Question about Andis Health & Beauty
How to attach the comb set tomy Andis detachable plus model AG2 the comb set seems to be to small. Thank you
4 Suggested Answers
philschneide
  • 448 Answers
SOURCE: Bought Oster Golden A5 clippers new but did not
There is a small gun-metal colored bar at the very rear, just below the back of the blade. It pushes inward, in the direction of the blade. Push it firmly in and pull up on the teeth of the blade. It should pop upward. You can then remove the blade from the tongue that it sits upon. When you want to put it back, slide the blade back on the tongue, then, WITH THE MOTOR TURNED ON, push the blade down to its seated position. It will click into place.
Terms regarding these devices are all too often assumed as understood. For most purposes, these are what you have to know for the A5 Oster. The cover plate is the part with two screws that has the name and other info on it. If you remove the two screws and the plate, you will see a nylon part that moves the blade back and forth--that is the lever. The other end of the lever, with a hole in it, is connected to a metal part called the link. Both parts are easily removed by simply pulling them upward from the device. The bakelite gear is the part that the link sits on (the larger hole in the link). It too can be simply pulled up off the metal shaft that it rides upon (careful not to lose the washer under it). That gear is turned by the armature gear of the motor (which is where things get much too involved to cover here, but from that point on the device very rarely has problems). Incidentally, the lever, the link, and the gear can all quite simply be replaced. They are available quite inexpensively at Amazon under Oster A5 Clipper parts (note that the one speed and the two speed take different bakelite gears, but the lever and the link are the same). If you were to replace parts such as these or simply lubricate them, remember that a good white lithium grease is recommended in light application for the gear and the shafts (lever and gear shafts and armature gear). Also, the gear shaft has a hole down its middle (and two small holes that lead to the outside of the shaft. The shaft should be filled with grease so that grease can get through those small holes to lubicate the inside of the bakelite bearing. The two pads (one on each side of the lever) should be oiled. The simple way to tell if you need to replace parts is to grip the blade end of the lever while all parts are in place and try to move it back and forth, as though it were running the blade. If there is any more than the slightest movement, replace the lever (replace that anyway if the part that contacts the blade is rounded off) link and gear.
Good luck.
Posted on Oct 03, 2009
askmannyssha
  • 76 Answers
SOURCE: Andis Ag2 clipper blades-I dropped the 4fc blade
can you move the cutter blade (this is the smaller blade) side to side easily with your fingers if so the tension on the cutter blade has loosen. you need a special tool to reset the tension and the spec' on how much tension. send the blade to mannyssharpening.com they have fast return service and return shipping is included in the sharpening price.
Posted on Apr 18, 2010
SOURCE: I have a Andis Model
try www.angliaclipperservices.com for andis clippers and blades
Posted on Sep 16, 2010
Why wont my hp pavilion all in one turn on?
Problem with Andis ProPet Clipper Kit in Storage Case with size 10 detachable blade set- Model MBG2
May 23, 2014 | Andis ProPet Clipper Kit in Storage Case...
Replaced the switch on my Andis AG2 clippers and now they are frozen
Pull it to pieces again slowly, checking each step until you find the motor comes free. Whatever you last did will be where the fault is.
Jul 17, 2012 | Andis AG2-Speed Detachable Plus Clippers
Looking for a replacement cord for Andis Master Model M any suggestions ?
Andis discontinued this cord in 2013
Andis M - 2 Wire Detachable Cord part # 01587.
Available from Pro Products And More as of July 2015.
http://www.proproductsandmore.com/zencart139/index.php?main_page=product_info&cPath=205_206&products_id=394
************ UPDATE ***********
The webpage above no longer has them, BUT you can get them from eBay or Craigslist... it's just a matter of getting an alert (notified when someone puts one up for sale). You can get alerts by email or IM (instant message) on your phone. They're still out there!
Jan 13, 2011 | Andis Health & Beauty
What is the hooked comb for
It's for removing clumps of matted hair, but any animals I've used them on don't like them. They seem to cope better with a wide-toothed comb.
Oct 13, 2010 | Andis Super Deluxe Pet Clipper Kit
Andis Ag2 clipper blades-I dropped the 4fc blade and now it will not cut. How do I adjust it so it will cut?
Jul 12, 2009 | Andis 01690 Hair Trimmer
Andis adjustment
blades has to be set precisely,only then will you get a crisp cut.
Aug 22, 2008 | Andis 01690 Hair Trimmer
Andis pet clipper kit
You are most likely referring to the snap on comb.. most of them are designed to use only with a 30 or 40 blade. This is the only way you will get a proper cut with them. Good Luck with your old "guy". And I'm sorry hes petrified to go to a professional groomer.. seems you have been taking him to the wrong ones. :)
Sep 26, 2007 | Health & Beauty
Health & Beauty Logo
49 people viewed this question
Top Andis Health & Beauty Experts
Anglia Clipper...
shaveroutlet.com
shaveroutlet.com
Kolbrun...
Are you an Andis Health and Beauty Expert? Answer questions, earn points and help others
