Question about Kenmore Dryers
I have a Kenmore elite 970-698330. The outer 2 rings work. My first assumption is a failed element. How do you open the top to get to the element to do a continuity check?
  • 311 Answers
SOURCE: The inner right front element
inner element burned out. Either burner needs replacing or control switch is bad. Take out burner and see if coil has a break in it. IF not, then switch is bad. I cannot see your repyl due to some tech issue w/ the site, so it may be a day or so before I can reply again. Please leave feedback for me if appropriate. Thanks
Posted on Nov 28, 2008
JR JR
  • 116 Answers
SOURCE: drum light goes on and off kenmore elite oasis dryer
repl user interface ,, it has a stuck button,, order inter face
Posted on Nov 30, 2008
cactus bob
  • 267 Answers
SOURCE: I have a Sears bought
the burner must be replaced . easy job, open oven look under lip of stovetop there are two 1/4 inch drive nuts , remove them then you can lift the cooktop you will see the underside of the burner . its held in with two screws , carefull of the clips,there easy to loose . let the old burner hang by its wires . when you get the new one in move the wires one by one to the new burner ... you will need two people one to hold the top up and one to do the work . dont forget to turn power off to stove . part will cost around 100.00 should take no longer than 15 mins to do the job . have fun and good luck ........ please rate this answer i need votes to stay here , thanks
Posted on Feb 01, 2009
  • 5 Answers
SOURCE: heating element continuity?
Unplug the dryer from the wall. There are 2 wires connecting power at the heating element. Take one of these wires off, doesn't matter which one, but take at least one of the 2 off. Then put your meter probes across the terminal of the heating element where you took the 1 wire off and the other terminal of the heating element that still has a wire on it. Your meter will pretty much read full continuity if good, no reading at all if bad. Also check from one of these terminals of the element with one meter probe going to the metal frame of the unit. You should get no reading. If you do the element is shorted and would have likely tripped your house breaker.
Better to test a heating element for voltage with your meter like I described to you in your other question. I've seen heating elements read good when just doing a continuity test, however once voltage is applied and they start to heat they can expand and open up, thus not work, even though testing good when doing just a continuity test. Not always, but sometimes, it does happen enough to note to you.
Posted on Mar 11, 2009
SOURCE: I have a kenmore electric stove. The top burner
I have the same problem, it turns out that the clock has a sensor in it to turn on the oven. If that sensor is not working, which is found in the clock, the oven does not work. I had a repair guy come out and it will cost 350.00 to repair. My stove is only six years old. It is only two months to the day off warranty. Apparently a power outage can cause the sensor to go. Hope this helps.
Posted on Aug 20, 2010
How can I get a user manual for my Kenmore Elite 30 inch Electric slide in range with ribbon radiant elements model number 46804
Kenmore Elite Electric Slide In Range 30 in. 41053 - Sears
www.kenmore.com/kenmore-elite-30inch-slide...electric-range...
Kenmore
Rating: 3 - ‎30 votes
The slide-in Kenmore Elite range 41053 has a true convection oven for faster pre. ...Kenmore Elite 30" Slide-In Electric Range w/ Convection - Stainless Steel ... Owners manual - English (Warranty) .... I called SEARS repair to look at my range and the repairman told me that this range has flaws with the oven fan and there is ...
Kenmore Elite 30" Double-Oven Slide-In Electric Range w
www.kenmore.com/kenmore-elite-30inch...slide...electric/p-02...
Kenmore
Rating: 3.5 - ‎30 votes
The exciting Kenmore Elite double-oven slide-in range 4111 offers all the feature. ... Versatile cooktop options include a 12-inch triple-ring element, a 9-inch Turbo Boil Flex™ element, and a ... Owners manual - English (Warranty) .... Ovens are both conventional or can be set to convection, my first bake was a cheese cake.
Nov 28, 2015 | Kenmore Kitchen Ranges
Kenmore c970-440935. Why does one element overheat?
Kenmore Elite C970 440935 Replace heating element range
www.fixya.com > ... > Ovens > Kenmore > Kenmore Elite C970 440935
Kenmore Elite C970 440935, replace heating element range related issues. Get free help, solutions & advice from top Kenmore experts. ... Kenmore 40494 / 40495 / 40499 Electric Single Oven. 793 Questions ..
