Question about Pioneer VSX-D710S Receiver
How to reset in factory setting pioneer VSX-D710S
petraman7
  • 1175 Answers
SOURCE: Pioneer Audio/video Multi-channel receiver Mod#VSX-D710S
Have you tried a 2nd source like the CD input or AUX input?
Have you tried the headphones..same static?
If nothing works then the output amp is broken. There could be internal fuses but only open a stereo when the power is DISCONNECTED. Then check for fuses
Posted on Feb 02, 2008
SOURCE: Pioneer Receiver VSX-D508
I just set it to theater1 setting and it made the center speaker still no sub but the reciever has plenty of base.
Posted on Apr 13, 2009
SOURCE: I have a VSX D710S and it flashes poweroff then
Im having this same problem. It happened after I had the music up really loud for about 3 hours. Also, where it has the volume all i see is -- instead of a number when i try to turn it on
Posted on Jan 07, 2010
SOURCE: Pioneer VSX-D710S and the message SP off and DTS
The SP off message is the setting for turning the speakers off while headphones are connected on some Pioneer models. If yours is one such model, hold down the RECEIVER button and press the SPEAKER (text may be written above another main function) button on the remote simultaneously and the sound should return.
Posted on Jun 24, 2010
dunnbiker
  • 8546 Answers
SOURCE: Pioneer VSX D710S, I hook
I wouldn't hold my breath waiting for free detailed circuitry.
A precise make and model might yield more-specific answer.
Generally speaking, an amp protects itself from heat, shorts and overloads.
Overloads can be from excessive periods of high output and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced hands-on tech.
Posted on Jan 24, 2011
How can I connect an analog turntable to my Pioneer VSX-D710S? Also, do I need a turntable with a built in pre-amp?
According to the specs there aren't any phono inputs which would have their own preamp. Everything else is line level so I'm pretty sure you'll need a preamp either between the turntable and one of the line level inputs or built into the turntable.
Mar 21, 2014 | Pioneer VSX-D710S Receiver
Hi ! I have a Pioneer AV receiver VSX-D710S and i have a problem with sound ! At the maxim volume (0db) the sound it's verry low an when i make volume ajustments i heard in speakers some knoking !...
The first thing you need to do is to disconnect all the speakers.
Then connect them one at a time and see if you get the correct volume on any of them.
If you don't get the correct volume on some of the speakers then it's those speakers that are faulty.
If you don't get the correct volume on any of the speakers then the fault is with the internal amplifier and you'd need to take it to get it repaired.
Jul 29, 2011 | Pioneer VSX-D710S Receiver
Pioneer VSX D710S, I hook everything up and turn the unit on, after about 5-10 seconds it flashes POWER OFF and shuts down.
Jan 24, 2011 | Pioneer VSX-D710S Receiver
Pioneer VSX-D710S and the message SP off and DTS off message appear and I have no sound. Any ideas how to turn them back on?
Apr 01, 2010 | Pioneer VSX-D710S Receiver
I had only static on back speaker of pioneer vsx-d810s. Now I can not get the back speaker to work at all. Tried every step in the manual ten times. Now I can not turn DTS on or off. Monitor only show...
well you must config the surrond back speaker , check in operators manual how you do-it and pag.17 to 19 . please check for When “SB*” is selected in SPEAKERS setting mode,
the SURROUND BACK distance cannot be set.
so if you dont have check this site, who has the manual to help you how to config.
http://safemanuals.com/user-guide-instructions-owner-manual/PIONEER/VSX-D710S-_E is from 710s, but have 810s also
Jan 08, 2010 | Pioneer VSX-D810S Receiver
Nov 29, 2009 | Pioneer VSX-D906S Receiver
Pioneer VSX-D710S Receiver Logo
98 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
Ian Summerfield
Ian Summerfield
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
