Question about Tablets & eReaders
My smart tab key bord there is nothing wrong with the actually keys my tab is not responding to the key bord it self
My samsung t210 is not resetting i have tried button and inside setting options both look like its working but when reboots no change the accounts come back aswell
Before performing the Hard Reset:
- In case your Galaxy Tab 3 7.0 can connect to a computer, Then it is better to make a backup of your saved data using Samsung kies software, You can read this Guide to learn how.
- But in case that is not possible, Then you can check that your phone's battery has enough charging level, Otherwise you should charge it.
Samsung Galaxy Tab 3 7.0 SM-T210 and SM-T211 Hard Reset Steps:
- Turn your Galaxy Tab 3 off.
- Take out any existed SIM or memory card.
- Wait for 10 seconds.
- Press and hold the Volume Up key + Home key, Then press the Power key.
- Keep pressing the keys until Samsung logo appears,Release all keys.
- Wait until you get Factory reset / System Recovery menu on screen.
- Use the Volume Down key to select Wipe Data / Factory Reset option.
- Use the Power key to confirm the operation.
- You need to use the Volume Down key again to select "Yes -- delete all user data"
- Use the Power key to confirm.
- After performing the hard reset, Select Reboot System Now option, And confirm it using the Power key.
- Now the phone will reboots, Wait for it to be fully on and then you can start using it.
New Hard Reset / Factory Reset Method Using Odin3 Flasher:
In case you cannot put the Samsung Galaxy Tab 3 7.0 Into Recovery Mode for any reason, Or the Normal Hard Reset operation does not solve your problem, Then you can use this new method to Hard Reset the device so easy, This New Method will reprogram the User area, And it can solve many software errors too, Just follow the steps below:
- Download and Extract Samsung Galaxy Tab 3 7.0 Hard Reset File ( SM-T210 ' SM-T211 ).
- Download Odin3 flasher.
- Put your phone into Download Mode.
- Run Odin3.exe
- Click on CSC button and Select the Hard Reset file.
- Connect your phone to PC via USB cable, And wait until Odin3 detects the phone.
- Click on Start button and wait until the operation done.
- Now your Samsung Galaxy Tab 3 7.0 will be rebooted.
- Done.
Jun 02, 2016 | Samsung Tab Tablets & eReaders
Tablet is not responding ,to any comands
Touch Screen Not Working Android Problem [Fix] - TechKhoji
www.techkhoji.com > Android
Feb 27, 2014 - How can I reboot my tablet, the touchscreen is not working. ....Sometimes when I turn on the screen it doesn't respond to my fingers. Then I ...
Android Tablet Touch Screen Problem Solution - YouTube
? 21:36
https://www.youtube.com/watch?v=h7_aqvkfKL4
Jun 16, 2014 - Uploaded by SOLOMON BOTCHWAY
I CANT Believe it, i Actually fixed my tablet.. all i did disconnect the ... my touch is working how to fix the screen not showing? ....2 WAYS TO FIX IPAD TOUCHSCREEN NOT RESPONDING - WORKING - Duration: 5:17.
Samsung galaxy Tab S 10.5 not responding by touch ...
? 2:54
https://www.youtube.com/watch?v=XkK9zCx46gs
Jul 7, 2014 - Uploaded by Linkhunter
i just the new tablet by samsung i recharge the tablet after that isnot responding by touch and so Sim card do ...
Touch Screen Not Responding ' DaniWeb - DaniWeb IT Discussion ...
www.daniweb.com > ... > Hardware > Mobile and Wearables
Jan 11, 2016 | Tablets & eReaders
To many patten attempts
  1. With the Samsung Galaxy TAB turned off, press and hold the VOLUME Down button, and then briefly press the POWER button.
Note: If you see "Downloading" on the screen with an Android shoveling you pressed the wrong Volume key. Remove and reinsert the battery and try again.
It should hard reset any of these tablets:
Reset GT-P6210 Galaxy Tab Plus 7.0 WIFI
Reset GT-P6200 Galaxy Tab Plus 7.0 WIFI + 3G
Reset GT-P6810 Galaxy Tab 7.7 WIFI
Reset GT-P6800 Galaxy Tab 7.7 WIFI + 3G
Reset GT-P7310 Galaxy Tab 8.9 WIFI
Reset GT-P7300 Galaxy Tab 8.9 WIFI + 3G
Reset GT-P7510 Galaxy Tab 10.1 WIFI
Reset GT-P7500 Galaxy Tab 10.1 WIFI + 3G
Feb 10, 2014 | Samsung Galaxy Tab 2 7" 8GB Android Tablet...
