Question about Nordic Track Exercise & Fitness
I have a Nordic Track C2155 that doesn't power up on the display after inserting key. The red LED on the power supply board does light up
    New Friend:
  • 14 Answers
The circuit board is fried. It's too expensive to have fixed if the warranty is expired. You can try and find a used display from ebay or craigslist. It would be an easy swap.
Posted on Jan 01, 2017
Testimonial: "Is there a way to test this out"
  • Ronnie Bissoon
    Ronnie Bissoon Jan 01, 2017
    Yes,but it will require advanced knowledge and not something that could be easily explained. It involves taking the display about and voltage meter, soldering skills as well as possible parts
Nordic Track C2255 no power to the console and the fan is running unable to turn of the fan, checked all the wires on the control board and the LED is fixed red.
This is a situation the controller board motor is Faulty.
They controlled the console CPU BOARD. with 8-12VdC
For CMOS Circuit.,this board has 3 control power supply Some IGTB is faulty: 1) Main motor 2) Elevation motor 3) Console Control
HOwever tight the connector coming from controller board motor to the Console very well, and clean it.
Otherwise replace the Controller board motor.
Blessing.
cuadra2016@yandex.com
cell+whatsAPP:+50588611441
https://www.youtube.com/watch?v=p6PkBZrh4KM
Nov 17, 2017 | Nordic Track Exercise & Fitness
Control panel will not turn on
Check the power supply, or however the device is powered. If the LED display does not light up then there is a defect in the panel circuit. Needs to be removed to troubleshoot.
Oct 07, 2014 | Nordic Track Cx1055 Console For Model...
Treadmill is dead.
Have you tried turning the power off, unplugging the system . Wait 15 minutes then plug it in and power up.
May 07, 2014 | Nordic Track Incline Trainer X9i...
Nordic track commercial 1500 no power
looks like there is power to the board. the board the sends power to the console. there could be a loose connection at the board
Mar 04, 2014 | Nordic Track NordicTrack Commercial 1500...
How do I install the walking belt for the nordictrack C2155
see the video and follow the steps and fix it. God bless you
Sep 29, 2013 | Nordic Track NordicTrack C2155 Treadmill...
Nordic track 1500 treadmill with no display and there is only a red blinking light on the circuit board
1( tight the ribbon cable and clean it,
2) tight the plug from display board , and clean it.
3) tight the display board vs lower board and clean it unplugged the power
4) test the fuse and replace if necessary or c.breaker reset.
5( Finally adjust the REED SWITCH , clean it and tight the plug very well see the diagram attached.
6) see the block attached. finally the display board can be faulty.
God bless you
Sep 30, 2012 | Nordic Track NordicTrack Commercial 1500...
I need a key for my c2155 treadmill
GO TO www.nordictrack.com and then customer service and then parts & manuals and order your part.
or go www. gympart.com
http://fitness.manualsonline.com
sincerely
Nov 13, 2011 | Nordic Track Exercise & Fitness
I own a nordic track exp1000 series and only recently had trouble with it. The panel lights up when the key is inserted but will not start up when the start button is pushed. What do I need to do to...
# get a 12-18 volt dc battery fully charged(like one from a cordless drill)
# Make sure it is fully charged, because it won't work if not
# attach the + and - to the motor red is + and black is -
# If the motor turns slightly your motor is ok, if not the motor is bad and would need replaced
# if the motor is ok then your motor controller(the board with the metal) is malfunctioning and would need replaced.
Jul 05, 2010 | Nordic Track NordicTrack T7 si Treadmill
I have a nordic track c2155. it powers up, but every button i push makes it beep. i have made sure the reed switch is 1/8th away from the pulley and that the unit has power
All, just figured something out. I had the evil beeping problem as well. I decided to play around and see if I could fix it. I unplugged the iFit adapter from the main control board and when I plugged it back in and tested it, IT WORKS AGAIN! NO MORE BEEPING!
Aug 19, 2009 | Nordic Track NordicTrack Treadmill, A2550
Nordic Track Ifit Treadmill has power but walking pad not working
If everything on the display console is working correctly then we know it is either a problem with the wires from the console to the controller or the controller itself. In most cases this means you need a new controller. To verify, take off the motor hood and find the green circuit board called the motor controller. With the power on go into manual mode and push the speed up button to a slow speed. If you see an LED light with "spd ctrl" next to it flickering but the belt still does not move then we know the problem is with the controller sending the signal to the walking belt, in which you should check the wires that go to the motor. If they are connected correctly then we know a new controller is in order. If you do not see a flickering light then it means the speed signal never got there and the problem will be with the wires going from the console to the controller. This is called an upright wire harness.
Apr 18, 2009 | Nordic Track NordicTrack Treadmill, A2550
Exercise & Fitness Logo
56 people viewed this question
Top Nordic Track Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Ross Metcalfe
Ross Metcalfe
 Atlanta Fitness
Atlanta Fitness
Level 1 Expert
Are you a Nordic Track Exercise and Fitnes Expert? Answer questions, earn points and help others
