Question about Garden
Getting my bp42 leafblower to stay on - Garden
Ryobi bp42 leaf blower making a rattle noise
first thing to check is a branch/trig stuck in the tube and hitting on the blower impeller fins
Nov 22, 2016 | Ryobi Garden
Ryobi problems
sounds like you have either a dirty carb or a small air leak
Aug 11, 2014 | Garden
Ryobi BP42 leaf blower will start but will not rev up when I push the trigger - how can I fix this?
Its a lean condition, not getting enough fuel. Check fuel filter and fuel lines. be sure you have fresh fuel. and the carb needs to be adjusted or rebuilt.
Jul 08, 2014 | Ryobi Garden
Ryobi BP42 leaf blower will start but will not rev - how can I fix this?
Its actually the opposite of flooding. Its lean. Adjust carb or rebuild carb.
LEAFBLOWER WON'T START
check fuel lines inside fuel tank, see if will run on a shot of starting fluid e85 gas eats them
If you need further help, I’m available over the phone at https://www.6ya.com/expert/mike_9693b5ad75773352
Sep 01, 2012 | Weedeater 2 Speed Gas Blower FL1500LE ()
Leafblower... getting fuel, but when I try to start its not getting spark... pulled plug and held it while I pulled the started... nothing... what would be the next step to get it to fire??
remove the flywheel and check the pickup coil and flywheel faces for rust on them as this can kill the pickup signal that you need to make a spark,if rusty,sand them lightly and blow out with air
Apr 18, 2010 | Poulan Weed Eater No.Ebv215 Electric...
Brand new leafblower first use and it stalled after 5 minutes. tried to re-start and the pull string will not move?
hopefully unless it is a 4 cycle? you mixed 2 cycle oil and fuel together as one and put it in the fuel tank? you can use a 40:1 mixture 3.2 oz of 2 cycle oil to 1 gallon of fuel 87 octane will work or 89 octane is better.
if its a 4 cycle (10w-30 for oil) and fuel go in a seperate area?check your manual to verify what they would like you to use
Jul 03, 2009 | Yard Man Garden
Craftsman leafblower running worse
Check the exahust screen (if fitted) for blockage. or exahust port...If it is clean port and or screen and use correct type/ ratio mix.
Dec 14, 2008 | Craftsman 4 Cycle Blower/Vac
Garden Logo
26 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
