Question about Generic RCA LED55G55R120Q 55" 1080p 120Hz LED HDTV
I have a 55 inch RCA model # LED55G55R120Q and it will not turn on. There is a red light that comes on, on the front, but that is all.
Also, I have lost the owners manual so I have no clue about any kind of troubleshooting or resetting. Please help!
How to turn off internal speakers on rca led55g55r120q tv
You can't normally if using the HDMI cable, although you could check in Settings - Sound. The small 3.5mm jack usually has a mute for the internal speakers.
Your manual doesn't mention it, so no you can't. RCA are inexpensive basic sets.
http://www.searspartsdirect.com/partsdirect/user-manuals/LED55G55R120Q-RCA-LED%20TV-manual
Dec 31, 2016 | RCA Televison & Video
A led55g55r102q RCA tv that wont turn on and the power light on the front does not light up
The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Sep 29, 2016 | Generic RCA LED55G55R120Q 55" 1080p 120Hz...
Flatscreen Television isn't turning on. I'll plug it in and the light to the left side turns red with a black screen.
Fault to its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Nov 14, 2015 | Generic RCA LED55G55R120Q 55" 1080p 120Hz...
Vertical lines appear on right side of screen intermittently. Can it be fixed.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Mar 10, 2015 | Generic RCA LED55G55R120Q 55" 1080p 120Hz...
Sony bravia
what model of Sony is it? On many of the Sony projectors, a 3 flash error code indicates the lamp is not properly seated/installed or the lamp door is not closed properly
May 15, 2008 | Sony BRAVIA KDL-40S2010 40 in. LCD...
52 inch RCA - green light turns on & off, BUT no picture
CP150 is a capacitor in the power supply circuit....feel top to
see if flat....change if "pooched" or swollen..................T.
Apr 15, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Generic RCA LED55G55R120Q 55" 1080p 120Hz LED HDTV Logo
74 people viewed this question
Top Generic Televison & Video Experts
CoppellTVRepair.com
richie46
Are you a Generic Televison and Video Expert? Answer questions, earn points and help others
