now our oven cooks but not right , any ideas
If you have an electric range, look at both the top and bottom elements while oven is cold. Look for a rough spot like a hole in the element. You may have just burned out one of the elements. Sometimes they go bad without any marks. Turn on oven to about 350 and watch the bottom element to see if it gets red hot. Then set for broil and watch the top for the same red hot glow. If either does not glow red after 5 to 10 minutes, that element is bad.
Apr 02, 2016 | Ovens
What causes a duke E101 convection oven to not cook evenly?
If it's getting hot, but it isn't cooking as fast as normal, your convection blower/fan may be out. If you can hear the fan running, but the oven isn't getting hot enough, then you most likely have a heat element or thermostat problem.
Fan and blower problems tend to be a bit more common with convection ovens.
Jul 19, 2014 | Duke E101E E Series Single Convection Oven...
Maytag oven blowing hot air from bottom vent heating house
Wanted to know if you found the answer. I have the same problem.
Aug 31, 2012 | Maytag Ovens
The main oven gets warm but nowhere near hot enough to cook anything. Could it be the element? And if I replace it myself, what is the pen like object attached to a wire at the rear of the oven? Many...
if it gets hot but not hot enough its proberly your thermostat and the pen like thing over the wire is just a cover to insolate the bear spade connection
Aug 11, 2011 | Zanussi ZHQ575 Electric Double Oven
My oven will get a little warm but it will not get hot enough to cook anything.
make sure that the bottom is actually coming on andnot just the broil portion... fi it is indeed coming on then sounds like the thermostat is bad on unit... usually is a temp probe that comes into back of oven or in the rear side ranging from 2 inches to 4 inches in length..the temp prob will go back to the control ...i would start there...good luck to you
Jan 09, 2011 | Whirlpool Ovens
The heating element becomes red hot,but the food doesn't appear to cook in an appropriate time os fashion. Any answers or suggestions
The top of whatever food you're cooking should be in the center of the oven for the most effective cooking. Do you have the oven set on bake or broil? Broil is a direct heat method and if the food is on the lower shelf and the oven is set on broil, the food is not getting enough heat to cook it properly. Baking heats the lower element and the heat rises to surround the food. Broiling heats the top element and since heat rises, it is not getting down to the food to surround it and cook it.
Nov 04, 2010 | Hotpoint SY36 Style Line Stainless Steel...
Jul 06, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
Sep 26, 2009 | Ovens
Oven not hot enough
Dec 26, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Ovens Logo
35 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
