Question about RCA Televison & Video
My 55 inch RCA model # LED55G55R120Q won't turn on. The red light on the front comes on, but nothing else happens. Plus, I have misplaced the owners manual so I am totally screwed.
  • 61 Answers
SOURCE: TV Problem
The first thing is to check to see if the fuse is blown,if so replace with a 5 amp fuse,fuse is located near were the power cord connects to the board,make sure set is disconnected from power.
Posted on Mar 05, 2008
SOURCE: TV Wont turn on - Red Blinking Light under Lamp
The lamp is shot. Port is on the right side of set - just remove and take a look. Check VISA limit.
Posted on Apr 16, 2009
rickbrashear
  • 176 Answers
SOURCE: 42 inch lcd with blinking red light
I just fixed mine, I am not exactly sure what did it, but I held the power button down while pushing and holding each button for a few seconds after going through each button I unplugged power cable and then plugged it back in and it powered it up and it worked
Posted on Jan 28, 2011
protvrepair
  • 153 Answers
SOURCE: Heard a pop , bulb blew out , replaced bulb , it
3 blinks indicates lamp door is not on or has not been reinstalled properly. This also could mean the lamp door switch has failed itself. Try removing the lamp door and putting back on, if that doesnt correct the problem then I recommend having the switch replaced.
Posted on Oct 29, 2011
SOURCE: Bike won't start, won't turn over, lights
Changed the FOB battery in mine andf it was the problem, try it!!!
Posted on Jan 23, 2012
How to turn off internal speakers on rca led55g55r120q tv
You can't normally if using the HDMI cable, although you could check in Settings - Sound. The small 3.5mm jack usually has a mute for the internal speakers.
Your manual doesn't mention it, so no you can't. RCA are inexpensive basic sets.
http://www.searspartsdirect.com/partsdirect/user-manuals/LED55G55R120Q-RCA-LED%20TV-manual
Dec 31, 2016 | RCA Televison & Video
Flatscreen Television isn't turning on. I'll plug it in and the light to the left side turns red with a black screen.
Fault to its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Nov 14, 2015 | Generic RCA LED55G55R120Q 55" 1080p 120Hz...
Red Light Won't Stay On
1. Remove batteries from remote to "zero" it, then reinsert batteries
2. Turn on TV (RCA?)
3. Press and hold CODE SEARCH button until indicator lights
4. Press and release TV button. Indicator will blink and remain on
5. Enter code from list in instructions
6. Point remote at TV and press on-off button. TV should turn off
7. Use remote to turn TV on again and press CH+. If TV responds you're all set; if not, repeat the process with the next code
Nov 19, 2012 | RCA CRK76TE1 UNIVERSAL REMOTE - With...
My Sanyo tv is not working. The power light comes on and then starts blinking red.
I myself had a 55 inch hdtv ready projection tv and the lamp went out in it. It cost me $104.00 plus shipping to replace it. Check out discount replacement parts but remember that if it is a projection tv, it won't last but approximately two years and you will have to do it again.
Aug 25, 2012 | Sanyo SELECT PLC-XP45 Rear Projection...
Tv wont turn on, just red light blinks
From the owner's manual of that model:
If a red light is blinking on the front of the TV, the set has entered protection mode. If this happens it usually means you simplyneed to reset the TV. Unplug the TV for 60 seconds. Then plug the TV in and try to switch it on. If the light is still blinking red,call the Customer Care Center at 1-800-531-0039
Dec 08, 2011 | Philips 55PL9524 55" Rear Projection...
RCA LCD TV red light flasiing tv won't come on
Bad main logic board. Probably won't be able to find it. You can try Encompas Parts. Good Luck to you.
Nov 20, 2011 | RCA L32WD22 32 in. LCD HDTV
I have a RCA DVD Home theater system and I plug it in and the blue standby light comes on, but when I push it or other buttons on the unit, it just powers off and then won't turn turn back on at all....
I am having the same problem...i plug it in the standby light xomes on but i press the power button and nothing happens...mine is a rca rtd315wr model
Sep 03, 2011 | RCA RT2360 System
I just bought the 55 inch philips dptv335 tonight. it was used and did not come with an owners manual. it refuses to turn on although there is a sound like the audio is turning on and a click like the...
This is a very common problem. Your Flyback/HVG has gone out. The most commion symptom is that you have audio but no video. We see this all the time on the DPTV3XX models. The bad news is that its nearly impossible to find one.
You can get complimentary replacment instructuons and part numbers at the following link.
http://www.tvrepairkits.com/component/content/article/104
Dec 24, 2010 | Philips 55PW9363 55" Rear Projection...
Televison & Video Logo
435 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
