Question about Dewalt Heavy - Duty 12" Double - Bevel Compound Miter Saw - DW716
My dw705 sometimes works ok sometimes does't work
  • Robert Sabino May 11, 2010
    what do you mean by works ok???? cuts out of square, brake no grabbing, etc....
    President:
  • 583 Answers
Check the brushes youdoit
Posted on Jul 25, 2009
I have a 12 inch compound mitre saw that makes a grinding
sound, will not gain speed and throws the circuit breaker
Posted on Mar 20, 2011
Where can I order a replacement trigger switch
How to Install a Switch Kit on a DeWALT DW705 Miter Saw ...
? 12:35
https://www.youtube.com/watch?v=FJ1Wo2xufzI
May 15, 2013 - Uploaded by eReplacementParts.com
Get a replacement switch kit for your DeWALT DW705 miter saw ... kit on a DeWALT DW705 miter saw which replaces thetrigger switch (part ...
Miter Saw Parts ' Tool Parts Direct
www.toolpartsdirect.com/saw/miter-saw.html
Shop the Tool Parts Direct inventory of miter saw replacement parts. A miter saw is designed to quickly make cuts at a variety of angles. Featuring a pivoting ..
Oct 23, 2015 | Saws
How do I remove 12" blade from from dw705 miter
loosen the guard screw, UNPLUG tool first, move the guard out of the way, there is a spindle lockon the backside of the gearcase push it and slowly turn the blade until it engages and then remove the bolt, it is a left hand thread. DO NOT disassemble the guard, just loosen bolt and move out away from blade also you need to have the head in the raised position.
Oct 28, 2010 | Dewalt DW715 Heavy Duty 12" Single -...
Need to get owners / instruction manual for my Dewalt DW705 type 3 12" miter saw. Do you know where I can get one quickly?
Hello. DeWalt has 13 types of this saw on file. Here is the link to all:
http://servicenet.dewalt.com/Parts/Search?searchedNumber=DW705&searchType=1
Click on the "more details" arrow of the one that meets your needs, then click the PDF symbol in the top right of the "product information" tab.
If this helps, please rate a four-thumbs up. Thank You.
Sep 12, 2010 | Hitachi C10FCE2 10" Compound Miter Saw
Dewalt dw705 miter trigger won't pull/depress
DeWALT DW705 TYPE 8 12 Inch Miter Saw Parts Sounds like a bad switch, Since you don't have any money it go ahead a replce it. Good Luck
Sep 07, 2017 | Dewalt Saws
MISSING INSTRUCTION MANUAL
C'mon! http://www.dewalt.com/us/service/instruction_manuals.asp?SKU=dw70&submit=Submit
Oct 09, 2009 | Saws
DEWALT DW705 MITER SAW BRAKE DOES NOT WORK
Could be worn brushes, dirty commutator or a combination of both. Unplug the tool and remove one brush at a time noting the condition and length. Use a flashlight look into brush tube and also not condition of commutator. I would blow is out with compressed air and you can try turning the brushes 180 deg and retry. That is usually the problem
Jun 27, 2009 | Dewalt Saws
How to set fence square to blade.dw705
First if you need an owners manual go to Dewaltservicenet.com and in the middle of the page at the bottom type in your model number and get a copy. OK for setting the fence square, first unplug the tool and make sure that the blade isi good. Get an accurate square. Set the table at 0 or 90 degree for a straight cut depending on your scale. Make sure the blade is straight up and down on the bevel before starting. What you want to do is loosen up the 4 bolts on the back side of the fence enough so you can move the fence with some resistance. Set your square on the left side of the blade and pull or push the fence till it is square with the blade, snug up one of the bolts and then put the square on the right side and check for square, you might have to move it some if square snug up one bolt and recheck the left side again, if ok tighten both bolts and recheck the right side and repeat if OK. I sometimes recheck 3 or 4 times just to make sure. Also I should have mentioned about putting a straight edge across the length of the fence to make sure that it is not bent in some way thereby not allowing you to square the blade. Let me know if you need any more help
Jan 27, 2009 | Dewalt DW744S 10" Portable Table Saw with...
Dewalt DW705
Use a continuity tester to check each leg of the cord from plug to switch and from switch to the motor.
Apr 28, 2008 | Dewalt DW744S 10" Portable Table Saw with...
Dewalt Heavy - Duty 12"  Double - Bevel Compound Miter Saw - DW716 Logo
624 people viewed this question
Top Dewalt Saws Experts
JOHN LAPIER
Craig Butler
Craig Butler
Are you a Dewalt Saw Expert? Answer questions, earn points and help others
