I have pionner audio video receiver VSX-D710S but no sound even i turning up the master volume of the audio video receiver
petraman7
  • 1175 Answers
SOURCE: Pioneer Audio/video Multi-channel receiver Mod#VSX-D710S
Have you tried a 2nd source like the CD input or AUX input?
Have you tried the headphones..same static?
If nothing works then the output amp is broken. There could be internal fuses but only open a stereo when the power is DISCONNECTED. Then check for fuses
Posted on Feb 02, 2008
  • 21 Answers
SOURCE: AUDIO VIDEO MULTI CHANNEL RECEIVER VSX-818V NOT
Check fuse or power supply
Posted on Oct 27, 2009
SOURCE: I have a VSX D710S and it flashes poweroff then
Im having this same problem. It happened after I had the music up really loud for about 3 hours. Also, where it has the volume all i see is -- instead of a number when i try to turn it on
Posted on Jan 07, 2010
  • 14 Answers
SOURCE: Pioneer VSX-01 TXH receiver turns off
Sounds like the speaker circuit is overloading or the receiver is overheating.
Check to make sure all speakers are in phase. Pos to Pos. Neg to Neg.
Make sure receiver has plenty of cooling room.
Hope this helps.
Posted on Apr 17, 2010
dunnbiker
  • 8546 Answers
SOURCE: my pionner audio video multi
The problem is not clear. Does the unnamed multichanger turn of/on wit hthe VSX-498 or is the VSX-489 having power issues?
Is the power cord of the multichanger plugged into the back of the VSX maybe the outlet is SWITCHED with the power state of the VSX..
Posted on Jul 16, 2011
How can I connect an analog turntable to my Pioneer VSX-D710S? Also, do I need a turntable with a built in pre-amp?
According to the specs there aren't any phono inputs which would have their own preamp. Everything else is line level so I'm pretty sure you'll need a preamp either between the turntable and one of the line level inputs or built into the turntable.
Mar 21, 2014 | Pioneer VSX-D710S Receiver
Hi ! I have a Pioneer AV receiver VSX-D710S and i have a problem with sound ! At the maxim volume (0db) the sound it's verry low an when i make volume ajustments i heard in speakers some knoking !...
The first thing you need to do is to disconnect all the speakers.
Then connect them one at a time and see if you get the correct volume on any of them.
If you don't get the correct volume on some of the speakers then it's those speakers that are faulty.
If you don't get the correct volume on any of the speakers then the fault is with the internal amplifier and you'd need to take it to get it repaired.
Jul 29, 2011 | Pioneer VSX-D710S Receiver
My pionner audio video multi changer receiver vsx-498 shuts off then turns on when the receiver is on how can i fix it
Jul 15, 2011 | Audio Players & Recorders
Pioneer VSX-D710S and the message SP off and DTS off message appear and I have no sound. Any ideas how to turn them back on?
The SP off message is the setting for turning the speakers off while headphones are connected on some Pioneer models. If yours is one such model, hold down the RECEIVER button and press the SPEAKER (text may be written above another main function) button on the remote simultaneously and the sound should return.
Apr 01, 2010 | Pioneer VSX-D710S Receiver
Nov 29, 2009 | Pioneer VSX-D906S Receiver
No sounds
Test one speakers at other amp to ensure its working. Amp is going into probable protection mode. Disconnected all speaker and av wires (only power) turn up volume and see if it stays on. If not sounboard or volume function faulty. If on, connect one speaker L or R. Go to tuner mode to tuned radio station an listen for sounds. If sound connect speakers and av cables one by one and test each one on its own until amp switches off, or no volume. Investigate from there were prolem is.
Feb 25, 2009 | Pioneer VSX-D710S Receiver
54 people viewed this question
 Grubhead
Grubhead
