Question about Garden
Briggs 4 stroke mower starts but only runs for 3 to 5 seconds i have drained tank & refueled mower is only 16 months old
  • 1,104 Answers
Hi sounds like a blocked main jet in the carburetor,. Cheers
Posted on Jan 01, 2017
Eliminate smoke
Drain fuel tank. Fill with fresh and add the correct amount of the correct oil.
Take the old fuel, and add it to your car's tank, it should be diluted enough so your car will be fine.
Jul 07, 2016 | Garden
Lawn mower not running well
Try changing the fuel and air filters. Also drain the fuel tank and refill with fresh fuel.
Feb 23, 2015 | Briggs & Stratton Garden
8 hp B&S amf dynamark rider ran it out of gas, since filled w/new gas starts but quits running after 3-5 mins
try and run it with the gas cap loose when you refueled it dirt might have blocked the vent on the cap
Jul 10, 2012 | Briggs & Stratton Briggs Stratton...
I have a mower that had not been started in 2 years, and the gas was left in the tank i feel this has destroyed the carb, it wont start, not getting fuel to cylinders. can these carbs be rebuilt, and...
The carburetor is not destroyed, just gummed up with the old gas. You might be able get it going yourself by doing the following: Drain all of the old gas out of it. Put in a little carb cleaner in the tank. If you have a spray can, just spray it into the tank for 3 to 5 seconds, or at least until you can see a puddle of it in the tank. Crank the engine for about 5 seconds. If the puddle in the tank has gone down, then let it sit for an hour then repeat and wait another hour. Then add some gas and try to start it. However, if the puddle in the tank does not go down at all, the carb will have to be disassembled to be cleaned. If you don't want to do that yourself, call a local mower repair shop - should be less than $50.
Aug 25, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Briggs and stratton 4.5 hp ( 10G902 ) starts great but after a couple seconds starts to stumble. i have replaced the plug, gas and cleaned the air filter. I tried a couple things like spraying carb cleaner...
Try draining the carb and gas tank into a small plastic bowl and look for water in the fuel. I you have a diaphragm type carb it might just need a new diaphragm and spring.
Did the stumble start right after refueling? If so then your gas can may be carrying some water too. It happens. I have seen gas can with INCHES of water in the bottom! True story. I went to a customers house after she had both her walk behind and rider stop running. She said both were fine until she refueled and then...no start. I looked at her gas can and it was terrible!
If you are trying to clear the main jet you need to get inside the carb and clean from the fuel inlet side. Bowl carbs usually have removeable jets that you can look through.
Good luck and be careful!
Jul 12, 2010 | Briggs & Stratton Garden
Mower wont start
About the only suspect is water in the fuel - even after you drained it. If your Masport has a 'Quantum' style engine with a float type carb, undo the bowl nut and allow the float chamber to drain. Odds on there's water in it. A single drop will block the jet. If it's a 'carb-on-the-tank' engine, chech for water droplets in the bottom of the tank. They wll be obvious if present.
Mar 11, 2010 | Briggs & Stratton Lawn-Boy Insight Series...
Troy-Bilt Briggs & Stratton 550 restarting
Troy, Unless you are using old fuel (it breaks down after 1 week) it sounds like you have a faulty spark plug. Replace this first, drain any old fuel and replace with fresh fuel (premium unleaded). A faulty plug will work one minute but then fail like you have described.
Oct 24, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Poulan Pro lawnmower (Briggs and Stratton 128 cc engine) will start when primed but will not stay running. New Lawnmovewr, < 3 months since purchased at Walmart
IF IT IS A BRIGG & STRATTON ENGINE YOU CAN GO ONLINE TO BRIGGS & STRATTON.COM AND ASK THEIR TECH SECTION ABOUT THE PROBLEM. FOR 3 MONTHS OLD SOUNDS LIKE DIRT OR WATER MAY HAVE GOTTEN INTO THE TANK. WHEN YOU PRIME THE MOWER YOU ARE FORCING GAS INTO THE CARB AND ENGINE AFTER THAT THE ENGINE SHOULD PULL THE GAS IN THE ENGINE, I WOULD SAY THE CARB MITE NEED REBUILDING BUT NOT AT 3 MONTHS
Sep 17, 2009 | Poulan Garden
Vanguard (Briggs) 20 HP V Twin Mower Engine
pull the tank first and inspect. if u still find nothing, you might want to check your coil
Aug 22, 2009 | Briggs & Stratton Briggs Stratton Vanguard...
Garden Logo
27 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