Aug 05, 2015 | Kitchen Ranges
Kenmore 790.9641* free-standing electric range: The "single" (inner) part of the dual radiant element is not working. When the knob is turned to the single side, the ELEMENT ON indicator lights, but
The inner ring or center part of the element is burned out. You will need to replace the entire element, as it is not possible to replace just part of it.
Dec 19, 2014 | Kenmore Kitchen Ranges
Inner burner on duo element does not heat up. Seems dead.
This could be either the element itself or the switch that controls the element. Since the outer ring is working the issue almost always is with the element. The top can come up and the element replaced.
It is a moderate repair, so some technical ability will be required, the use of an ohmmeter is needed to verify the component that has failed. Let me know if you need more information.
May 06, 2010 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
My kenmore elite with calypso motion top load is leaving black marks on my clothes and they are getting caught between to bottom plate and the side wall, the plate is fairly new.
1. UNPLUG THE WASHER.
2. Open the washer top. Look along the front seam of the washer where the top meets the front. There are a couple of retaining clips (about 2" in from each side) that you will need to push in on with a putty knife while gently lifting up on the top to get the top to release. Carefully open the top and lay it back in a resting position. Make sure you support the lid so it doesn't fall open when you tilt the top back. NOTE: I would recommend using duct tape to keep the lid closed and gently place the top against a wall for support. Use a towel between the cabinet and wall to prevent any damage to painted surfaces. This also reduces the strain on the top panel supports.
3. Remove the tub ring. This is the plastic donut shaped ring that sits on top of the wash tub. There will be a tab on either side of the outer tub near the back that you can use a screwdriver to release the tub ring. The ring is filled with fluid and is used to balance the tub. So, if you hear liquid sloshing around, this is normal.
4. Remove the wash plate center dome from the wash plate. This is the center cone on top of the wash plate. Use a flat blade screwdriver and insert it into any of the slots available along the sides. Gently pry until it pops off. I say "gently", but you may have to use a little muscle to get it to come off. Sometimes they stick. Once the center cone is removed there will be a series of nuts under it.
5. Remove the nuts and the main wash plate should lift out, exposing the inner wash plate. This is another cone shaped device located under the main wash plate. Remove the inner wash plate, using care not to damage the gasket under it. It is common for clothing to become tangled in the leveler or u-joint under this inner wash plate.
6. When all required maintenance is complete, reinstall the inner wash plate, ensuring the gasket is seated under it. The inner wash plate is keyed and should only install one way.
7. Insert the main wash plate and insert mounting bolts. Use a criss-cross pattern when tightening to ensure all bolts are tightened evenly and the gasket seats properly.
8. Reinstall the center dome on the wash plate by snapping it back in place.
9. Reinstall, the balance ring on the wash tub.
The following is a parts list of the most common items that may require replacement when you experience erratic motion of the wash plate, and/or clothing becoming damaged or entangled:
Wash Plate Dome
Main (Outer) Wash Plate
Inner Wash Plate
Leveler Assembly
Inner Wash Plate Seal
U-joint
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jul 08, 2009 | Kenmore Elite 45986 Front Load Washer
Replace heater element
Unplug the dryer.
Open the lower front panel.Use a putty knife to push in thclips on top of the lower front panel. They are about 2 inches in from each side.
Lower the panel. The heater will be in front of you on the bottom right.
Are you sure the heater is bad?
It may be another part.
Apr 12, 2009 | Kenmore 63032 Electric Dryer
The inner right front element will not heat up on our Kenmore Elite ceramic stove top. The middle and outer elements on the right front work fine. Why is this happening?
Nov 28, 2008 | Kenmore Kitchen Ranges
GE Hotpoint Dryer NVLR333ET0WB
ck for thermal fuse on outer edge of element housing it usually a small round disc
Jul 23, 2008 | Kenmore Elite HE4 Electric Dryer
Door handle
I bought a handle and took a chance that I would figure it out. It turns out to be pretty simple. Open the dryer door and you will see 10 phillips head screws on the back of the door. There are also torx(star shaped) screws. Remove only the phillips head screws. This will separate the plastic outer ring from the door. On the back of the plastic ring are 2 screws that hold the handle. Remove the screws, replace the handle and put the ring back on the door. Put the 10 screws back and your done.
Nov 09, 2007 | Kenmore Elite HE4 Electric Dryer
Dryers Logo
46 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
