Question about Honda Electrical Supplies
Honda generator I read that the battery door on the honda EU 6500is generator might cause the engine to loop when the motor is cold. I would like more information, I looked at mine and the door has vent slots should I cover the complete door or is it the foam gasket that needs sealed?
gisvc
  • 40 Answers
SOURCE: 1985 honda shadow vt500c pulse generator
hi,
locate the crankase cover to the left of the engine towards the lower end of the motor. if the bike has a center stand place it upon it t\and undo the crank cover once removed you will visually see the pulse generator it is like a large type style magnet. good luck
live free ride hard..
Posted on Mar 30, 2009
  • 260 Answers
SOURCE: Motor Oil leaks from 1999 Honda Civic EX
make sure they are tight
could be time for head gaskets
make sure the old gasket from the old filter came off the block sometimes they come off old filter and stick this causes a leak due to improper seal.
Posted on Apr 10, 2009
  • 109 Answers
SOURCE: Oil pan gasket change on 2000 dodge grand caravan
TO answer all your questions, the red oring is for the oil pump pickup tube, one bolt will fix that, RTV sealet is used in the seperation seams at the timing cover and rear seal retainer, 1/6th thick bead, 1/4" wide at seams, has for the trans inspection cover remove it for the repair, 5 bolts will do that part, and rear bracket, then the pan is ready to come off... GOOD LUCK RDJRP
Posted on Aug 07, 2009
  • 583 Answers
SOURCE: i have a honda generater gx160 removed side cover
dont know what happened here ,i did this ten minutes ago.o.k. if you look at the gear on the crankshaftnext to the lobe you will see a large dot near the teeth ,now if you look at the out sid of the camshaft you will see apointer like this V only pointing out ,put the point to the dot and slidde the cam in .. if the valvelifters are in the way and you cant get past them,you will need to take the rocker cover off remove the rockerger and pull the push rods out then you can reassemble it all ther tappet clearances are inlet .006 and the exhaust is .008 once you have it back together [dont forget the oil ] start her up ,when warm re check the tappets , and go and have a nice cold beer ,you deserve it any problems at all just come back to me... "youdoit"
Posted on Oct 25, 2009
  • 288 Answers
SOURCE: I have a Honda EU 2000i generator. With eco switch
starving for fuel. the generator will always rev up when it is under a load or about to run out of gas. there will be a few adjustment screws on the carb... one for air and one for fuel. try increasing the fuel a quarter turn and see how that does
Posted on Dec 19, 2009
How to correct e04 error cod or governor circuit on eu 6500is generator
The "governer" is really a throttle motor (basically a servo motor) that sits on top of the carb that gets its signal from the inverter and adjusts the throttle according to compensate for load power output. My first place to look would be that small motor on the top of the carburetor. I have seen them go bad so they either bind up or burn out.
Feb 16, 2015 | Honda EU6500iS Inverter Generator
My honda 2000 generator only runs for about 3 seconds then shuts off
Its sure that its missing oil at the engine.Modern engines have a oil alert dispositive. Check oil level,if it is low,just fill with more oil at carter engine.
Sep 03, 2014 | Honda EU2000IKN EU 2000 Watt Generator 50...
Causes cylinder misfire
Could be injector or possibly intake gasket leak.
see misfire section at link below.
Do It Yourself Diagnosis and Repair
Aug 11, 2017 | Honda Cars & Trucks
I have a eu 6500is generator inverter that will run perfectly for any amount of time, then with no warning just stop generating and idle. No overload alarm. No oil alarm. Nothing will just idle. If you...
this sounds like a capasitor/resistor that is getting hot under load once it is switched off and cools down it works until it gets hot again similar to that of a cars ignition coil which will get hot and cut the vehicle out but once it cools it will start again.
Dec 07, 2013 | Honda EU6500iS Inverter Generator
Honda eu 6500 Error e21. First time using it and the machine is new. How to fix it? Sorry there wasn't category for generator
check oil levels as generator will not start if oil level is low. this is a built in safety device on most generators and one of the leading causes of returns to stores />
Aug 03, 2013 | Garden
Honda eu 2000 generator surging
remove the throttle control motor spin motor a few times. I believe due to the minimal rotation required during activation a flat spot or build up results in a poor connection. Kicks down under load now. Back to the smoothnes of a new unit
Dec 28, 2012 | Honda 6370C - Parallel Power Kit For ...
Electrical Supplies Logo
27 people viewed this question
Top Honda Electrical Supplies Experts
John Trevino
Are you a Honda Electrical Supply Expert? Answer questions, earn points and help others
