I have a 350 Braun stick mixer,which has serviced me very well. The black plastic connector piece in the top driver,has become disfunctional,
The Black plastic connector piece in the top Drive,has become disfunctional, and will not now connect to the drive shaft in the lower half. Is this piece replaceable?
Master_Tech
  • 770 Answers
SOURCE: I had an "f2" error code on Fisher Paykel DD603
i will but need your email address
Posted on May 20, 2008
SOURCE: part removal and replacement
The black plastic clutch has a left-handed brass threaded insert. Temporarily remove the motor to hold the shaft and remove the brass insert by rotating clockwise.
Posted on Jul 12, 2008
rowdy45176
  • 2176 Answers
SOURCE: Dremel Model 395 Type 3 Plastic Drive Shaft
You can call Dremel direct at 1-800-437-3635 and order the part. Let me know if you need more information.
Posted on Apr 14, 2009
hslincoln
  • 235 Answers
SOURCE: KitchenAid K5sswh mixer after replacing plastic gear-no power
Hi COVINIO. Yes, the "large black spring loaded magnetic screws on the sides of the mixer" are your mixer's brushes, which supplies electricity to the electric motor. (The black cap is the brush cover). I suspect that one or both of the brushes is (are) not seated properly. Did you remove the brushes to replace them or were you just inspecting them, when you replaced your plastic worm gear?
The brushes need to be installed so that they both seat correctly on the armature's commutator. See the illustration below:
I'd suggest removing them again and making sure the concave contact face rests completely on the armature’s commutator. If you've turned it 90 degrees too much, it won’t seat properly and you get no power to the motor.
It would also be helpful to have the Parts List manual on hand. If you're lacking one, you can download a PDF version from the KA website at: http://www.kitchenaid.com/flash.cmd?/#/page/home.
Click on Customer Care>Locate Manuals & Guides> Enter the 6 character model number, in your case use KSM50P (Your K5SS mixer falls within this manual), and select the first file KSM50P.pdf (438.31 KB) listed under Parts List (4) and then check to verify this matches your mixer model.
Turn to pages 6 & 7, titled “Motor And Control Parts”, which provides an exploded view for the disassembly and reassembly of your mixer’s electrical components, along with all the parts. Locate Illus No 47, Brush holder assembly that includes #28, 32, 33, 34 & 46 which is the brush holder insert, and Illus. No. 29, brush & Spring assembly respectively. The illustration along with the picture above regarding the orientation of the brushes should get your mixer powered back up and operational. Good luck! I hope this helps. Howard, Burke, VA
If this solution has been helpful to you, please rate it, thanks! -hslincoln
Posted on Jan 29, 2010
Testimonial: "Dear hslincoln,Thank you for your very helpful link to diagram that showed exactly what to. It was fixed within 3 minutes"
SOURCE: needs new black rubber tubing connector
my sunbeam model 7660 bp monitor needs a new part on tubing. on the inside of machine there's is a black rubber piece that connects the clear plastic tubes. where can I get a new part? thanks..
Posted on Mar 17, 2010
I don't know much too add to describe my
can you contact customer service at braun and ask them if they supply replacement parts and how would you go about buying one? hope this helps.
Oct 31, 2017 | Health & Beauty
Replacement parts
Part 2: Opening up the Braun handheld blender/mixer turbo 600, typ 4191.
A second phase, with the Dremel for working in the direction of the axis and splitting up the tools mounting part, also showed that no other way was available to open the machine7be945c4-ba75-4b59-83da-fc638caa551e.jpg
Oct 30, 2013 | Braun MR 5550 M HC + BC MultiQuick...
Part "i" , the plastic(nylon) tooth part on my Braun PowerMax Blender, type 4184, broke and I need to find a replacement part. The Braun Service website was useless. Can you help? ...
www.smallappliance.com. you can order a new blender blade which has the white nylon teeth or you can order the coupling which is the black teeth that the jar sits on. NOTE: the black one is easy to replace, but getting the screws out of the base is the hard part.
Jul 02, 2010 | Braun MX 2050 PowerMax Work Top Blender
Looking for a service manual for the Braun 7570 syncro razer
It's actually easier than it looks. On the bottom of the shaver is the charging port. That black plastic piece surrounding it can be pried off. Do it carefully, so you don't dent/scratch the casing. Once removed, the side pieces easily remove. You'll now see screws holding the body together. Have at it. :-)
Jan 08, 2010 | Braun Syncro 7570 Electric Shaver
Braun 4166 household blending mixer How do you take this apart?Disassemble?
1. Remove two small plugs on top, digging a wood screw into the soft plastic. They cover two screws.
2. Remove the screws.
3. Remove the cover.
4. Remove two screws holding the motor housing to the foot.
Dec 21, 2009 | Braun MR 300 MultiQuick Blender
Where I can get a replacement backplate for my Braun M880 mixer?
Braun Products & Replacement PartsPayPal Braun Shaver, Appliance & Dental Parts. Parts Ship Free over $60. SmallAppliance.com
Good Luck_Ned_
Nov 05, 2009 | Braun M880 MultiMix Hand Mixer
How to open it to change the electric cable ?
I'm looking myself for a guide to open it fully, but I can at least answer your question partly. Maybe you can get on from there.
When you look at the front side of the mixer(the side opposite to the cable), there's a slim oval lid with rounded ends. Push a small flat sdcrewdriver under that lid until it pops out, revealing a screw. Remove the screw.
The rest of the enclosure seems to be held together by several hidden plastic clips. Use a pocket knife with a thin blade and push it carefully between the halves of the case. Work your way from the screw to the top and bottom side, levering the halves apart step by step. Do not use too much force!
I'm stuck at the back of the case where the rubber ring is. I can't get this part open., but it's a start
Feb 14, 2009 | Braun M880 Multimix Hand White Mixer
Washing Machines Logo
21 people viewed this question
Top Washing Machines Experts
