Question about Vanguard Heating & Cooling
1st panel on Vanguard 22,000 btu ventless propane wall unit has overshooting flame causing strong exhaust-like odor in house. Has black residue coming out of top vents. No fan on this unit.Help!
Propane wall heater. We have a Vanguard model VP22001TB. 22,000 max btu. Probably installed around 1995.This propane wall unvented heater is installed in our home. It has begun to give off an odor more like automobile exhaust in the home and the flame on the 1st panel is overshooting up over the ceramic panel and burning onto the metal piece above causing black residue coming out of the upper vents. When we put it on the 2nd or 3rd panel it doesn't do that on those panels, just on the first panel. Is it possible the first panel needs to be replaced? We've been using this heater as our main heating source for 10 years. Most of the time we just have it set on panel 1.We have a heat pump, but prefer this heater. We turned it completely off for now. Would like some answers soon. Thank you.
    Top Expert:
  • 50,576 Answers
Good thing that you turned it off as it is now not operating as designed and that makes gas dangerous
call an accredited gas fitter to properly diagnosed the problem and repair/ replace it
Posted on Jan 01, 2017
  • Kim Graham
    Kim Graham Jan 01, 2017
    Thanks for leaving a reply. Will do.
Why suddenly a strong odor of burning fuel when heater is operating?
Improper air to fuel mixture, way to rich.
Does this heater have the ability to adjust ratio?
if so, play with adjustment until odor goes away.
Mar 25, 2015 | DynaGloDelux Dyna Glo Delux Liquid Propane...
I have a blueflame probane heater ventless and when burning it has a slight smell. Is that normal for this ventless heater.
It depends on what it smells like. Initially, when the unit is installed it should be burned on HIGH for 45 minutes to an hour. Doings that, burns off all the oils and seasons the heater. Sort of like seasoning a cast iron skillet. After that, the newness odors should be gone. It's normal to get a whiff of gas when the burner lights or turns off. It should dissipate rather quickly.
Although Vent-free (ventless) heaters are very safe to use and are 99.5% efficient, their one drawback is that pick up strong household odors, like strong cleaning products, carpet shampoos, new paint or stain odors, strong cooking odors, etc and make them worse. That's why it's always best not to use the heater during or after painting, for at least 2 weeks. Although your nose may not detect the paint odor, the heater can and will make it worse. Also, always use your range's exhaust hood when cooking. Hopefully, it's the vented type and not one of do nothing recycling hoods.
Also, thoroughly cleaning the heater inside and out , at least once a season, will go along way in reducing odors and maintaining the longevity of your heater.
One other caution, do not burn scented candles and operate the heater at the same time. Scented candles soot anyway, but adding the warm moist, comfortable heat from the vent-free heater, will cause them to soot 50 times worse. Trust me, it's not the heater, it's the scented candles sooting.
Hope this helped explain some of the things that you asked about and more. If I can be of further help, please ask me through the Leave a Comment link.
Apr 22, 2011 | Procom MN300HGB Heater
I have a Kozyworld wall mounted ventless propane heater. Whenever it automatically turns ON or OFF you get a strong odor of propane. While it is ON you don't smell propane. What is wrong with it. I...
You need to clean it out. Take the wall heater down and use a air compressor to clean out the gas system. Also clean the orifice out. Make sure that the chamber is clean and clear of spider webs and dust.
Jan 26, 2011 | The Companion Group Kozy World Portable...
I have mold problems when using ventless propane gas wall heaters in a small rental house. The house is very tightly insulated. How can I solve this problem?
Air requirments for these units are 50 cubic feet of air for every one thousand BTU'S - if you are under this amount need to have fresh air into the room with a grill that has 1 square inch for every thousand BT'S.
Oct 06, 2010 | Heating & Cooling
Charmglow ventless gas fireplace burners won't ignite
is pilot flame on the thermopile good, pilot flame should cover the thermocouple and thermopile if unit has both
Jan 07, 2010 | Blue Flame Charmglow 30K BTU Propane Vent...
I have just installed LP ventless in my garage . Burns a nice blue flame but the odor will burn your eyes and smell gets in the house. I had used this same heater 2yrs ago just fine w/no issues .Cleaned...
if your burners are dirty you will get incomplete combustion and this could cause the problem you described. be sure that the unit is for lp and not natural gas this situation could also cause the issue you describe.
Dec 12, 2009 | Washing Machines
Wmn20a ODORS
How long has the unit been running for? sometimes with these newer heating elements it takes a while to burn off the oils used to make them.
May 29, 2017 | Desa International CBP20T Wall Mounted...
Pilotlight will not light, getting spark, but no propane.
make sure you have the gas valve knob on turned to pilot while pressing that down while pushing the spark it should light or it is tripped on a safety like rollout switch or oxygen depletion sensor if equipped which all ventless heaters are
May 12, 2009 | Dyna-Glo D-E37 Wall Mounted Panel Heater
Heating & Cooling Logo
Top Vanguard Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Are you a Vanguard Heating and Cooling Expert? Answer questions, earn points and help others