IT WON'T TURN ON WHEN I PUSH THE ON OFF BUTTON
Ok let it sit on the ORIGINAL charger for hours. DONT TOUCH IT. then after 4-5 hours see what happens. if nothing still i would go ahead and call Samsung or take it to the store if you bought it. could be a defect and get money back or a replacement. If it actually a defect then you will be coverd its called a manufactures defect and they last up to a years in coverage.
i have one more option and it is safe and many people do it. sometime the operating system doesn't respond so try this. if you see a samsung logo during the beginning then you know your good and just finish the steps and enjoy! hope this helps!
Performing a hard reset
  1. Turn Off your Samsung Galaxy Note 10.1 device.
  2. Wait for 10 seconds, Then move to the next step.
  3. Press and hold Volume Up key + Power key.
  4. Keep pressing the above keys until the Samsung Logo appears,Then release Power key only.
  5. When you see Factory reset / System Recovery menu on screen release the Volume Up Key.
  6. Use Volume Down key to select Wipe Data / Factory Reset option.
  7. Use Power key to confirm the operation.
  8. You need to use the Volume Down key again to select "Yes - delete all user data"
  9. Use Power key to confirm.
  10. After performing the hard reset, Select Reboot System Now option, And confirm it using Power key.
Jan 31, 2014 | Samsung Galaxy Note 10.1 2014 Edition with...
My galaxy 2 tablet will not turn off. Can you help me?
you maybe heave problem with a key it is nor responding , not heave a contact
Nov 03, 2013 | Samsung Galaxy Tab Tablet PC
My galaxy tab 2 7.0 wont reboot. when I shut it off and turn it back on it wont go past the samsung logo. I have tried to plug it in, it shows the battery icon and its full. I hold the power button down...
At frist turn off your smart tab&then press [(Volume+)+home key] on that time you have to press power key again and again.then you get cwm recovery.then select update from sdcard by using vol - key and click it by using home key.then select your zip file which is dwonload you before for root your phone.
Thank You
-Mitin Sakib
Aug 27, 2013 | Tablets & eReaders
I have an Evorea Tablet, I power up get a white screen but no home buttons show up, in fact nothing but a white screen
Hello Jachin, if you still have this problem. Try doing a "hard reset"
- Turn off tablet
- Hold down the power and volume "down" key together
- when red text appears select "yes" by holding down power key for 10 secs.
Reformatting shall commence
Please note that this process works on most android tablets.
Hope this helps
Nov 24, 2012 | Android Tablets & eReaders
I want to hard reset my galaxy tap. I have a symbol of phone on left then central yellow triangle with ! and computer symbol on right and holding volume button down with power button nothing happens
THERE IS NO USE OF HARD RESET I THINK THAT MAY BE WRONG WITH UR HANDSET POWER &VOLUME KEY BETTER U GO TO SAMSUNG SERVICE CENTRE
DONT PUT ANY OUT SOURCE IT MAY TEMPER UR WARRENTY
May 24, 2011 | Samsung Galaxy Tab Tablet PC
The wireless key doesn't seem to be working on my X41. There is nothing wrong with the network but the computer can't/wont find any networks. If I need to change the wireless key where do I find it? (I do...
Before you can use the assigned X41 Wireless ON/OFF key and other hot keys, you need to load the appropriate and specific Hotkey driver for your X41 and Operating system (XP, W2000, VISTA or W7):
If you do not have the drivers media, see this link or other on this Lenovo/IBM site: http://www-307.ibm.com/pc/support/site.wss/MIGR-68000.html
ps. You can also locate the Wifi driver starting from the above site.
Hope it helps.
Dec 20, 2009 | IBM ThinkPad X41 Tablet PC
How do joy sticks operate
it is input device as mouse. it is use in to play game. we can operate game by arrow key in key bord. But joistick is as handle, we can roated it any direction so it hehps easy to play game. we can get it in usb and serial. thanks
Mar 07, 2009 | Toshiba Portege M700-S7002 Tablet PC
Tablets & eReaders Logo
29 people viewed this question
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
